Lighting models ?
    January 2003
Lighting models ?
Posted by emo07 on Friday, September 1, 2006 11:45 AM
Hi all,
I originally posted this in the aircraft forum, but might have better luck in this forum since some of you have used LEDs to light spacecraft.
Anyway, I have a 1/24 scale Trumpeter Zero fighter plane that I would like to use LEDs to light the navigation lights.
What components would I need to do this ?  Power supply ? How do I make them blink ?
Any help is appreciated !!
emo07
" When I saw fighters escorting the bombers over Berlin, I knew the jig was up." - Herman Goering
    May 2003
Posted by klem on Friday, September 1, 2006 2:12 PM
Check out Micromark. They have lights led's and such for trains and what not. I lit up my 48th B-24 using grain of wheat bulbs and wired all so that they were drawing juice off a AA battery. I believe led's need a potentiometer to control the watage. I also have a flashing light setI bought from the train section of a hobby store. It has a small circuit board and a resistor due to the fact that it is powered by a nine volt battery. There were a number of articles about lighting models in some issues of FSM. One was for a Klingon crusier, there was also one on the Death Star. If you can find those articles they might help.
"We the unwilling, led by the unknowing, are doing the impossible, for the ungrateful. We've been doing so much for so long with so little we are now capable of doing anything with nothing." Unknown
    January 2003
Posted by emo07 on Friday, September 1, 2006 3:07 PM
Thanks, Klem. I will check these articles out.
emo07
    May 2003
Posted by kylwell on Friday, September 1, 2006 3:55 PM
I get all my lighting info here
http://www.starshipmodeler.net/cgi-bin/phpBB2/viewforum.php?f=58
Posted by Woody on Friday, September 1, 2006 5:21 PM
 kylwell wrote:
I get all my lighting info here http://www.starshipmodeler.net/cgi-bin/phpBB2/viewforum.php?f=58
He knows of what he speaks! Wink [;)]
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    June 2006
Posted by Cpt.Sponder on Monday, September 4, 2006 2:43 AM
all you need really is some resistors between your power suply and your leds, so do a google on: resistor calculator, 1000's available, check it, they make life easy :)
for more detailed questions: dont hesitate to post!! good luck!
    June 2006
Posted by Cpt.Sponder on Monday, September 4, 2006 2:50 AM
i suddenly remember i did some basic explenation a while back, did a quick search, maybe this will help:
 viper_mp wrote:
Sometimes thats all you need to do.  It really depends on if you are running it for long or short time periods.  I set up mine for short, so its just two 12v LEDS hooked to a single 9v. Gives it a little more run time.
im afraid i dont agree.. the problem is not the voltage, but the Amps.
a normal led on full intensity pulls something like 20 Amperes, so 2 leds: 40 Amps. now check your battery to see howmuch amps its delivering (depends on battery) obviously, it will give more than 40 amps, the voltage is not that important. You need to take away the rest of the amps so the leds will only get 20 amp, otherwise they will burn out way too soon... (the wattage will be too high in leds..)
you can compare it with a river:
the width of the river: VOLTAGE (U)
the quantity of water streaming through the river: AMPERE (I)
controlling the quantity of water (like a dam): RESISTANCE (R)
energy consumed by components: WATTS.
With a lot of water in a small river, the water will stream fast and hard (low voltage lots of amps, meaning preasure, stuff gets really hot..)
With a very wide river, but only a glass of water, no preasure at all.
What you want to do, is create a river wide enough to let enough water through to power your components, and than create a dam, so you control how much water is entering. Obviously the width of the river controls the amount of water that CAN be put through, so the resistance depends on this.The minimum width of your river depends on the led, normally they require 2-3 Volts.
how? again: U=IxR
it will give you 100.000 hours of life for a led if you screw down the amps, and since resistors dont cost anything really, imho its really worth wile protecting the leds.
so in your case you have 2 leds:
2x2Volts = 4 volts (so a 5 volt battery will do) 5 volt - 4 volts = 1 volt too many..
so u=ixr => 1=20xR ==> R=1/20 ==> 50 Ohm. (next high value in E12 series will do nicely)
in your case you have 9 volts:
2 leds = 4 volts ==> 9 volt - 4 volts = 5 volts too many:
u=ixr ==> 5=20xR ==> R = 5/20 = 250 Ohm
next resistor from E12 series in your case: 270 Ohms.
Hope its a bit more clear now, and you see why you really DO need to hook up resistors to a led, nomatter the voltage.
ps: if you dont trust my or your own calculations, or if you are just too lazy for it, google for: resistor calculator, lots of them! just give the power supply, nr of leds et voila, you have your resistor... :)
gr. S.
