Just-finished BTTF Time Machine
Moderator
Posted by Matthew Usher on Tuesday, May 17, 2005 10:54 AM
Hey guys!
Here's one I just finished, Polar Lights' Back to the Future DeLorean Time Machine.
It's a snap-together curbside kit with a plated body. Mine's more-or-less straight from the box, but I did spend a little extra time cleaning up the parts and detail painting. The kit's nicely engineered and PL even gives you optional parts to model the "lightning-rod" version or the "Mr. Fusion"-powered car. A pretty good deal for the $13 or so it retails for. A full review will appear in an upcoming issue of Scale Auto.
Matt @ FSM
    May 2004
Posted by maxx1969 on Tuesday, May 17, 2005 11:42 AM
Very COOOL MattCool [8D]
Hey did you strip the plating off of the front and back before painting the gray? If so what did you use? I tried sanding but what ever PL used its on there to stay. I do have to say though its not a bad looking representation of stainless steel.
Matt
~Matt T Meyer
Moderator
Posted by Matthew Usher on Tuesday, May 17, 2005 1:10 PM
Matt
Glad you like it!
I didn't strip the plating, I just painted over it. I did the gray first, then did the black lower-body trim after that. I used Floquil and Model Master enamel paints and they both seemed to stick pretty well. (Admittedly, I should have painted the rearview mirror housings black...)
I have to admit, I was a little sceptical of the plating at first, but once all the trim's painted and the time-machine details are installed, it looks pretty good. It's convincing from about three feet away, and that's just fine by me.
Matt @ FSM
