Using magnets to display models
Posted by djrost_2000 on Thursday, October 7, 2004 10:13 PM
I was looking through an aviation goods catalog recently, and they offer a small aircraft model that is suspended in air by magnets. It literally floats in the air above it's base with no physical suspension system.
I'm curious as to how many have heard of suspending models this way, and even if anyone has tried it?
I wonder if larger models could be suspended by electromagnet? Of course shutting the power down suddenly could cause an impact problem.
Cheers,
Dave
Posted by cmtaylor on Friday, October 8, 2004 4:12 PM
The principle is quite simple; you have a large permanent magnet in the base and a much smaller one in the model. The idea is that the magnet in the model is positined in such a way that the repulsion between them overcomes gravity.Since the smaller magnet will not be all that powerful, relative to the large one, the the model can not be overly large thus the models displayed in this way will not usually be bigger than 1/144 fighters. Furthermore, to stop the model being flug off of the stand, it needs to be tethered by means of thin fishing lines to wingtips and tail.
Theoetically, it should be possible to use electromagnets in the base to provide a shaped magnetic field so that the model sits in a trough and does not require any form of tethering, although that's outside my field of expertise
Gentlemen! You can't fight in here; this is the WAR ROOM!
Posted by philp on Monday, October 11, 2004 4:43 PM
Revell of Germany makes several of these kits with 1/144 and 1/72nd scale planes.
Phil Peterson IPMS #8739 Join the Map http://www.frappr.com/finescalemodeler
