Romulan Warbird
Romulan Warbird
Posted by Anonymous on Sunday, July 31, 2005 11:41 PM
I've just started my Star Trek Romulan Warbird (yea jimmyd finally!) and its been tougher than I thought to detail/weather it. So far i've just laid down the main color (I chose a light green, not too light though). Anybody have any ideas on what and how I can weather/detail it?
    September 2005
Posted by Fish-Head Aric on Tuesday, November 1, 2005 1:47 PM
Trekkie, did you ever get this model finished?
Would love to see it!
~Aric Fisher aric_001@hotmail.com
Posted by cassibill on Tuesday, November 1, 2005 4:50 PM
Some darkening around the disruptor emiters and having the leading edges and areas around the warpdrive lighter seems about right.
I can look for some more pics for you if you'd like but startrek.com has a lot of pics that might help.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
    December 2004
Posted by fistius on Tuesday, November 1, 2005 7:33 PM
Hi, on the actual studio models, there is also a subtle overspray of a lighter colour, almost white, on the panel lines and leading edges, with some blending to the hull colour. Check out the pics at the IDIC page. Cheers, Chris
'Beavers and ducks!'
Posted by Anonymous on Wednesday, November 2, 2005 4:37 PM
I some how missed this post. I'm not sure what level of construction your looking for,but I tell you how I handled mine.
Because of the double hull design you will have to strategically plan your painting/detailng sequence. Construct the upper and lower hull,the "head"or forward section, the rear pylon,and the nacelles. Take each of the 6 sub-assmblies and construct the model using masking tape to hold the completed model together. When you fell the alignment is to your liking, glue the forward section to the top hull. Then attatch the rear pylon to the lower hull.
Now remove the tape and you're left with 4 sub-assemlies which should not be glued together - the upper hull and head, the lower hull and rear pylon,and the two nacellels.
Paint ,detail,and weather the interior portions of each hull.
Now complete the construction of the model. the parts of the model that would now be extremely difficult to detail- due to the limited space available between the hulls- are now already painted. Now you have only to mask the pre-painted interior to prevent overspray and such that might occur while finishing the outer hulls. Any painted areas that may have been affected during the final construction should be easily accessible and can be refinished.
The many panels make it very easy to touch up painting and detailing as each panel can be masked and painted separtely, and in theory no two panels are the same anyway.
Posted by Anonymous on Thursday, November 3, 2005 1:53 PM
I liked the way this one was painted up. My airbrushing skills aren't quite up to that level though: http://www.starshipmodeler.org/gallery9/ipms_04/tk_ipmsnats04_sf_55_jd_ships11.jpg
Posted by Anonymous on Thursday, November 3, 2005 2:03 PM
I thank you for the compliment StevenQ ! Just so happens jimmyd30 built and detailed that model. Wink [;)]
    September 2005
Posted by Fish-Head Aric on Thursday, November 3, 2005 3:57 PM
Wow! Jimmy, you did a fine job on that. Much nicer than the green look of TNG first introducing the return of the Romulans.
Posted by Anonymous on Thursday, November 3, 2005 5:51 PM
Yes very nice indeed. I saved the pic to my computer to use it as a reference to paint my own, someday. Again, very nice airbrushing.
