Filling Panel Lines on AMT E-A
    November 2003
Posted by MartianGundamModeler on Tuesday, April 5, 2005 10:21 AM
I ahve an AMT Enterprise-A that I am currently kit bashing. I was thinking of filling all of the fine panel lines and only leaving the large "main lines". I am working on a Constitution class that was "up-rated" with 24th century technology, includding phaser strips and sunken Definant/Voyager type bridge.
I want the hull to have hull plates similar to the large ones that that Voyager has...
"Some men look at things the way they are and ask ' Why?'. I dream of things that never were and ask "Why not?".--Robert Kennedy taken from George Bernard Shaw's "Back To Methuselah" (Thanks to TomZ2) http://martiangundammodels.50megs.com/index.html
Posted by Woody on Tuesday, April 5, 2005 11:18 PM
When I need to fill a panel line, I use CA and CA accelerator. I dab the glue into the seam a tiny drop at a time with a tooth pick. I hit it with accelerator every little bit and wet sand with 600 grit wet/dry sandpaper. I've had the best luck with this method. If you use filler sometimes a "phantom" seam will reappear later.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    November 2003
Posted by MartianGundamModeler on Wednesday, April 6, 2005 1:33 PM
Man, I don't think am am up for filling that many seams with CA glue! Oh well they have to stay. i have never used accelerator...
Though i know if you mix CA and testors model glue [one on side and one the other of the piece] it dries faster...
    May 2004
Posted by maxx1969 on Wednesday, April 6, 2005 11:03 PM
I just puttied the saucer for one of mine and used the Testors brand red putty. It worked great and sanding was a breeze. You can putty right over all the panel lines and then before it has time to set run a piece of styrene through the ones you don't want filled. They clean up easy.
Matt
~Matt T Meyer
    November 2003
Posted by MartianGundamModeler on Thursday, April 7, 2005 8:58 AM
What did you use to spread the putty? I have some of the Testor's grey putty [contour putty]. Can any one tell me the difference?
Posted by Anonymous on Thursday, April 7, 2005 10:39 AM
Sand them off the entire model.You'll be happier with the results.Rescribe th e lines you need as you go along. the model wall are plenty thick enough to accomodate both the sanding and scribing. It may sound like alot of work but either way you'll have to sand the entire surface.if you fill with CA you can bet you will sand and refill certain areas multiple times.
Posted by Anonymous on Thursday, April 7, 2005 10:47 AM
By the way, if you hit the CA with accelerator it will be rock hard and very dificult to sand. My suggestion any time you're going to use the CA to fill and sand cure it with baking soda and sand immediately. Work small areas at a timethe longer you leave it curing the harder it will get. Empty a Visine dropper and fill it with baking soda. apply the CA then squeeze the Visine dropper softly and astream of baking soda wiil cure the CA.
    May 2004
Posted by maxx1969 on Thursday, April 7, 2005 1:36 PM
I'm not sure of the make up of the putty but the red seems to be more ply-able and feathers less than the gray or white putty. It also bonds a little better to the plastic in my use of it. Others my have different results. The nice thing is you can see your work as the red shows up nicely on most model surfaces. To spread it I used a piece of styrene and just replaced it as needed. To keep me out of the putty I worked around the saucer in 1/3 sections at a time untill dry. Hope this helps a little.
Here are a couple of links to mine:
http://www.modelhead.com/images/saucer1.jpg
http://www.modelhead.com/images/saucer2.jpg
Matt
~Matt T Meyer
    November 2003
Posted by MartianGundamModeler on Friday, April 8, 2005 10:46 AM
Thanks for the pics maxx! Yeah i like how the red shows up.
Jimmyd30 i just found out yesturday about how thick that plastic is! i was sanding the enginering hull yesturday, I shaved the pylon hard points off, and noticed that I was shaving most of the panel lines as well! SWEET! I am relocating the pylons to the side of the hull. i have not decided whether to angle them or not...
Also if you look at the first pic maxx posted I have cut out the center divider between those holes in the top of the bridge deck to make one large hole. I am going to plase a peice of plastic sheet underneath and create a "sunken bridge" similar to Voyager and Defiant.
EDIT: Spelling corrections.
    May 2004
Posted by maxx1969 on Friday, April 8, 2005 2:46 PM
I like the sound of your idea it should make for a cool subject. Can't wait to see some pics of this.
Matt
~Matt T Meyer
    November 2003
Posted by MartianGundamModeler on Friday, April 8, 2005 3:32 PM
Well I just signed up for an account at "Free photo". I have a digital camera that i haven't figured out yet but hopefull I can post som picks this week end. Tough I have been model building for the past 20 years this is my first major kit bash. i have learned alot about sanding and putty in the last week!!
Wait till you guys see what I did with the navigational deflector! I cut it out and deepened it by simply placing a drink bottle cap behind the hole. It gives the impression of an Excelsior style dish. But keep in mind this is not an "old style" soda bottle cap that has spiral grooves. In stead it has these little notches aranged in a sort of step like pattern. Any way you just have to look in a 2 liter coke bottle cap to see what I mean...Shy [8)]
Any ways what are some good sites to store the photoes to link them to the site?
