MPC Space: 1999 Moonbase Alpha - Flimsy Base Construction
    April 2015
Posted by Mark Lookabaugh on Tuesday, March 19, 2019 1:27 PM
I'm starting the recent re-release of the MPC Space: 1999 Moonbase Alpha kit. This is the version with the base reworked to more accurately show the detail, and with the spot for the enlarged base cutaway section removed.
The four plastic sections that form the base are vacuformed, and quite flimsy.  I superglued them together as accurately as I could, but there are seams to fill.  The plastic flops around quite a bit.  I'm going to glue it to a board, but even still I'm worried that it might be problematic to work with as I do the detailing and construction on top of it.
I was considering filling in the underside of the base sections with "Model Light" balsa filler, or some other light substance to make it a bit more secure.  Was just curious if anyone here has built this kit before, and what your experience was with this.  Was it a problem for you, and if so, how did you handle it?
Thank you!
Mark
    May 2011
Posted by Real G on Tuesday, March 19, 2019 3:38 PM
I'm not sure if this is helpful, but for my Modelkasten Oskar that had a big vac-formed hull, I cut thin strips of paper towels (yes you read that right) and glued them inside, much like fiberglassing a boat hull.  The paper towel strips were laid in place with thick CA, pressed down to conform to the hull contours, then carefully saturated with thin CA.  I gassed myself when I got impatient with the CA accelerator and melted a thin spot in the vac hull due to the reaction heat.  But it did result in a light, super strong shell that has held up very well.  If you do go this route, I would suggest doing it before you cut the panels from the backing sheet.
https://flic.kr/p/9UnkTn] [/url]Oskar 1 by N.T. Izumi, on Flickr
One modification you could do is lay sprue or similar like rebar in concrete, in combination with the CA/paper towels.
HTH
“Ya ya ya, unicorn papoi!”
    April 2015
Posted by Mark Lookabaugh on Tuesday, March 19, 2019 7:55 PM
That's a great idea!  Thanks for the info!
    January 2005
Posted by Watchmann on Wednesday, March 20, 2019 9:10 PM
Hi Mark,
Has this version of the base been accurized?  I remember the original release and the 1999 repop were missing a launch pad, and some of the buildings or travel tubs were inaccurate.
    April 2015
Posted by Mark Lookabaugh on Thursday, March 21, 2019 12:12 PM
Yes, this version was updated with fixes for the original release.
    January 2005
Posted by Watchmann on Thursday, March 21, 2019 6:15 PM
Oh, that's nice.  I have the 1999 repop, so the base is in two pieces.  I was planning to make mine more accurate, so I'll have to scratch a new base.
    April 2015
Posted by Mark Lookabaugh on Friday, March 22, 2019 7:29 PM
Real G,
Your suggestion worked brilliantly!  Definitely going to keep it in mind in the future.  It's super easy to do, too.
My hobby shop had some glass fibre cloth, which I cut into strips and then covered with a layer of CA.  One layer gave me enough strength, but the great part about this method is you can do it as many times as necessary.  In hindsight, I probably shouldn't have spent the extra money on the glass fibre cloth, as paper towels would have done the job just as well.
If there is a "trick", I guess I would just recommend not "soaking" the strips too much.  There were a few places where the CA didn't have enough material to bond with, and still hadn't dried 24 hours later.  I spread a bit of baking soda around on it, and it hardened instantly.
Anyway... Now that I have a solid base to work from, the rest of Moonbase Alpha should be much more enjoyable to work on.
Incidentally, I've decided to mount this effort vertically on the wall, since it's 18" x 18".  I absolutely don't have that much horizontal space anywhere, but I can probably negotiate with the wife for a section of wall out of the way somewhere.  ;-)
Thanks again for the assist.
Mark
    May 2011
Posted by Real G on Friday, March 22, 2019 8:03 PM
Mark,
That is awesome, I'm super jazzed that it worked well!  I also had excess CA glue pooling and not hardening.  And that is why I tried to hurry things along with accelerator and ended up with a melted spot in the hull!  And yes, paper towels work just as well as fiberglass, so long as you get full saturation.
The wall plaque idea is brilliant - I was wondering if the 1/350 K'tinga would also make a nice wall decoration!  You know, with a Klingon insignia base and halo lighitng...
Please post pictures of your progress!
Posted by CapnMac82 on Saturday, March 23, 2019 7:42 PM
My prefered medium was landscaping plaster and plaster cloth.
Trickiest part is finding some soft foam to hold the base inverted, and level.
I would bury a machine screw with a fat washer before (mostly o_O) pouring the filler, which helped for "dead certain" mounting on a base (the base gets a caouter bore, the screwes get a nut and washer , then the screws cut to suit).
My 2¢, spend it as you will.
