MaK: Nitto AFS Mk 1
    September 2006
MaK: Nitto AFS Mk 1
Posted by the Baron on Friday, March 6, 2015 12:27 PM
A couple of years ago, my buddy Hershbell got me interested in Maschinen Krieger, giving me a Raptor from his stash.  This is my second completed MaK kit, the old Nitto Mk 1 AFS (Armored Fighting Suit)
I started this in December 2013, and worked on it, off and on.  Not that it was a difficult kit, but I would hit roadblocks and stop till I thought my way around them.
One thing that I wanted to do was to depict the suit in a more animated pose than is usual for MaK subjects.  The armored suits remind me a lot of the Mobile Infantry in Robert Heinlein's "Starship Trooper", and I picture the suits as enhancing the pilot's movements.  A weapons system that makes it harder to fight would tend to lead to a dead pilot.
Another thing that I wanted to do was to modify the kit's pilot head.  I originally sculpted a crash helmet, didn't like it, and then got the idea to make the pilot a Sikh.  In this, I thought of David Drake's Hammerverse, with mercenary units reflecting various countries and ethnicities from old Earth.  Why not a Sikh battalion, fighting with the mercs against the SDR in the MaK world?
Anyway, here's the finished product:
and a couple of close-ups:
I hadn't intended to leave off the face shield, but I found that it didn't fit the helmet.  Not that it's a hair to wide here or there--it's not shaped right.
I also experimented in this build with using a hard enamel primer as a base for chipping and scraping with a Scotch Brite pad for weathering.  I used Army Painter matte black, which is an excellent, hard primer.  But then I made the mistake, without even thinking, of grabbing the only sand color I had on hand, which was an enamel.  Needless to say, the 3M pad would not scuff the paint a bit, and I wound up using sandpaper.  That scuffed the top coat, but it also scraped the plastic.  Lesson learned.
Also, the kit comes with coated wire (I think the Brits call it fuse wire) and fine springs to make the power hoses.  They worked well enough, but at one point I had to remove the hoses, and I damaged the kit parts.  So I used wire solder and fine beading wire to replace them.  Wire solder works better than the coated wire, I think, because it's soft enough to shape, but maintains the shape you give it.
The base is built up of foam insulation pieces, with Elmer's wood putty, thinned with water, to provide textures.  It depicts a bombed-out building in New Canberra, in one of the early battles after the war began.  The sign is printed out from MS Paint and glued to a piece of styrene, painted to look like the enamel signs common in Germany today, and weathered to look like it was damaged in the explosion that took out the building.
Hershbell gave me the wooden base, and Paul Keefe gave me tips and advice on various stages of the build, and I'm indebted to them both.
Comments/criticisms/questions are welcome, and thanks for looking!
Brad
Posted by Gamera on Friday, March 6, 2015 2:23 PM
Super cool! I love how the suit came out and the base looks pretty darn cool too! And neat idea on the pose- it's very eye catching.
And as I remember in 'Starship Troopers' the Mobile Infantry were from all over, Rico himself of course being Filipino. Except the lily white cast of the movie- which was probably the worst film I've ever seen and trust me I've seen some awful ones.
    March 2009
Posted by wolfhammer1 on Saturday, March 7, 2015 11:07 AM
Starship Troopers the book was awesome.  The movie cheaped out and gave us guys in body armor and detailed bugs.  Who cares.  I was looking forward to the mobile infantry kicking backsides and taking names.  Since there seems to be a kick of rebooting stuff, maybe we can hope for a real movie based on Starship Troopers.
John
    September 2006
Posted by the Baron on Sunday, March 8, 2015 9:39 AM
Thanks, Gamera!
Yeah, I call the movie "Space 90210", it was horrible.  Clancy Brown and Michael Ironside were very good in their roles, though.  Verhoeven also glossed over Heinlein's political theories from the book.  As a faithful filming of the novel, it's a failure, but as an action film, it's a C+.
I did like the costuming, though.  The Federal uniforms are an interesting mix of elements from various armies, and in that regard, it's a little similar to Kow's MaK-verse.
Posted by Gamera on Sunday, March 8, 2015 7:11 PM
I have heard that there was a movie about humans vs. alien bugs already in pre-production when the studio got the rights to 'Starship Troopers' and decided to stick it on the movie. Verhoeven hated Heinlein's politics and made the movie as a rip on his novel. Or so I'd heard anyway.
    September 2006
Posted by the Baron on Friday, August 7, 2015 12:02 PM
the Baron
...I hadn't intended to leave off the face shield, but I found that it didn't fit the helmet.  Not that it's a hair to wide here or there--it's not shaped right...
I need to add a footnote to this, especially for anyone else who is going to build this kit.  I've found that the issue with the face shield is not one of fit, but of my own mistake.  The shield is meant to be installed from the inside of the helmet, not from the outside.  I missed this completely.  Of course, it means that if you do install the shield, you need to address keeping it clean of paint as you continue assembly and painting, either masking it, or painting the helmet separately and then installing the glass, or whatever you may come up with.
Best regards,
Brad
