Nitto PKA Ausf G "Gustav" (Maschinen Krieger)
    September 2006
Posted by the Baron on Sunday, April 7, 2019 9:06 PM
Hi, all!
Just a post to prove that yes, I do occasionally finish a build, too.  Here is my latest, Nitto's old Gustav kit.
I started this three weekends ago, to have something for our MaK display at MFCA.  I took it to MosquitoCon, too.
Kit is pretty much out-of-the-box.  I made some minor modifications:
  • I gave the pilot earphones, made from Apoxie Sculpt, wire, and bits of Plastruct tubing.
  • I added a bulkhead to separate the cockpit and engine compartment.  Otherwise, it's a clear view straight through
  • I put an additional cushion on the seat back, also a bit of Apoxie Sculpt.  Of course, it's not visible now
  • I replaced the kit hose springs with fine beading wire, because I couldn't get the springs to fit properly into the cups on the legs
  • I added joint covers and weld beads with Apoxie Sculpt
  • I added the whip antenna from glass filament and fine beading wire for the spring base
Goal was to finish the build, so I kept the color scheme simple, too.  Tamiya flat acrylics, Green blotches over Medium Blue base.
I primed with Army Painter matte black, intending to scuff the finish colors down to the black primer.  But I must have put the finish colors on too thick, because it hardly scuffed.  I wound up using flat black to depict chipping.
I wanted to depict the suit in active motion, following my interpretation of the suits as working like Robert Heinlein's powered suits, not plodding suits of armor.  I think it came out pretty well, but I also learned some things about posing a model in motion, that I will apply to future builds.
For an old kit, it's not bad.  I didn't run across any major fit issues.  I was disappointed to find that the really cool machine pistol gets hidden behind the seat back, once everything is closed up.  If I hadn't already closed off the engine compartment, I would have fit the machine pistol bulked in that place instead, so you could see it.
Kit decals were still good, too.  Though, they needed really hot water to get them to lift off the backing paper.  With warm water, it was almost 10 minutes till they came off.
The base is a piece of foam insulation, carved to a rough terrain, covered with wood paste, with some fine gravel, and painted in tans and browns.  The clumps of scraggly grass are made from twine.
It was fun to start a kit and finish it in a couple of weeks, instead of starting and then putting it aside.  This gives me motivation to jumpstart another build, a diorama using the recent AFS kit that came out a couple of years ago.
Comments and criticisms are welcome, and thanks for looking!
Best regards,
Brad
    September 2006
Posted by the Baron on Sunday, April 7, 2019 9:09 PM
A followup since showing this at MosquitoCon yesterday:  I'm going to re-base this, and replace the foam base with one made from epoxy putty.  I can make the base thinner, and I will drill down into the pedestal.  That way, I can support the figure more properly in the running pose, with the left foot in the air, not touching the ground.  My goal is to finish re-basing it by our Lehigh Valley Scale Modelers Club meeting Wednesday evening, and then on to MFCA next weekend.
    May 2011
Posted by Real G on Monday, April 8, 2019 1:07 AM
Wow, that SDR dude is really booking!
Someone did a video short showing an SAFS running through open ground, and I immediately thought of Youtube click bait proclaiming “Guy in an armored suit runs and trips on a tree stump - see what happens next!”  These things weigh around half a ton, so I can’t help but wonder how agile they’d be.
The Gustav is probably the best looking of the Strahl PKAs, IMHO.  Good to see a MaK model on the forum!
“Ya ya ya, unicorn papoi!”
Posted by Gamera on Monday, April 8, 2019 11:33 AM
Yeah, very cool! Love the in-action look!!!
    September 2006
Posted by the Baron on Monday, April 8, 2019 2:02 PM
Thanks, Real G and Gamera!  I'm glad you like this.
When I first got interested in Maschinen Krieger, and saw the suits, my thoughts went to the powered suits in Heinlein's "Starship Troopers".  I remembered, too, a show that was on The History Channel, that looked at arms and armor through the ages.  One episode dealt with the late medieval man-at-arms and his armor.  While the armor was heavy in itself, when distributed over his whole body, it didn't inhibit his agility or motion in combat.
I think the suits amplify and enhance the pilot's movements, as well as provide protection in combat.  Good weapons should increase, not decrease, the odds of a soldier's survival.
Posted by CapnMac82 on Friday, April 12, 2019 11:11 PM
Don't discount machine agility just due to mass.
Boston Dynamics regularly is building autonomous machines in the quarter ton range that are as agile as an equivalently sized quadraped.
If we ever cut the Gordian Knot of a power supply for mecha, they will only be slow on purpose, not for lack of agility.
    September 2006
Posted by the Baron on Friday, April 26, 2019 8:31 PM
CapnMac82
Thanks, Cap'n, but my point is really more about the common interpretation of the MaK artistic design, than about true mechanics.  That is, most modelers finish their suits in static poses, or if they're depicted in motion, it's plodding.  And the series creator, Japanese graphic artist Kow Yokoyama, has produced illustrations of suits that are truly bulky and look like they'd plod along.
When I was introduced to the series, my thoughts went to Heinlein, and to David Drake's "Hammer's Slammers", and the notion of powered armor suits that enhance the soldier's own body, amplify his motions, and make him more effective.
So I don't like to pose my suits just standing around with both feet planted, looking off somewhere.  I like them to be more agile.  Here's an earlier figure I built and mounted on a base, an Armored Fighting Suit AFS Mk I, to illustrate what I mean:
I borrowed a little from Drake with the AFS, too.  In the MaK canon, there is the SDR, which is the totalitarian power trying to defeat the colonists on Earth and their mercenaries.  The AFS was developed by the mercs.  I've made him a member of a Sikh Battalion.  Kow didn't write anything like that in his stories, but Drake did.  In the Hammerverse, different planets were colonized by national organizations-the Dutch settled Hammer's home planet, for example-and some military units are made up from smaller national or ethnic groups.  The Sikhs are renowned for their warrior prowess, so I thought, why not a Sikh Battalion serving with the mercs.  I need to get decals made up for the unit signs, though.
    September 2006
Posted by the Baron on Friday, April 26, 2019 8:53 PM
I took this to MosquitoCon, and then to the MFCA show the following week.  In between, I replaced the foam groundwork:
with a thinner base made of Aves Apoxie Sculpt:
I also anchored the figure more securely into the pedestal.  With the terrain fitted more closely to the right foot and the suit anchored better, I got the pose I wanted, with the left foot in the air, in mid-stride.  For this kind of application, I think putty will be my first choice for the groundwork material.
