The saucer from "FORBIDDEN PLANET"
    August 2008
Posted by tankerbuilder on Monday, June 11, 2012 10:44 AM
I got to thinking one day."How do I get more clear panels on this and the UFO model I have as well as the ROBINSON family spaceship? I was categorizing my C.D.s when it hit me like a ton of bricks.The clear panels from cd jewel cases! REALLY ! I also found certain pans in the kitchen that have very close profiles to what I needed.
Well I took one of those pans and got it hot, Not blistering , but , hot enough to bend plastic.I then very gently laid the panel on the surface.It bent just fine.Then I checked the fit ,adjusted it in very hot water,Cut it to fit where I wanted and VIOLA!!! A nice ,very clear panel showing more of the interior of the ROBINSON ship.
Now ,I can do my version of the UFO saucer.As you know it doesn,t have a lot of detail.So imagineering is called for here. Good luck on your project.    TANKER-builder
Posted by Gamera on Monday, June 11, 2012 7:32 PM
That sounds like a great idea! Would love to see photos Camera
    February 2007
Posted by mitsdude on Tuesday, June 12, 2012 2:54 AM
Sounds interesting!
However this old brain needs a pic to fully understand the concept.
    July 2003
Posted by Kugai on Wednesday, June 13, 2012 12:16 AM
Ain't it great when something relatively simple comes to mind that you can use to make a good kit even better, as well as uniquely your own?
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    June 2010
Posted by OctaneOrange on Monday, June 18, 2012 7:03 PM
i'm amazed you were able to get it to bend without melting, crazing or twisting.
i've used the cd jewel cases for flat clear styrene, but because it's so thick, i tend to shy away from it.
    April 2009
Posted by Cadet Chuck on Monday, June 18, 2012 7:23 PM
The C-57D saucer from "Forbidden Planet" is a huge but rather boring model.  The only interior detail exists in the center section, under the clear dome.  I spent a lot of time building one, but am thinking about recycling it now, as it is just not very interesting.  Now, if you could put more windows in it, and scratch-build details inside the outer portions of the saucer, that would be very interesting, indeed!  Good luck and let us see pix!
