QUOTE: Originally posted by joewhite
What are the differences between it and the Horizon besides the resin and metal pieces and is it better than Horizons?
For one the Kit is a lot smaller, the body, lower legs and arms are still vinyl.
Guns and some of the parts on the upper legs are White metal.
The major difference are the struts on the rear of the legs, they are made from Resin(2 pieces) with a centre white metal screw/shaft.
Check the image below it looks something like that:
http://www.amazingstarships.com/starships/models/readers/davidfox/ED209C.jpg
If you want big than the Horizon is your best bet, if you want smaller and more accurate than the Argonauts can't be beat.
AFAIK, they are based on different movie models though there will be some differences in designs.
Be warned though some companies make poor all-resin copies of the argonauts kit.
HTH.
FYI, I also did their 1/4 Terminator Endoskeleton and it is the BEST kit there is of the design.
