T-800 Skull
    December 2005
T-800 Skull
Posted by viper_mp on Tuesday, July 18, 2006 11:44 AM
I got this off ebay. Its a vinyl skull with some resin.  I drilled out the eyes and added LEDs and diffusers to the eyes.  Overall base of Metalizer Titanium with nato black shading.  The teeth were painted in JDF grey.  I'm very pleased with it.  It the first ti,e I have used an airbrush to do shading/detailing.
Rob Folden
Secretary / Webmaster- IPMS Plastic Surgeons Member at Large-IPMS Hawkeye Modelers
Posted by ssgkopp on Tuesday, July 18, 2006 7:23 PM
that looks great  good job on the shading
k
    June 2006
Posted by Cpt.Sponder on Wednesday, July 19, 2006 4:32 AM
i really like the eyes, do they fade in/out?
    November 2003
Posted by ilikespagetti on Friday, July 21, 2006 11:32 PM
That looks great, I had the all vynil verson of this. I got pissed at it, threw it on the floor, after picking it up I havent touched it since.
I am a man, But I can change. If I have to....I guess...
    November 2003
Posted by MartianGundamModeler on Tuesday, July 25, 2006 3:25 PM
What did you use for the difusers?
"Some men look at things the way they are and ask ' Why?'. I dream of things that never were and ask "Why not?".--Robert Kennedy taken from George Bernard Shaw's "Back To Methuselah" (Thanks to TomZ2) http://martiangundammodels.50megs.com/index.html
    December 2005
Posted by viper_mp on Tuesday, July 25, 2006 4:09 PM
Thanks for the comments guys.
The eyes do not fade.  They are real simple, two red LEDs wired to a 9v battery.  No circuits at all.  The eyes themselves are clear plastic cut from a blister package.  the backside as sanded in a circular pattern, which acts as the diffuser.  I glued square pieces on balsa wood behind the eyes, with holes drilled for the LEDs.  The inside of the eye and the wood were painted in flat black, and the eyes were painted with tamiya clear red mixed 5-1 with clear smoke.  The red LED is centered in the eye, so the black around it works with the diffuser to give the overall eye a red to black fade.  and when the eyes are off, they are solid dark red/black.
Rob Folden
Posted by Anonymous on Friday, July 28, 2006 3:41 AM
Cool i like it when people add simple modifications to make something cool .
So if i wanted to put leds in my model all i need is to hook it up to a battery? I want to put some lights in some of my models but i always heard its hard to do it.
Any other shots of it , in better lights ?
    June 2006
Posted by Cpt.Sponder on Friday, July 28, 2006 7:33 AM
nope, you gotta hook up some resistors as well, otherwise your leds would have a short life indeed..
losta electronics tuts, but it comes down to: U=IxR...
    December 2005
Posted by viper_mp on Saturday, July 29, 2006 7:33 PM
Sometimes thats all you need to do.  It really depends on if you are running it for long or short time periods.  I set up mine for short, so its just two 12v LEDS hooked to a single 9v. Gives it a little more run time.
Rob Folden
    June 2006
Posted by Cpt.Sponder on Monday, July 31, 2006 3:40 AM
im afraid i dont agree.. the problem is not the voltage, but the Amps.
a normal led on full intensity pulls something like 20 Amperes, so 2 leds: 40 Amps. now check your battery to see howmuch amps its delivering (depends on battery) obviously, it will give more than 40 amps, the voltage is not that important. You need to take away the rest of the amps so the leds will only get 20 amp, otherwise they will burn out way too soon... (the wattage will be too high in leds..)
you can compare it with a river:
the width of the river: VOLTAGE (U)
the quantity of water streaming through the river: AMPERE (I)
controlling the quantity of water (like a dam): RESISTANCE (R)
energy consumed by components: WATTS.
With a lot of water in a small river, the water will stream fast and hard (low voltage lots of amps, meaning preasure, stuff gets really hot..)
With a very wide river, but only a glass of water, no preasure at all.
What you want to do, is create a river wide enough to let enough water through to power your components, and than create a dam, so you control how much water is entering. Obviously the width of the river controls the amount of water that CAN be put through, so the resistance depends on this.The minimum width of your river depends on the led, normally they require 2-3 Volts.
how? again: U=IxR
it will give you 100.000 hours of life for a led if you screw down the amps, and since resistors dont cost anything really, imho its really worth wile protecting the leds.
so in your case you have 2 leds:
2x2Volts = 4 volts (so a 5 volt battery will do) 5 volt - 4 volts = 1 volt too many..
so u=ixr => 1=20xR ==> R=1/20 ==> 50 Ohm. (next high value in E12 series will do nicely)
in your case you have 9 volts:
2 leds = 4 volts ==> 9 volt - 4 volts = 5 volts too many:
u=ixr ==> 5=20xR ==> R = 5/20 = 250 Ohm
next resistor from E12 series in your case: 270 Ohms.
Hope its a bit more clear now, and you see why you really DO need to hook up resistors to a led, nomatter the voltage.
ps: if you dont trust my or your own calculations, or if you are just too lazy for it, google for: resistor calculator, lots of them! just give the power supply, nr of leds et voila, you have your resistor... :)
gr. S.
    December 2005
Posted by viper_mp on Monday, July 31, 2006 12:30 PM
Most of the time I dont use LEDs.  And if I do, they are pre-wired in a circuit. I just quickly threw in a couple on this one for fun.  They arent intended for prolonged use.  Usually just a minute or two.  But if they ever fail, they can easily be swithed out for something more permanent.
And thanks for the google tip.  I may need that in the future.
Rob Folden
    June 2006
Posted by Cpt.Sponder on Tuesday, August 1, 2006 2:51 AM
no prob. last note though: if you were to attach a resistor, the leds would be permanent :)
Hope you or maybe some1 else who wants to light up their models but dont have any electricity experience (like me..) found the post usefull..
Posted by Anonymous on Thursday, August 3, 2006 11:28 PM
Thanks for the posts its helping me learn more about electronics. I am in film school and i like to photograrph models and make them look as if they were from the movies but alot of mine needed some lights in the models for the illusion to work.
    June 2006
Posted by Cpt.Sponder on Friday, August 4, 2006 2:55 AM
no problem!
but hey, once you have the pics, you wouldn't mind sharing them eh? please do!
good luck with it! let me know if you have any problems..
oh and btw: since you are in film school, cant you make a quick tut. about taking decent pics from our models? just my My 2 cents [2c] thanks!
Posted by Anonymous on Friday, August 4, 2006 7:34 AM
ya that would be cool , i have not made a tut before i can post it on my site. i am pretty busy in school right now. All my lights were back at home but i can do one with some pretty basic lights.
That is is 2nd fav part of model building the photographing of them giving that final presentation 1st i painting and weathering.
