HELP... Unglueing??
HELP... Unglueing??
Posted by Anonymous on Monday, February 21, 2005 9:57 PM
Hello
I think I really need some help here. While I was trying to dryfit the Nacelles on my NX-01 I dropped one one the floor. (I know modelling and beer don't mix)
The only way I can see to fix the damage is to take it apart and start over. Is this possible??
I used Testor's Orange Tube on the alignment pins, and Testor's MEK liquid on the seams.
Can I undo the damage I have done?
Thanks
Yolev
Posted by Woody on Monday, February 21, 2005 10:18 PM
Some people say that if you freeze the parts in the deep freeze they can be popped apart. I've never tried that but it sounds do able.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    May 2004
Posted by maxx1969 on Monday, February 21, 2005 11:13 PM
Hi Yolev, I have gotten parts to separate after gluing with the liquid glues by warming the part just a bit in warm tap water and then work along the joint applying pressure to the center of the joint. It will start to weaken the joint and will pop loose after a couple of passes. The gel type glue is some sticky stuff and you might brake a pin or two there but that will be hidden when your done anyway.
Matt
~Matt T Meyer
Posted by Anonymous on Tuesday, February 22, 2005 4:15 PM
Thanks for the suggestions.
I tried Woddy's idea of freezing. Maybe my freezer isn't cold enough ( not quite a deep freeze) but it didn't work.
With a lot of poking, proding, and tweezering I was able to get the piece back into place. Shoud be good enough to glue back.
Next time I will try the warm water.
Yolev
