LIS Chariot 1:35
Posted by CapnMac82 on Friday, December 15, 2023 11:58 AM
Plexiglass wants low RPM for cutters.  Which is complicated not matter which cutter is used.
    July 2014
Posted by Bakster on Sunday, December 17, 2023 11:39 PM
I got a few hours of work today:
1. The second armhole is opened up.
2. The foam gasket is installed. The foam I purchased is perfect for the job.
3.  Holes are drilled for the top portion of the hinges. The hinges I went with are not all that great. I was forced into getting those because I need clearance for the hardware. The top half of the booth has an odd bend to it and as a result, the hexnuts must fit into a tight area. Fortunately, the hardware fit, but only by the skin of its teeth. It could not get any tighter.
4. The booth has gaps here and there and this simple fact helped to run the led light cord out of the booth.  I at first thought I might need to drill a hole into a side panel. Using a gap eliminated a host of throuble. But... as good as that is... I must still feed the plug and switch through. I was thinking I might need to cut the cord and reattach when a simple solution presented itself. This booth it put together with nuts and screws. All I need to do is disassemble the top panel. In the end, I only needed to unscrew one half of the panel.
Below: You can see that foam is used to fill a gap. And you can see that this is the gap I ran the cord through.
The door is mounted. I guess... if there is a plus to the crummy hinges, it is that the door can easily be removed... if needs be.
More work to do like mount the sleeve holders and sleeves, to drill a hole for the airbrush hose, and to make some sort of mechanism allowing for securing the door shut.
Should not be too much longer now.
Posted by Gamera on Monday, December 18, 2023 8:10 PM
That looks great Bakster! Looks like you're almost there now!!!
It's in better shape than my Christmas decorations at least. Clapper and his cousin showed up and wrecked the place! Even my screaming 'GET OFF MY LAWN, YOU DAMN PUNKS!!!' didn't get them to leave...
Posted by Gamera on Monday, December 18, 2023 8:15 PM
'I'm not letting you in Clapper! I know it's you no matter how much you disguise yourself!!!'
    July 2014
Posted by Bakster on Tuesday, December 19, 2023 2:49 PM
Yes, almost done for sure. By Friday, should be good to go, if not sooner.
Lol.  You just keep Clapper over there. He might make a mess of my new booth. Or hey... here is an idea. Send Clapper to Capns yard. It is a target rich environment. Wink
Sorry, Capn. We need to share the pain. Hehe.
    July 2014
Posted by Bakster on Tuesday, December 19, 2023 2:55 PM
Gamera
Lol.
He is a devious one. The other day, pretty sure it was Clapper, he was ringing the bell for the Salvation Army. I ran the other way.
Posted by CapnMac82 on Wednesday, December 20, 2023 12:18 PM
Bakster
Send Clapper to Capns yard. It is a target rich environment. Wink Sorry, Capn. We need to share the pain. Hehe.
Clapper will have to get past the guard-puppy, Jill:
Who is quite formidiable and opposed to all burglars, squireels, and the like, and is determined to keep all tigers away as well.
    July 2014
Posted by Bakster on Wednesday, December 20, 2023 3:01 PM
CapnMac82
Bakster
I was wondering what you would come back with. That is a good one! Lol
Clapper is in for a rude awakening.
Posted by CapnMac82 on Friday, December 22, 2023 1:01 PM
Bakster
Yep, 45# of super-protective barking at full volume.
Now, if Clapper has a couple of paw-fulls of treats, well, Jill has the attention span pf a tween with two cell phones . . .
    July 2014
Posted by Bakster on Saturday, December 23, 2023 2:15 PM
CapnMac82
Bakster
Lol about the treats. We won't tell Clapper.
    July 2014
Posted by Bakster on Saturday, December 23, 2023 3:36 PM
Okay, this is a long and tedious post to write. Particularly, with my IPad spellchecker fighting me. Apples OS does not play well with this website. It is a SERIOUS fight. So, if you see lots of spelling and grammatical errors, Sorry Charlie. Tired of the fight but the convenience outweighs the pain.
The booth is done.
Below: I drilled a hole for the air-hose and this was not an easy task. This metal is difficult to cut through. I started small stepping up to larger bits. The final sizing was done by adding a grinding bit to my drill. I planned to use a rubber grommet for the opening but that would require taking off roughly another 1/8 of material. I don't have a drillbit that large and if I did, it probably would not fit in the chuck. I might still do it one day by grinding, but as of today, I am not up to it.
