My 1/32 Round 2 Star Trek Galileo 7 build.
    December 2013
Posted by Jim Kirk on Wednesday, August 19, 2020 10:23 AM
So let’s try this again... the Round 2 1/32 Galileo 7 .
I reserve the evenings for "me" Build time, so I worked on this.
The roof slides off so I can add lights...or an Interior kit from Polar Lights if they make it.
The lighted areas will be the rear engine and interior cabin.
I painted the model to match the color suggestions on the box and reference material.
The paint was Tamiya, I mixed them.
Even though the hatch is closed in the photo, the lower area swings down and the top is removable. It's tacked in place right now until the decals fully cure.
The viewport "glasss" In not in place yet. I may display the model with the windows closed.
    April 2015
Posted by Mark Lookabaugh on Wednesday, August 19, 2020 11:03 AM
It's amazingly perfect!
    March 2010
Posted by mach71 on Wednesday, August 19, 2020 1:24 PM
Looks great!
    December 2013
Posted by Jim Kirk on Wednesday, August 19, 2020 3:35 PM
Took a 15 minute break from the bench to get some decent, but boring, Pictures of my 1/32 Polar Lights Galileo build.
    December 2013
Posted by Jim Kirk on Friday, August 21, 2020 1:29 PM
Many thanks to
Gary Kerr
in getting the color correct!!
Although it wasn’t exactly easy, the upper and lower hull colors HAD to be mixed then lightened a little for correct scale.
If you want it like the 22’ prop, you can’t get the colors from a rattle can.
The weather has been downcast and rainy, so I took some quick pictures with the sunlight.
    December 2013
Posted by Jim Kirk on Friday, August 21, 2020 4:44 PM
    March 2010
Posted by mach71 on Friday, August 21, 2020 7:21 PM
Nice video!
I've always used Tamiya Insignia White for the top and Tamiya fine grey primer on the bottom. I guess I was wrong.
Can you share the paint mixing recipe?
Also did you put 1 LED in the impulse motor or 2?
Thanks
    December 2013
Posted by Jim Kirk on Saturday, August 22, 2020 8:14 AM
mach71
Nice video!
Thanks
The formula is in the description of the video...But Here it is again! All Model Master paints!!
Upper Hull 75% #1730 Flat Gull Gray 25% #1726 Lt Sea Gray Lower Hull 70% #1794 Aggressor Gray 20% #1788 Euro 1 Gray 10% #1735 Wood Don't forget to lighten the mixes slightly for scale(This is a model not the 22' Prop!)
    December 2013
Posted by Jim Kirk on Saturday, August 22, 2020 3:44 PM
Now that the dull usual tabletop pictures/videos are out of the way...a little fun!!
    March 2010
Posted by mach71 on Saturday, August 22, 2020 5:26 PM
Jim Kirk
Thanks! Thats what I need.
Those colors seem like they would be too dark, But I can't argue with the results you got!
Your build looks spot on!
Those are mostly flat paints. Can I assume you gloss coated before decals? And then Semi matt coated to seal everything after?
Sorry if this was covered before.
Thanks very much.
Mark
    May 2011
Posted by Real G on Saturday, August 22, 2020 6:12 PM
I’m going to reveal my ignorance of TOS minutiae, but what are the shuttle nacelles supposed to be?  Are they warp nacelles, since the impulse engine is apparently the big grille in the back of the hull?  Or am I being like that kid in Galaxy Quest asking Tim Allen’s character about some discrepancy in the show?
“Ya ya ya, unicorn papoi!”
    December 2013
Posted by Jim Kirk on Sunday, August 23, 2020 12:03 PM
    April 2009
Posted by Cadet Chuck on Monday, August 24, 2020 12:43 PM
I appreciate the paint mix data.  The kit gives little or no info on this.  Thanks!
    December 2013
Posted by Jim Kirk on Monday, August 24, 2020 12:52 PM
Cadet Chuck
You bet! Glad to have helped!
    December 2013
Posted by Jim Kirk on Monday, August 24, 2020 12:53 PM
Another shot of the kit!
    April 2009
Posted by Cadet Chuck on Monday, August 24, 2020 1:18 PM
Looks like most of those colors are no longer available, but I can punt.  Your photos are a big help.
Are the nacelles the same as the bottom hull, or are they a bit lighter, somewhere inbetween the upper hull and lower hull colors?
    December 2013
Posted by Jim Kirk on Monday, August 24, 2020 5:29 PM
Cadet Chuck
The whole lower hull...nacells included, are the same color!
Posted by Gamera on Monday, August 24, 2020 6:36 PM
Another great job!!! Heart
Posted by Gamera on Monday, August 24, 2020 6:38 PM
Real G
Considering they look like warp nacelles I'd always assumed shuttles had some sort of limited low-warp capability but I think they are assumed to be sub-light only.
    March 2010
Posted by mach71 on Wednesday, August 26, 2020 10:23 AM
Real G
Sorry it took so long Real G,
That's up for discussion.
An argument can be made that 2 "warp" engines (pods) are needed to go FTL.
Every FTL ship we see in TOS has 2 warp engines.
The shuttlecraft, by strong sugestion, has a limited warp capability.
This would indicate logically, that the 2 pods are warp engines.
But they are small and the black grill on the back is large, and it's obviously some kind of drive.
In "The Galileo Seven" you see Spock Jettison the fuel and ignite it. The ignited fuel is shown coming from the pods. The comment is made that "they need that fuel to maintain orbit". Impulse engines are use for orbit and sub light manuvering.
Confusing.
The Starfleet tech manual lists them as "booster pods" with the center engine listed as "main propulsion".
The Tech manual is not completly accurate to the show.
So, after a long post the answer is maybe.
    February 2015
Posted by InternationalRescue on Saturday, September 5, 2020 3:39 PM
Great job!  Just picked one up from my local hobby store and can't wait to build it.
Posted by CapnMac82 on Saturday, September 5, 2020 4:11 PM
TOS (The Original Series) canon was that the warp nacelles created a warp field of varying intensity.  The Impulse engines than provided thrust to move you places.
So, fan-based canon is that the shuttles can generate warp fields, and the pulse engines get them from place to place.  (Which allows them to travel great distances to advance plot lines.)  The Shuttles are also SSTO (Single Stage To Orbit) vehicles, so they need large Impulse engines to achieve that sort of manoverability.  (Which also advances plot lines.)
The the various series, they honor that canon, by having ever larger impulse engines on major space craft.  And the Shuttles all are capable of long range travel, leter to include enough power to support Transporters.
TOS is imprecise about whether Shuttles are armed or nt (they are in later series as a matter of course).
As an interesting bit of trivia, the prop was ot available until Episode 5 of TOS, which is why they inveted the Transporter.
    December 2013
Posted by Jim Kirk on Monday, September 7, 2020 1:55 PM
A quick diorama build until my other one is 100% finished.
