Yes, its another anti-gravity build, yet again. This build went together rather easy. I started off with the IDF Nagmachon APC kit from Hobbyboss, that I received as a reward for the ‘Random Award’ in November 2017. I then converted the kit into a hover unit using the kits original parts only, making up about 98% of the bulk of the vehicle. The only scratch build parts and foreign items used in this built, was the rear panel, with the rounded exhausts mounted on; a few white styrene here and there, and empty astma canisters used for the four engines. The weaponry were modified and extra parts added to give them a distinctive look from my box of ‘Misc’ model parts from other kits I have collected over the years. The name ‘Walrus’ was given due to the shape and size of the overall look of the vehicle.
Charles King ----------------------- You may think you know...but you don't
Thanks,
John
keavdog That’s a cool subject. I don't know the genre but sure looks like an AFV to me. Nice job on the dry brushing/highlights. Overall very cool looking. With the progression of armor in the 20th and 21st centuries tending towards reduced silhouettes - what's the story with this vehicle?
Hi John. I am just letting my imagination run wild here. As I mentioned in the original post, I used the IDF APC kit and just rearranged the parts in the kit to come up with this design. It's basically a revised updated version of the IDF APC nagmachon vehicle. I simply made it into an anti-gravity recon military vehicle.
Oh wow! Love it!!!
When I look carefully I can see where you've moved stuff around!
Gamera Oh wow! Love it!!! When I look carefully I can see where you've moved stuff around!
Glad you noticed.
Very nice, Tiking. That looks really cool and your work is excellent. I like the concept too!
Bakster Very nice, Tiking. That looks really cool and your work is excellent. I like the concept too!
Thank to you kindly Bakster.
I really like the composition of this one.
Anyone with a good car don't need to be justified - Hazel Motes
Since nobody has said this yet about the Walrus..."Coo Coo Ca Chuu" The Beatles guys will get it.
Actually, you did a very good job on this vehicle. I'm just not familiar with the design or its original beginnings.
SprueOne I really like the composition of this one.
Thank you buddy. Appreciate your input.
ikar01 Since nobody has said this yet about the Walrus..."Coo Coo Ca Chuu" The Beatles guys will get it. Actually, you did a very good job on this vehicle. I'm just not familiar with the design or its original beginnings.
Hi. The only familiarity is the fact, that I used the IDF APC Nagmachon kit as the starting point for this build. It is basically an Israel's apc tank turned into an Anti-Gravity military vehicle. :)
Love it Charles
Excellent paint and weathering, would look great hovering beside a moisture vaporator on tatooine...lol
SMA members are scattered to the winds it seems...
Cheers
Bruce Coy
Belugawrx Love it Charles Excellent paint and weathering, would look great hovering beside a moisture vaporator on tatooine...lol SMA members are scattered to the winds it seems... Cheers
Yep, it sure would. :) Thanks.