Below: When I must position the door to access the booth, I need a stop for it to rest against. And what better than to use a door stop! Hehe. You can position it for the correct angle and the rubber foot helps protect the plexiglas from getting damaged. I secured the foot using double sided tape. I try to apply these changes so as to cause the least amount of damage, keeping the changes reversible. Why? If I ever need to sell or donate the thing, it would allow me to undo my crazy. Not sure anyone would want this sort of system.
Lastly, the arm is epoxied at the precise angle I want.
Below: you can see how I constructed the hand openings. The black things are made from pipe flashing; highly modified.
https://www.homedepot.com/p/Gibraltar-Building-Products-3-in-and-4-in-Adjustable-Pipe-Flashing-with-Hard-Plastic-Base-and-Rubber-Collar-CMIHB34/100319899?source=shoppingads&locale=en-US&pla&mtc=SHOPPING-CM-CML-GGL-D22-022_010_ROOFING-NA-NA-NA-PMAX-4035567-NA-NA-NA-NBR-NA-NA-NEW-Pmax-CL3TestA&cm_mmc=SHOPPING-CM-CML-GGL-D22-022_010_ROOFING-NA-NA-NA-PMAX-4035567-NA-NA-NA-NBR-NA-NA-NEW-Pmax-CL3TestA-71700000103694446--&gad_source=1&gclsrc=ds
The assembly is epoxied to the door. The pipe clamps are epoxied to the pipe flashing. The purpose of the clamps is to provide something for the gloves to attach to.
Below: Gloves in place. As noted in another post, I cut the gloves off. I do that because they are too bulky, and keeping them clean would introduce more lint and such. Long story short, it would be more trouble than it's worth. I really only need the sleeves. The sleeves provided a loose seal around my arms and that is all I want. It allows for easy in and out. When done, I stuff the sleeves in the opening and that keeps the fumes inside.
https://www.amazon.com/gp/product/B088WXYW39/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
A happy note about the gloves. I expected I may need to glue or clamp them to the inner clamp, but the gloves come with an elastic compression. And let me tell you, they squeeze. They are not comfortable to adorn as designed. Your arms will get sore quickly, but for my purpose, it solved a problem. The elastic allows me to fit the sleeves over the clamps and it holds perfectly.
Lastly, to secure the door while in use... I purchased a set of removable hangers. I bind the door closed with rubber bands. The face of the booth is not entirely square so if I want a better seal, I need to use these.
Some last words about this booth. The ductwork exiting the blower have some major airleaks. You can feel air flowing through the joins in multiple locations. So, for my purposes, they need to be sealed. The air coming out is fumed air. So, I sealed the leaks using clear caulk.
Thus ends a chapter, Bakster takes a side trip.
I suppose this means I must start work on the Chariot again. Let's see if life will allow it. It's been turbulent.
    October 2021
Posted by PhoenixG on Sunday, December 24, 2023 11:22 PM
Wow, I've missed a lot since I was last here. So much accomplished!  Including funny stories involving clapper.  :-D
Bakster, your painting booth is a marvel.  You have a negative pressure room with seals to minimize chance of contaminated air entering the other parts of the room.  It needs to have CDC Biosafety lab level markings. LOL
All you need now is the disenfecting shower stand connected to it by a flexible tube. I hear the wash is mostly Lysol so keeping a can handy would be good enough.  ;)
CAUTION: Massive Digression ahead (yeah I know, big surprise Smile)
Bench time was challenging the past couple of weeks.  During that time I discovered Adam Savage's One Day Builds and they've been a great way to unwind.  Watching them was like reading your forum posts, but with video!  I loved his build of a garage resin kit of an AT-AT.   It's a three part video. Here's the start if your curiousity is piqued.
Adam Savage Building an AT-AT
His videos run an hour on average, but I hardly notice.
END Of Digression.
You've put a lot of effort into making the booth be what you want. Can't wait to hear how your first few airbrushing efforts go!
On the Bench:
Bandai Starblazers 2202 Garmillas Zoellugut
    July 2014
Posted by Bakster on Monday, December 25, 2023 12:03 PM
PhoenixG
Thanks and Lol...
PhoenixG
Amazing how we are going through the same thing. I have watched his builds as well. I will rewatch the AT-AT build. Time has been so scant that I live vicariously watching others build. Here are three of my favorite build channels:
Sprueverse
A light hearted channel seeking to ever improve, not claiming to be a master builder, and yet he builds fun projects to a great result. Probably my favorite channel because I learn through his mistakes and musings. Phil has grown into a talented builder.
https://www.youtube.com/@sprueVerse/videos
Aztek Dummy
Also a light hearted channel with diverse and fun builds, the models assembled by a highly talented builder. This is right up there with Phil at Sprueverse in terms of my liking.
https://www.youtube.com/@aztekdummy/videos
TrekWorks
A highly skilled and patient builder that is as masterful teaching his craft.
https://www.youtube.com/results?search_query=trekworks
PhoenixG
I am hoping that over the coming new years weekend I will give it a spin. No time right now.
