Building PL 1/1000 TOS NCC-1701 for first time. Seeking tips and pointers for this kit.
Posted by djrost_2000 on Tuesday, July 11, 2006 1:58 PM
Will be building Polar Lights 1/1000 USS Enterprise soon.  Just seeking tips and pointers for this kit.
Thank you,
Dave
    January 2006
Posted by dirkpitt77 on Tuesday, July 11, 2006 3:30 PM
    The only thing I can think of that really gave me problems on that kit was joining the engine nacelles to the pylons.  I've heard it's almost better if you attach the warp engine half to the pylon first, then finish assembling the engine nacelle.  I did my engine nacelle first, then tried to snap it onto that little tab on the pylon, but broke the tab.  Ended up having to epoxy it.    Other than that the kit was gravy.
        Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    November 2004
Posted by Chris_in_Japan on Tuesday, July 11, 2006 4:55 PM
Agreed.. The engine nacelles, and the saucer join seam.. Other than that she's a cool little kit..
Looking forward to seeing more..
Chris
On the bench:
                          1/48 RAAF 3 Sqn F/A-18B
                          1/150 /1/160 N Scale Japanese Rail diorama.
Posted by djrost_2000 on Tuesday, July 11, 2006 7:11 PM
Thanks very much for the replies and info.  I posted the same question on Starship Modeler forum and the engine nacelle issue was one of the biggest thing mentioned there.
Thank You!
Dave
    May 2006
Posted by CaptainHawk1 on Tuesday, July 11, 2006 9:56 PM
First an foremost... GET RID OF THE EXTRA PARTS.  Decide which version you plan on building and put those extra parts away (refer to the instructions to figure out which ones you need).  I wish I had and instead I wound up having... issues.
Cut off all of those pins used to snap this kit together on the causer section, nacelles and engineering section.  They just get in the way.
I recommend using Testor's Model Master Flat Camouflage Gray and mixing it with flat or gloss white (you figure out how much you want to use as I wasn't paying attention when I did it, I just added white until it looked good) as your base color.
DO NOT use the paint scheme recommended in the instructions.  It's retarded.  Look up pictures of the screen model online.
Like the man said, cut the ends of the "V" (the nacelle pylons) as the nacelles fit cock-eyed when those things are on.  You will need lots of putty to fill those gaps.
I would recommend cutting that part on the neck that connects to the saucer section right off and just use Zap to connect the two sections together.
Use lots off putty everywhere on this thing.
This model was my first foray back into modeling after a  4 year absence.  Needless to say, I made a lot of rookie mistakes that were avoidable.
-Shawn
"Never mind...it's just easier to call you stupid." -Brian Griffin
    November 2004
Posted by Chris_in_Japan on Wednesday, July 12, 2006 12:30 AM
I think its because of all the years playing with AMT kits, that cutting off the pins becomes a second nature form of thinking.. he he he.. But you layed it out well there Shawn.. An awfull lot of putty!.. Seems to be the way on most models sadly!
Chris
On the bench:
    December 2004
Posted by Hippy-Ed on Friday, July 14, 2006 9:00 AM
I just stumbled upon this & I've got the same kit in my stash. I've looked over the sprues many a time & I'm still undecided on which version to doShock [:O] Yet, that is sound advice on setting the unused pieces aside as they'd just make things more confusing. Thanks for posting on what nneeds to be done here with this kit as I know I found the info quite helpfulThumbs Up [tup]
If you lose your sense of humor, you've lost everything
    November 2004
Posted by Chris_in_Japan on Sunday, July 16, 2006 7:28 AM
Good to see you back Ed!Thumbs Up [tup]
Chris
On the bench:
    December 2004
Posted by Hippy-Ed on Sunday, July 16, 2006 4:12 PM
Thanks ChrisSmile [:)] You know me, I am at home here & can't stand to be away for too longSmile,Wink, & Grin [swg]
    November 2004
Posted by Chris_in_Japan on Sunday, July 16, 2006 7:09 PM
Well mate, its just good to see you on again..
Chris
On the bench:
