Viper Mark 2 from BSG?
Posted by Anonymous on Saturday, August 13, 2005 6:25 PM
Well, I've done some searching around and I found a guy that created a resin kit of the mk2 but it goes for about 220 bucks. A tad out of my range.
So then I was reading a FSM magazine and saw where I guy took a gun ship model (hercules) and made it into a slightly different model by cutting it and sticking it back together with some parts and stuff...anyway he also recreated a part using resin foam, and then cast it. And then I wondered...could I maybe get a old viper model and re cast some parts and voila?
btw: I've only done a few resin cast type things a few years ago...mostly extra heads for my starwars guys.
So...possible? better suggestion? I'd REALLY like a viper mk 2
Thanks all!
ps - look forward to my "intro" soon
Rick
Posted by Anonymous on Saturday, August 13, 2005 7:01 PM
I suggest you spend more effort on Google. There are three different MKII kits in existance right now and another on the way.
You should check these sites.
http://www.starshipmodeler.com/cfstore/index.cfm?fuseaction=product.display&Product_ID=121
http://scifimodels.com/sfmmkits.html
But you won't find a better kit than the 1/24th scale one for $200+.
Posted by Anonymous on Saturday, August 13, 2005 8:32 PM
Yeah, I've seen that 1/48 one, though that 1/72 one is new to me. Still, the 1/48 seems kinda small, like 7 inches. So the 1/72 has gotta be like...5? I don't suppose there's a scale in the middle some where, huh? 10 or 11" long would be nice.
Posted by Anonymous on Sunday, August 14, 2005 10:32 AM
That would be 1/32 to match the Monogram. There is talk from MMI that they could do it with enough interest. But it would be way off in the future.
You could carve it you know. There is plenty of reference out there to do it.
http://www.starshipbuilder.com/ubb/Forum3/HTML/000002.html
Posted by Anonymous on Sunday, August 14, 2005 12:13 PM
Kinda brings me back to my original point...I think I might look into that resin foam stuff, then get an old monogram kit and cast some new bits to it.
Or would you, if you were me, just scratch it? What would you use?
Posted by Anonymous on Sunday, August 14, 2005 1:15 PM
There is absolutely nothing common between the two Vipers. It would be more work and far more expensive to try an convert the old kit.
I strongly recommend reading this article. I think Mr. Merriman is teasing with the "kitbuilder" bashing, but the article is sound and very informative.
http://culttvman.com/scratchbuilding.html
Urethane foam is great. But you will need to seal it with epoxie putty or something similar.
Here is a treatment I did to make thin parts without vaccuum forming.
http://home.comcast.net/~cobywan/Templates/VF.htm
Posted by Anonymous on Sunday, August 14, 2005 1:56 PM
Woah, wait wait...I still need to read the one article, but I looked at your model...so...you carved that in foam, then coated it with putty and filed/sanded it to get those pieces? Dude, that is amazing. And the panel lines...holy crap.
Posted by Anonymous on Sunday, August 14, 2005 11:35 PM
The original shapes were foam. Then I coated them in primer but squadron putty would work for that too.
I then made a mold off of those shaped in plaster. I waxed up the plaster so that nothing would stick to it.
Then I mixed up Magic Sculpt epoxie putty and rolled it out like a pie dough. The real trick here is to roll on parchment paper and use talcum powder like you would flower. I rolled with a spray can of primer. The lip on the edge of the can made the whole sheet uniform.
I then pressed the sheet of epoxie into the plaster mold. After the epoxie is set you have to trim it out carefully. I put the rough trimmed parts back into the plaster form and sanded the seams flat using the mold top as the reference. You can really finnesse the epoxy shell with sandpaper.
The scribing was done with a broken sewing needle put into an X-Acto handle. I used the Hasegawa scribing templates.
You have to be carefull with the epoxie shell though. They are very brittle.
Posted by Anonymous on Tuesday, August 16, 2005 3:20 PM
That's absolutely amazing. I'm going to have to try that. Did you use balsafoam, or something cheaper?
I imagine I will spend a lot of money, make a huge mess, and make a lot of useless crap until I get it right...but damn does that sound fun.
I read that other article, that guy is certainly angry. I ordered a back copy of FSM that has the resin article in it, should be interesting.
Wish me luck.
Posted by Anonymous on Tuesday, August 16, 2005 9:25 PM
What I use is the same stuff as balsafoam. But my employer uses it and throws away stuff that is useless to them but valuable to us small modeler types. Bass wood is always a joy to work with though. But the foam stuff is easier all around.
Posted by Anonymous on Wednesday, August 17, 2005 10:38 AM
Never heard of bass wood...
Is your stuff cheaper than balsa foam and available commercially? I ask about price because I forsee a lot of trial and error.
Is it stupid that I'm actually giddy at the prospect of goofing with all this?
Posted by SNOOPY on Wednesday, August 17, 2005 12:24 PM
PSUEDODIGM: Here is a link to a place that makes and sells Balsafoam I, II, and III, http://www.balsafoam.com/aboutbalsafoam.asp The website also explains sanding techniques, painting, carving, etc. Especially the safety aspect of it when sanding or cutting with a moto tool. Price is comparible with everyone else that I saw.
Scott
Posted by Anonymous on Wednesday, August 17, 2005 9:50 PM
I can't rightfully say. I've never bought either product. ;)
In regards to Basswood, do you have a hobby shop or a good craft store in your area?
Where are you from by the way? And getting excited about scratchbuilding is perfectly normal.
Posted by Anonymous on Thursday, August 18, 2005 7:35 AM
I have a hobby shop that has a lot of great stuff, but I haven't noticed any wood of any kind really. some metal and lots of styrene. Then again, I really haven't checked out the train section...I'll look around more. And yeah, I have a couple craft places. Michaels and AC Moore.
I'm in Massachusetts.
In reading about the balsafoam, it looks like you could use the foam itself for the master, by just coating it with putty and sanding. It also mentioned giving it a plastic shell. I've never tried "painting" a 2 part resin onto anything...and I'm not sure how you'd get it not to run...but I suppose you could just sand out all the runs
But perhaps it would be better to just build up a coat of acrylic paste and use it as a positive for a rubber mold, then use resin in that.
Posted by Anonymous on Thursday, August 18, 2005 7:41 AM
If you add a bunch of baby powder to your resin it will thicken it and make it more sandable. But full strength aumotive primer can be painted on with a brush and sanded down. The trick is to sipple it into the foam so it gets into the pores. It could take a few coats too. But you can get a nice finnish
Posted by Anonymous on Thursday, August 18, 2005 10:43 AM
Interesting, and baby powder won't screw up the resin at all?
Posted by Anonymous on Thursday, August 18, 2005 8:39 PM
At my job talcum powder is a required addative to the fiberglass resin. I think it adds some kind of structural component. The more you add the more of a paste it makes.
Posted by Anonymous on Friday, August 19, 2005 8:21 AM
That's pretty awesome, I'll try that. ...wonder if there's a difference between "baby powder" and "talcum powder".
Thanks for all your help. I'm sure I'll check back in once I get these supplies and start experimenting, but I think I've taken up enough of the forum's bandwidth as it is.
Posted by Anonymous on Friday, August 19, 2005 8:37 AM
The only difference is the perfume.
I don't think bandwidth is a problem here. ;)
