Zvesda 1/2700 Star Destroyer with custom lighting
    October 2021
Posted by PhoenixG on Friday, February 11, 2022 3:17 PM
JimC2020
Pretty easy. The Arduino IDE works great in terms of seamlessly uploading your compiled code to the actual Arduino hardware. The IDE is simple, but then again the programming is crazy complex either, so it's OK.
Can't argue with that. Arduino's are geat little devices.
Had some fun once coding up a homemade laser tag set.  Complete with Ammo count, Health bars, and sound effects.  Kids had fun with that but discovered TV IR remotes were like nukes and could aim practically anywhere in the room and get a hit.  Big Smile
Your build is going to look awesome when completed!
On the Bench:
Bandai Starblazers 2202 Garmillas Zoellugut
    February 2021
Posted by JimC2020 on Monday, February 14, 2022 8:41 PM
More progress... bottom half and engines all wired up and hooked into the circuit boards. Yikes, no turning back now...
    March 2004
Posted by Mikeym_us on Tuesday, February 15, 2022 9:42 PM
Ok I do believe the little engines are not supposed to be on when the mains are on. They were not lit on the original filming model. Good probability those engines are for light speed not really sure unless someone has the schematics laying around for Star Destroyers?
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    February 2021
Posted by JimC2020 on Thursday, April 14, 2022 3:59 PM
Thanks for the info, sorry for the long delay. Finally solved the remaing electronics isues (hopefully all of them now), and made some more progress. The bluetooth controller is now sorted out, so I'll be able to control various bits, including the start up of the light speed engines vs the sublight. Not sure if the big ones are lightspeed or sublight, will have to look that up.
    February 2021
Posted by JimC2020 on Thursday, April 14, 2022 4:20 PM
Ok finally some more progress, battery supplies hopefully sorted. Assuming I did this right I'll be powering this with ~12v ~2.2A, with a battery pack of 3 18650 cells, and if I attach it all up correctly hopefully it won't burn down my apartment!
So this showing the separate battery cell holders, spaced individually instead of all together to allow everything to fit.
the Battery Management System, this makes sure the battery drain is kept even and handles the logic to properly recharge them as well.
Little on board voltage meter, press the button and it will show the battery voltage, to see when it needs charging.
component placement
and after mounting and wiring up for good:
The Bluetooth controller lives!
Test rig for the bluetooth controller,
wired up for real
It talks to this program (test app on my MacBook that will then get ported  to iOS for usage on iphone):
And when the two are connected the controller outputs this on windows (when the arduino is connected via USB):
Arduino pro mini mount:
Not done yet, just have the power/gnd leads in place
Audio board to place sounds and imperial march
That's all done now, it will be connected to above arduino board.
There's one other little component, there's a special blue LED that drives 5-6 fiber optic cables in the top front area, that will blink when the Bluetooth control is not paired with the app, and then go solid when a connection is succesfully made.
All the programming is basically done, it's basically down mounting up the electronics and praying that I solder things correctly. Hopefully a couple more weeks and this thing will finally be done.
Posted by Gamera on Friday, April 15, 2022 9:58 AM
Oh wow that's amazing!!!
I've lighted up a few kits years ago with fiber optic cable and bits and bobs from Radio Shack but nothing like this. That's insane all the cool stuff you've got there!
Really looking forward to seeing her all lighted up like the proverbial Christmas tree!!!
    February 2021
Posted by JimC2020 on Friday, April 15, 2022 12:45 PM
Thanks, this is crazy what this has morped into, next time I'll plan better. Omg the budget for this! Insane...
Bluetooth model in place! The blinking lights mean it's looking for a connection, it will go solid once it's properly paired with my app.
Pro mini board now wired in place, with wires for the usb connector to upload code. Those are just temporary and will be removed prior to final mounting.
Left side is the HM-10 bluetooth module mounted in place now.
    October 2021
Posted by PhoenixG on Friday, April 15, 2022 9:57 PM
THAT IS
Can't wait to see the finished product!
On the Bench:
Posted by Gamera on Sunday, April 17, 2022 9:34 PM
That is sooooooooooo cool!
    February 2021
Posted by JimC2020 on Wednesday, April 20, 2022 12:28 PM
Batteries in place!!!
So far nothing has burned or melted!
Voltage meter works...
steady at 11.9 volts, basically matches what the multimeter reads.
Custom power on/off switch that I added
Works!
Brains all wired up
From left to right,
1) The main Arduino pro mini, handles all the lights, bluetooth, and primary audio
2) primary audio chip, reads from sd card
3) Secondary Arduino pro mini, handles secondary audio for sound effects during the power on stages, engine sounds, etc.
