1/25 Moebius Dark Knight Tumbler COMPLETE! (Pg.5)
    March 2006
Posted by TD4438 on Tuesday, December 3, 2013 2:47 PM
Hopefully I won't screw this up.
    August 2012
Posted by JimNTENN on Tuesday, December 3, 2013 5:12 PM
You won't screw it up. You'll be fine. Just take your time and enjoy. Despite its flaws it really is a fun kit to build.
Your seats look better than mine.
Current project(s): Hobby Boss: 1/72 F9F-2 Panther
                                  Midwest Products: Skiff(wood model)
    March 2006
Posted by TD4438 on Wednesday, December 4, 2013 7:20 AM
Thanks.I think I need to add some shading to the belts.Other than that,I'm happy with them.
    January 2006
Posted by SprueOne on Wednesday, December 4, 2013 7:04 PM
I'll be here for this one as well.
Come-on man, you're a model builder, how can you possibly screw anything up? Black Eye
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    March 2006
Posted by TD4438 on Thursday, December 5, 2013 4:03 PM
Current progress.Center console complete.
The instructions have you glue the interior panels to the exterior panels before constructing the cockpit.It was far from clear as to the proper alignment,so I attached the outer panels together first.Had I done otherwise,I probably would have been way off.
    August 2012
Posted by JimNTENN on Thursday, December 5, 2013 4:09 PM
Yeah, that was one of the assembly steps that should have been done differently in the instructions. I think I had to reassemble one of the inner side assemblies because it wasn't  lined up right.
I like your choice of colors for the interior.
    June 2010
Posted by OctaneOrange on Thursday, December 5, 2013 7:25 PM
something i'll keep in mind when i build mine
    March 2006
Posted by TD4438 on Friday, December 6, 2013 7:08 AM
I'm not sure what I'm gonna do about the floor.The instructions call for silver,but it has a texture to it the rest of the interior doesn't.I think I'll go with grey to provide a bit of contrast.
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 7:37 AM
I would have liked it better if they hadn't given it that texture.
    March 2006
Posted by TD4438 on Friday, December 6, 2013 5:10 PM
Current and very irritating progress.I cannot get the dash to fit the rest of the interior.
    March 2006
Posted by TD4438 on Friday, December 6, 2013 5:19 PM
I'm beginning to understand the problem here.DO NOT install the dash to the outer wall as instructed.Like the rest of the interior panels,there is no way to determine proper alignment.I do believe I'm gonna have to raid my second tumbler kit for replacement parts.
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 5:20 PM
From what I remember it was a little stubborn. The main thing is to make sure the dash is attached correctly to the front wall...in your photo it looks like it is...and make sure the inner side walls are attached properly to the outer walls. Each end of the dash is shaped to fit precisely with the ends of the inner walls. From what I can tell it looks like everything is right. The tabs on the bottom of the dash didn't meet the slots perfectly. It might have been a little warped. I had to coerce it all together a little but it went.
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 5:24 PM
Hold on. Don't raid your other kit just yet. If you are absolutely certain the sides are lined up right and the dash is with the front wall then it should go in. It is a little tricky but it will fit if everything else is lined up right.
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 5:25 PM
Also, I did attach the dash to the front wall and then to the interior assembly as the instructions suggested.
    March 2006
Posted by TD4438 on Friday, December 6, 2013 5:35 PM
I followed the instructions and it ain't working.The dash is attached to the outer wall way to high to fit at all.There is no way I can separate the parts without destroying them.
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 5:40 PM
It looks to me like you have it on there right. That's exactly how mine looked. Did you use CA or cement to attach the dash to the front wall?
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 5:42 PM
If I could see the interior assembly and the dash/front wall assembly from other angles I might be able to tell if something is out of whack.
    March 2006
Posted by TD4438 on Friday, December 6, 2013 5:48 PM
 Trust me,it's out of whack.The bottom of the dash attaches to the interior floor.The outer panel  attaches to the lip a little higher than the interior floor.I have the parts glued together flush at the bottom.I'm fooked and will have to raid the other kit.
    March 2006
Posted by TD4438 on Friday, December 6, 2013 5:53 PM
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 5:59 PM
Yeah, I see what you mean now. I was trying to visualize exactly how it fit together but I've already forgotten all that. If it was me I'd try to get a saw in there and cut them apart. That's what I had to do when I got one of the side assemblies lined up wrong. But you gotta do what works best for you.
    March 2006
Posted by TD4438 on Friday, December 6, 2013 6:03 PM
I scrutinized your pics for about twenty minutes while hacking off chunks of plastic.That's how I realized where I went wrong.Oh,well.Depending on how much of the interior was actually visible in this build,would have determined if I would even build it into the second.Guess the camo Tumbler is gonna have blacked out windows now.
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 6:12 PM
Man I hate that you have to raid your other kit. What are you gonna do for the front wall in your other kit if you build another Tumbler?
    January 2006
Posted by SprueOne on Friday, December 6, 2013 6:33 PM
This is all very educational for those of us that hasn't started ours yet. Seriously, this is awesome, play by play action.
And that interior color looks great!
    March 2006
Posted by TD4438 on Friday, December 6, 2013 6:42 PM
When I get to the second kit,I'll hack off as much of the dash as I need to and build it without the interior.
Hey Sprue,from my point of view this is irritating play-by-play action. LOL.
The incessant yapping of the neighbors dog wasn't helping either.Five hours of that BS!
    March 2006
Posted by TD4438 on Friday, December 6, 2013 6:46 PM
After further review,I might be able to get an x-acto in there to cut these pices apart.We'll see on the morrow!
    January 2006
Posted by SprueOne on Friday, December 6, 2013 6:53 PM
Cool. Sometimes I just need to step away from the bench and clear my head. Sometimes solutions will just come flooding in that you just didn't see while all stressed out at the moment.
yapping dog finally stopped…. I just read on-line news update about a dog found tied to a tree with it's muzzle duct taped shut. They're looking for information or witnesses now . . . interesting Wink
    August 2012
Posted by JimNTENN on Friday, December 6, 2013 7:07 PM
If you can separate them that will be best. I think I used one of those little saw blades that is shaped like a No. 11 blade except with teeth to cut apart the side pieces that I misaligned.
    March 2006
Posted by TD4438 on Saturday, December 14, 2013 6:57 AM
Our PC dropped a MONSTER deuce and is down for the count.I have plenty of pics to update the build log with as soon as we replace the hard drive.BTW,Mr. Exacto got those pieces separated no problem.I won't be raiding the other kit for parts.
    August 2012
Posted by JimNTENN on Saturday, December 14, 2013 7:03 AM
Good to hear you saved your other kit. Sorry to hear about your PC.
    March 2006
Posted by TD4438 on Monday, December 16, 2013 1:33 AM
      Current progress.