    July 2014
Posted by Bakster on Monday, December 25, 2023 12:20 PM
Well-- it was inevitable. Clapper called me, COLLECT! It seems Gamera turned him out for his antics. Clapper wanted to glum off me next but I told him there is a banana shortage over here. That shut him down quickly. He mentioned Capns place next but I told him there is a ravenous dog over there that will tear him limb from limb. You are welcome, Capn.
Sorry, LittleTimmy. If you hear a clapping sound... it's probably Clapper.  He was gonna glum off you next.
Posted by Gamera on Monday, December 25, 2023 4:54 PM
That looks great Bakster! A bang-up professional job! You ought to make these and sell them!!!
And thanks for the YouTube links guys!
Just what I need something else to waste my time on YouTube instead of getting stuff done!!! Confused
Posted by Gamera on Monday, December 25, 2023 4:59 PM
I hope the captain's dog taught Clapper a lesson. Beware of him Bakster! I wouldn't trust him either!
And yes look out Timmy and Phoenix- he's probably headed your way next!!!
He told me he asked St. Nick for a truck full of bananas but it all went to pot when he peed in Santa's lap...
    July 2014
Posted by Bakster on Monday, December 25, 2023 6:11 PM
Gamera
Thanks, Gam. I guess I needed a diversion!
Hopefully, getting back to the build soon.
Posted by CapnMac82 on Tuesday, December 26, 2023 1:29 PM
Bakster
There's a wealth of great channels out there.
Max_afterburner US (the underscore is required)
His aircraft builds are very considered, seeing as how he's a maintainer for the AZ Air Nat'l Guard.
The Model Shed  UK Steve is a retired RAF maintainer who lives in the far north of England, and builds all kinds of things--often over many episoes (his 1/200 HMS Hood was 50 episodes, IIRC).  He has a following of UK and european modelers with their own channels.
Night Shift  Czrchia Martin Kovak largely builds armor in dioramas--his channel is very much focused on technique.
Laser Creation-World Germany Thomas builds elaborate models for elaborate dioramas.  The German-to-English captions occasionally will have some uh-ohs.  Decent descriptions of techniques.  His painting style is very definitely more Fine Arts than "modeler's style."  And, that "fine arts" methi=od also extends to research & depiction--it's very much the the Art School adage of "it's a painting, not a polaroid."  Also, it's pretty much the same 4 cuts of no-royalties music in every video.
    July 2014
Posted by Bakster on Tuesday, December 26, 2023 10:18 PM
CapnMac82
Bakster
Hey Capn--  I did a cursory check on your links and they look good. I will subscribe to them.
Plasmo Plastic Models
Here is another good one. His skill level is high. One can learn much from his videos.
https://www.youtube.com/@idaemonplasmo
Posted by Gamera on Wednesday, December 27, 2023 9:33 PM
Yeah those sound great Captain!
    October 2021
Posted by PhoenixG on Thursday, December 28, 2023 12:01 PM
Hope everyone had a happy holiday weekend and wish y'all a Happy upcoming New Year's!
So many interesting modeling channels to check out!  Going to have to pace myself.  If I don't, I won't get anything done at the bench!  Big Smile
On the Bench:
Posted by CapnMac82 on Thursday, December 28, 2023 12:55 PM
There are a couple of channels I watch because they only get videos out about once a month and pour clear resin in kilogram quantities.  They are also largely in Monster/horro genres, whic hmakes a nice change of pace
MiniBricks Craft, which from memory is based in Czechia, and ThalassoHobby, which is in SE Asia (with subtitles in Japanese).
I also watch Charlie Bishop's Chadwick Model Railway.  That largely becuase it brings back memories of when I wa part of a model railway club as a scenery builder.  Charlie is a former RN submariner, too.  He's a very good videographer and is committed to his craft in making videos.  Also, he's on a quest to "Be the first Pensioner with 100,000 subscribers."
    October 2021
Posted by PhoenixG on Wednesday, January 17, 2024 7:32 PM
Hey Bakster,
Happy 2024 and hope all is well.  It's been a while so thought I would give the thread a ping and see how things are going.
I've been checking out a few of the channels the group recommended.  I enjoyed a few of Aztecdummy's builds and watched Sprueverse do a resin build of the egg scene in Alien.  It turns out I've seen a few of Plasmo's builds in the past.