This gives me multiple layers of sound, overkill, but the actual hardware is pretty cheap.
LED Lights mounted in place on top half
very close to being done, maybe even this weekend...
    February 2021
Posted by JimC2020 on Wednesday, April 20, 2022 1:44 PM
Audio test, running on internal power!!
Posted by Gamera on Friday, April 22, 2022 9:36 AM
Oh wow you'd almost have to be a real starship engineer to get all this wired up, great job!
It looks so cool!
    February 2021
Posted by JimC2020 on Saturday, May 14, 2022 12:51 PM
Sealed up the model yesterday! No more fiddling with internals now.
So much stuff inside, next time smaller wires!!!
Quickie walk around. The audio is being played via the secondary audio circuit.
    August 2021
Posted by lurch on Sunday, May 15, 2022 4:36 AM
This thing has enough wiring for a real starship. Pretty impressive to me. Not sure if I could do that. How much is the electronics costing for this project? Looks very expensive to me.
    July 2014
Posted by Bakster on Sunday, May 15, 2022 10:35 AM
What a massive project. All the wiring and fiberoptic makes my head spin. Congrats on this milestone. It has to feel good reaching the point of closing it up. Can't wait to see this baby lit up.
Posted by keavdog on Sunday, May 15, 2022 10:48 AM
Fantastic!  What a project you have going here.
Thanks,
John
    February 2021
Posted by JimC2020 on Monday, May 16, 2022 11:53 AM
Thanks guys,
For the electronics I'd guess the actual components probably around $50-60? The battery cells were $23. I had to go from nothing (I'd never done electronics before this) to all sorts of components, transistors, capacitors, resistors, different IC chips, soldering iron workstation, etc. If I were to add all that stuff up, I'd probably choke in embarassment! The colored leds were a little more expensive since they are the individually addressable ones, which cost a bit more, but makes the electronics circuit a lot easier and less hassle to deal with.
    August 2021
Posted by lurch on Tuesday, May 17, 2022 8:44 AM
Its going to be very impressive whenyou get it done.
Posted by Gamera on Thursday, May 19, 2022 6:49 PM
Again, that's sooooooooo friggin' cool!!!
    February 2022
Posted by SplatterMan on Saturday, May 21, 2022 12:44 AM
This is amazing. Going from never having lit a model to a whole star destroyer; talk about trial by fire. Hats off to you! I'd be curious to know how long all that fibre and wire would be if you put it all end to end.
    February 2021
Posted by JimC2020 on Monday, January 9, 2023 10:36 AM
Damn long time.... got burned out, but finally made some progress. Got sound files mostly done, but when testing them, found out one of hte LED's stopped working and ended up redoing the wiring and taking apart the model to track it down.
Posted by Gamera on Monday, January 9, 2023 7:05 PM
Oh wow, I'd pull out what's left of my hair trying to get all that straight!!!
    August 2007
Posted by DUSTER on Tuesday, January 10, 2023 11:18 PM
  Great job.
Steve
Posted by keavdog on Wednesday, January 11, 2023 9:24 AM
Great to see you back on this.  Amazing project!
Thanks,
John
    February 2021
Posted by JimC2020 on Wednesday, January 11, 2023 9:31 AM
Gamera
LOL once I realized what I needed to do I definitely cursed a bit :) And once I realized that one of the LED's was broken and needed to be replaced, I was *really* annoyed! That meant separating the two halves of the hull, which had already been glued together. But luckily they split apart really easily and no plastic was broken.
    February 2021
Posted by JimC2020 on Saturday, January 14, 2023 3:10 PM
OK so hopefully everything but gluing the two hull pieces back together gets done this weekend.
Working on testing the communications between the two arduino pro mini's. One drives the audio for the fx, like the startup sounds, and the other drives the background music like the imperial march. Currently I've got both powered up and audio running together.
Posted by keavdog on Saturday, January 14, 2023 3:22 PM
Fantastic!  Appreciate the soundtrack as well :)
Thanks,
John
    March 2007
Posted by armornut on Saturday, January 14, 2023 7:20 PM
   Love how the engines fire up freaking COOL.
we're modelers it's what we do
    February 2021
Posted by JimC2020 on Monday, January 16, 2023 1:27 AM
Finally after a frustrating 2 days to debugging arduino code, I think I can say all the electronics are done, the two arduino mcu's are talking to each other and both audio devices can play succesfully. I need to re-test the blue tooth controller, and then I can start figuring out how to pack all this crazy crap back together again.
    February 2021
Posted by JimC2020 on Monday, January 16, 2023 1:30 AM
Do you think there would be any interest in me making a youtube video with all the WIP shot and voice over explaining what I did?
