PhoenixG
I've been meaning to ask. How exactly did you leverage the four colors of aluminum?
To be honest it looks like there are more shades than that present.
It's been fun trying to guess but if you don't mind sharing I'm all ears. :)
First I built sub-assemblies, the guns, engines, upper and lower halves of the fuselage and each wing. Each sub-assembly received a base coat of Mr Color Gloss Black. This paint cures to a good hard finish.
Second, the fuselage halves and wings were sprayed AK Polished Aluminum. I let this cure over night then shot it with Tamiya Gloss Clear. The guns and engines received different colors of AK Metallic. The AK Metallics were just misted (more air than paint) on over the gloss black primer. The pressure was set to 9/10 psi. I used my Sotar 20/20 for the paint on this build.
Third, I did a lot of masking. I just masked different areas for different colors of AK metallic, whatever seemed right. Not a lot of planning for the masking, just some "yeah, this will look good." The recesses between the wings are Tamiya Neutral Gray.
Fourth, I put the Invasion Stripes where I felt they fit best. Each stripe is 4mm wide. I sprayed the white first then masked for the black.
After all the painting and masking and more painting, each sub-assembly was sprayed with Tamiya Gloss Clear and left to cure overnight. The next day everything was snapped (glued) together. I think the whole build took me a week.
I'd like to find an A-Wing and a B-Wing so they can get a similar treatment.
Oh yeah, I started with the lightest shade of AK Metallic then moved to progressively darker shades.
