OK, so I know it's been awhile but it took a lot longer to strip the paint job I did as a kid. I got it to where it's as good as it's going to get. I've been slowly working on the cockpit. Here's the stock kit part:
Not very accurate to what you see in the movie. I'm not going to 100% accuracy, but anything would be better than this. I cut down the spare instrument panel from my Revell A-6E that I just finished and grafted it on. I also removed the "seat" and will be replacing it with what I think is a WWII aircraft seat, but I couldn't tell you what kit it came from. It was just floating around in a spares box. Here's where I am right now:
I filled in the spaces with Perfect Plastic Putty and it looks a lot better. You can also see the seat I'm going to be using. I need to check some reference pictures for the side consoles to figure out what I'm going to do there. I still need to tackle the area behind the seat, scratch-build a targeting computer, and then hit the front panel.
I didn't take a picture of this, but I cut open a panel on the bottom of the ship, and plan on opening up a panel behind one of the proton torpedo launchers and build that. I'm also going to have one of the engines exposed, and open up the nose. I want to get more ambitious, but I don't think it would be good for me . After all, there's still the rest of the diorama to build.
