Black light, incandescent light: shadowbox question.
Posted by djrost_2000 on Thursday, March 25, 2004 9:05 PM
I'm in the middle of dreaming up and planning a space scene shadowbox.
I would like to use black light to make flourescent paint on certain areas of the starships to glow. But I also want to have a small incandescent light shining to represent the rays of a nearby star.
Does anyone know if incandescent light will cancel out black light completely, thus ruining the glowing effect on the flourescent paint? Or will you still get some benefit from the black light even with the incandescent light going?
Thanks,
DJ
    November 2003
Posted by roosterfish on Friday, March 26, 2004 1:31 AM
I seem to remember that black light is cancelled by incandescent light. It depends on how bright the incandescent light is. In other words black light works best in completely dark rooms.
Winners never quit; quitters never win.
    July 2003
Posted by Kugai on Monday, April 19, 2004 3:41 PM
I've built a few Trek kits with the same idea in mind for photography ( no opportunities yet ti get the pix, though ). Use a fluorescent tube-type blacklight to bring out the glow you want. The bulb-type blacklights won't work well at all.
From there, use only the slightest bit of incandescent lighting for the rest of the shadowbox to keep theglow of the fluorescent colors from being washed out. you may have to resort to small Christmas lights.
Good luck!Big Smile [:D]
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    March 2004
Posted by uilleann on Monday, April 19, 2004 3:52 PM
Kugai's got it.
We used to have an exibit on display here at the local planetarium which used several kit-bashed starship models we had built and photographed for our production of a show called "Star Pioners".
For the display, we used two of those "black light" tubes on either side of the viewing window (baffled so the tubes wouldn't be seen when looking into the diorama of course) and then two very dimly lit incandecents which were on a dimmer switch. They were just faint enough to show the surface detail and the black light tubes were on full intensity. The whole display was roughly 5' wide, 4' tall and maybe 3-4' deep - pretty large.
The effect was pretty cool though.
Bri~
"I may not fly with the eagles.....but weasels don't get sucked into jet engines!"
Posted by cmtaylor on Monday, April 19, 2004 4:41 PM
Might I suggest UV LEDs for the black light and white LEDs, channelled via optical fibres instead of the incandescent?
Gentlemen! You can't fight in here; this is the WAR ROOM!
    November 2003
Posted by roosterfish on Monday, April 19, 2004 7:31 PM
How does a UV LED look in comparison to the classic light? I'm sure the LED wouldn't have as much light output, right? Do colors glow with an UV LED like they do the traditional light?
Posted by djrost_2000 on Wednesday, April 21, 2004 2:04 AM
Thanks for the replies everyone. I'll probably be starting this project in mid-summer and I'll try to post info and photos as I go along.
Dave
