Kit-bashing Tamiya PzII into Hover tank
    April 2011
Posted by Unreality on Tuesday, April 12, 2011 9:31 PM
This is my first build log here, and I'm already several days in, so bear with me.
This started as a challenge by my LHS to buy and build a kit in a little over a month (because some of the guys there rarely finish stuff). The kit was Tamiya's old and rather crappy Panzer II F/G. The rules were simple: use only what's in the box, e.g., no aftermarket, no scratch-building, and nothing from the spares box.
I decided to stretch the rules a little and build something kit-bashed using what's in the box. So, I have the plastic parts, clear baggies, 2 staples, the instructions, the poly-caps, decals, and the box if I really need it. Technically, they are all part of the package...so we'll see how it goes.
I planned early on to do a hovertank with the back of the Pz II representing the front of my tank. That said, I had to do some major surgery to cut off all of the molded on details. And because I needed to conserve parts, I needed to save what I cut off. Thin Zona saws helped with this.
Lot's of pieces to use later...
The torso of one of crewmembers made an excellent substructure:
Front armor plate and visor:
The top half cut and sawed down:
This is kinda how it will fit together:
Action Fleet Unlimited: Star Wars models, customs, toys, techniques, and scale lists (with a few non-SW models thrown in)
Cheers
    April 2011
Posted by Unreality on Tuesday, April 12, 2011 9:35 PM
A few days ago I glued the top and bottom halves together and had a big gap to fill. Without the ability to use styrene strips, I used one of the Tamiya sprue logo pieces:
Before and after:
The Fourmost Miter Sander is one of my favorite scratch-building tools:
Could be better, but it's ok for what I have to work with:
Cheers
    June 2010
Posted by OctaneOrange on Wednesday, April 13, 2011 1:36 AM
What an interesting concept. sounds like it'll stretch your imagination a little. i'll be interested to see what you can come up with.
    October 2008
Posted by bsyamato on Wednesday, April 13, 2011 12:49 PM
Cool
Very curious to see it finished!! Yes
I'll follow
    April 2011
Posted by Unreality on Wednesday, April 13, 2011 11:45 PM
Thanks guys. By the way, nice avatar OctaneOrange.
So, I worked on the rear turbines today. I had to chop away the rear armor, and in it's place, I glued together 2 of the included figure stands. Then I Dremeled some holes for the actual turbines:
Before and after...sort of:
I liked the look of the idlers, so i used them, but opened the center up for turbine cones. The cones I used were thick sprue pieces shaped with a Dremel into the best cone I could get freehand:
Glued and puttied:
I'm still not sure what I'll do with the flaps on either side of the turbines. If I leave them, I'll need to reshape them...maybe add some kind of air brake.
Cheers
    February 2011
Posted by GreySnake on Thursday, April 14, 2011 3:20 PM
That's one cool looking build Yes Looking forward to seeing it finished.
    February 2011
Posted by MAJ Mike on Thursday, April 14, 2011 6:50 PM
ToastWow
 "I'd "I'd rather be historically accurate than politically correct."
"Sic gorgiamus allos subjectatos nunc!"
    August 2009
Posted by SLW 45 on Thursday, April 14, 2011 9:11 PM
Cool idea cant wait to see the finished product Yes
    April 2011
Posted by Unreality on Friday, April 15, 2011 9:54 PM
Well, I've added a bit more over the past few days. I keep banging my head in the wall just wishing I could open my spares boxes. But I'm committed....for now.
I needed to cover up the large opening on the left side, so I took the underside of the turret (the part the allows it to rotate) and saved the angular part off. With a little work and sawing, I cut out the circular inner lining and then glued it to the side.
After a long deliberation with me and myself, I decided to add a dust vent for whatever small particles were sucked into the engines. This consists of a one-piece box that I cut out the inner bits, as well as 4 canteens that will act as dust spouts....sort of.
The box was also given angled cuts on one side of the 3 slats to help with the fit.
I had a fun time trying to drill a hole centered on the top of each canteen when the mold doesn't even seem to be centered.
It's a little rough, but I'm thinking some Mig pigments will enhance the believability.
Next up will probably be the turret. Oh joy...
Cheers
Posted by Gamera on Friday, April 15, 2011 11:22 PM
Gee, when I think of kit-bashing it's of adding extra stuff to the kit not using what's in the box. Very cool idea!
Please keep up the updates I wanna see how she comes out. Cool
    January 2006
Posted by SprueOne on Sunday, April 17, 2011 10:25 AM
yes, I'm watching this build
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    April 2011
Posted by Unreality on Monday, April 18, 2011 11:20 PM
Not much new lately, just filling, sanding, smoothing, wash, rinse, repeat. I have started a few smaller assemblies that I will attach later.
