So here's a question for all you Falcom modelers out there. The exhaust staining aft of the three vents at the back... Due to the simple principles of the laws of mothin, wouldn't those stains run parallel to each other, instead of a radial pattern? I know it's a small point, but from one who is around planes quite a bit and sees staining of all sorts, this doesn't follow any flow patterns I've ever seen.
just idle curiosity... :)
"I may not fly with the eagles.....but weasels don't get sucked into jet engines!"