Such a variety of approaches to scale models.   Looking forward to trying more. My goal is view at least one video from the channels everyone shared.  :)
On the Bench:
    July 2014
Posted by Bakster on Wednesday, January 24, 2024 10:08 PM
PhoenixG
Hey Bakster,
Hey PG... so glad to hear you have watched a few. They entertain me when I am not able to build. And speaking of not building... I had to stop. Life has different ideas for my time and energy. It has been challenging. Once the onslaught subsides, I will try getting back to it.
Thanks for checking in!
    October 2021
Posted by PhoenixG on Thursday, January 25, 2024 11:47 PM
Bakster
Hey PG... so glad to hear you have watched a few. They entertain me when I am not able to build. And speaking of not building... I had to stop. Life has different ideas for my time and energy. It has been challenging. Once the onslaught subsides, I will try getting back to it. Thanks for checking in!
Thanks for sharing them.  I'm currently watching Spureverse build a Battlestar Galactica Shuttle.  I've been bad and haven't tried any of the others yet.
Understand how life has it's own plans for us.  Do the needful and take care of yourself.  Look forward to seeing more when you're once again able to return to the bench. :)
On the Bench:
Posted by CapnMac82 on Friday, January 26, 2024 12:23 PM
Bakster
We each find our own way.
Sometimes that way is neat and direct like a highway.  Sometimes it's as winding and convoluted as the path of a drunken bumblebee.
Often the best we can hope for is a cowpath with half-adequate signage.
Many here might suggest a simple OOB kit build--hey, a modeling site is going to have modeling suggestions, que suprise.  But, given how abominal your local weather has been of late, perhaps not being the basement is a good idea.
Instead, perhaps what's wanted is some very good fiction, some oustanding movies to just sit back on the couch an absorb.  Forbidden Planet.  Ice Station Zebra.  Rear Window.  The Fifth Element.  Raising Arizona.
Shoot, just get on You Tube where you can watch all four seasons of Farscape, and both of the Peacekeeper Wars which close the series out.
Posted by Gamera on Friday, January 26, 2024 11:27 PM
I hope everything is okay Bakster. No problem with stepping away from the bench for a little bit. Sometimes it helps to recharge the batteries.
    July 2014
Posted by Bakster on Sunday, February 4, 2024 8:46 PM
CapnMac82
Bakster
Hey Capn, all good advice. I am taking it slow. If all the other stuff going on was not enough, I got hit with Covid. My first go with it. Fortunately, nothing too severe. Point being... that forced me to dial it back even more.
Today, I worked on some refinements to my spray booth. I am expanding the exit point because I had it stepping down to a smaller diameter hose. I intially did that to minimize impact to my drywall, should I ever move. I know that by reducing it causes some back pressure, and since I revamped the booth, I figured, what the hey... do it right. So, I expanded the hole.
Speaking of the booth... I made another change. You might recall my saying the air draw seemed good. Well, another issue reared it's ugly head that I didn't see coming. Right out of the gates I noticed an odd electrical smell. I wrote it off as new electronic smell that will eventually go away. Well... after several tests, it didn't go away. It got worse. For the heck of it, I pulled the filter assembly and felt the fan housing. Holy cats, it was hot! You'd burn yourself if you kept holding it. THAT IS NOT GOOD! I don't need volatile vapors flowing over something that is hot. If the fan heats like that during short runs...what will happen if I run it a long time?
The question became... was I causing that with my closed system. Further testing revealed it adds to it, but even with leaving the front wide open, that fan gets hot. I thought for sure it was a bad fan so I wrote the company. They sent a replacement and what do you know, same darn thing. No improvement.
What to do. I never had this issue before using my old system. The fan I had worked fine even under the closed door load. I almost decided to just go with it, my lazy kicked in, but in the end... no...no way.
They are using a computer fan with this like many of these commercial booths. My previous fan housing was pulled off one of those portable units and they used a computer fan too. Yet, I had no heat issue. What it is about this fan that it heats up like that, I do not know.
Long story short. I found a nice fan that is closer to an exhaust fan and it even has a higher CFM. I also like that it has a variable speed control on it. Now, I can dial in air draw. I ran it for a spell and with initial testing, the fan housing gets warm at best. Not hot!
As Walter Cronkite used to say, and that's the way it is.
    July 2014
Posted by Bakster on Sunday, February 4, 2024 8:47 PM
Gamera
Thanks, Gam. Still kicking here.
Posted by Gamera on Sunday, February 4, 2024 8:53 PM
Oh wow, good to hear you're okay after being sick and the fan issues!