First, I've made 2 air brake steering flaps. I cut the top lid of the storage bin in half and fit some leftover turret bits on the opposite sides. I then recut the edges of the lid into a more angular shape:
As part of the covering the center up, I made a dust filtration system (the dust exits through the side ports I already made). I cut one side of the spare track link piece off and then glued several running gear bits to it. These bits were originally molded on:
Finally, I added a scanner/antenna assembly to the front. It is made of the antenna holder with the sledgehammer tool set glued underneath (hammer head removed).
Thanks again for the comments guys. This is a fun little build.
Cheers
    April 2011
Posted by Unreality on Wednesday, April 20, 2011 4:37 PM
I decided to add tinted windows to the cockpit and turret area using the clear bag the parts came in. To do this I mixed future and Polly Scale RLM 83 Light Green and airbrushed it on a large section of the bag. It didn't adhere well, but I covered such a large area that i could cut out the best sections. Then I glued it in place with Future, and later I added some white glue to fully hold it in.
This is a pic of the finished dust filtration system. I still need to do more filling and sanding:
Here's a pic showing off the air flaps. The actuators were made from MP40s.
Finally, I changed the cupola by routering a roadwheel and fitting the hatch to it. I'll glue it later:
Cheers
    January 2006
Posted by SprueOne on Wednesday, April 20, 2011 7:22 PM
I like your resourcefulness and on the spot engineering Idea
    April 2011
Posted by Unreality on Friday, April 22, 2011 1:01 AM
Thanks man. I wouldn't call it on-the-spot though. It's more of a blaming-everything-else, then cooling-off-and-working-through-a-solution engineering.
Anyway, in this update, I've modified the road wheel shock absorbers into hovering things (if you're a Star Wars fan, we can call them "repulsorlifts"). Then I attached them facing inward on the underside of the chassis. When I get it assembled, you'll be able to see the results better.
Cheers
    June 2009
Posted by Guney on Friday, April 22, 2011 5:31 PM
Looking perfect so far....Good luck.....Smile
    April 2011
Posted by Unreality on Saturday, April 23, 2011 8:22 PM
Alright, so I've been hitting it hard lately trying desperately to hit the painting stage (not yet though). I did finish making the barrel out of a sprue. It's certainly not turned aluminum, but it will work:
And I made an ammo feed belt by splitting the tank tracks and CAing the German ammo drums in between:
Here it is sitting in the feed roller/drum thing (made out of the exhaust and stowage bin):
Uploaded with ImageShack.us
Cheers
    October 2008
Posted by bsyamato on Saturday, April 23, 2011 8:51 PM
great looking Geeked
actually it seems like.. it
Yes
    April 2011
Posted by Unreality on Sunday, April 24, 2011 10:28 PM
Well, I have about 5 days until the contest, but it's going good so far. I just primed it with my cheapo rattle can grey. Here's a pic moments before. I added a rail and two grab handles out of the 2 staples in the box, and I added a bit more detail bits around the model....nothing that big.
Painting is next!
Cheers
    April 2011
Posted by Unreality on Monday, April 25, 2011 9:13 PM
Well, the first bit of painting is finished. I opted for a unique "tetris" looking camo pattern, which required a lot of tape. There was a little bleed through in a few areas, but I can easily fix that. I'll probably paint the turret and details tomorrow.
Cheers
    April 2011
Posted by Unreality on Wednesday, April 27, 2011 12:54 AM
Finished the painting today.
I also used part of the cardboard box to create strips to hold on the extra fuel cells. It's not photo-etch, but it works just fine.
Everything painted:
Cheers
    February 2011
Posted by MAJ Mike on Wednesday, April 27, 2011 6:03 AM
Amazing!
    November 2006
Posted by dupes on Thursday, May 5, 2011 3:05 PM
Wow. That's really cool.
Can't wait to see the finish!
    April 2011
Posted by Unreality on Sunday, May 8, 2011 12:46 AM
Well, I almost didn't finish. My area got hit hard by tornadoes last week and it's taken quite awhile to sit down and actually photograph this thing. Luckily, we're ok, just a few small trees down. As for the tank, I added several filters and weathered it in a "used, but not junked" look.
Enjoy
Cheers
    February 2010
Posted by Stage_Left on Sunday, May 8, 2011 12:54 AM
Glad you're ok......I've seen the reports from down there and it's scary just to look at.
Fantastic build. Love the approach, and love the result. Yes
    October 2008
Posted by bsyamato on Sunday, May 8, 2011 5:53 AM
good to ear all it's ok
tank looks great YesYes
    February 2011
Posted by MAJ Mike on Sunday, May 8, 2011 7:55 AM
Amazing.
    January 2006
Posted by SprueOne on Sunday, May 8, 2011 9:39 AM
Great looking tank. The paint and weathering as well as the mash-up detailing
also, glad you're ok
    April 2011
Posted by Unreality on Sunday, May 8, 2011 6:43 PM
 Thanks guys.
Cheers
    November 2006
Posted by dupes on Saturday, May 21, 2011 2:11 PM
Man, great finish! Cool
I wonder what I've got kicking around the stash that I could turn into something like this. Hmmmmm.
