1/2500 Scale Trek Modeling Goodness
    June 2004
Posted by Griffworks on Thursday, September 7, 2006 8:16 PM
OK, been a while since I've posted any new model stuff here, but here ya go.
I've gotten back to Trek again after a short hiatus of mostly building Battlestar Galactica stuff. I've gotten my focus back and am working to finish some few Trek models here and there. First up has been a Sovereign, an E-D, almost my entire Klingon Fleet and some few Fed and Romulan stragglers. Those are still in-work, but as the paint dries on those, I construct more.
My Trek focus has come back to an idea I had about a year or so ago to do several Mirror Universe Trek ships. For the full -background story on that, see this thread at The 2500 Page Forums: The Terran Empire - Mirror, Mirror, On The Wall....
Anyhow, I've got several new ships that are at the primer stage now and will go in to the queue to be painted. First batch is in the pics below. Identification of ships from the below pics follows.
Upper Left: Guenther-class dreadnought. I used a spare (at the time!) PNT Models Avenger hull mated to a modified PNT Models Indomitable secondary hull. I built up the connecting area w/sheet stock and putty to raise it up a bit, giving more clearance for the pylons. The upper nacelle and pylon assembly is a spare "second" from the VA Miniatures Jenghiz-class destroyer. I cut the nacelle from the "neck", reversed the neck after sanding it to fit the upper hull of the Avenger, then glued the nacelle in place. This one is to be named the U.S.S. Kristiansen, NCC-3601.
Middle Left: is one of two ships I'm calling the Kumari-class Fast Destroyer (DF). I took the basic Stingray-class destroyer hull and added a warp nacelle/pylon assembly from a Furuta Constellation/Stargazer mini. I also added one of the VA Mini's weapons pods that comes w/the kit to give it a dual punch. My thinking is that this weapons pod allows for as many as four photon torpedoes to launch at once - sort of the predecessor to the photorp system that we see later in TNG whenever the E-D fires a "full salvo" or "spread" of photorps. I have made up two of these and this will be either Kumari, NCC-3100, or Zardoz, NCC-3110.
Bottom Left is the Andor-class Missile Cruiser! Love this thing! One of the fellas at The 2500 Page Forums 'bashed one out of a Refit kit, molded it, cast it and traded a few extra's and I got one. Want more! NEED more! The kit nacelles I got w/it were going to require more work to get them looking good than I was willing to put in to them, so I took the lazy-route and gave it a pair of VA Mini's "seconds" nacelles I had that need only minor touching up. I sanded down some of the scribed detailed panel lines so that it wasn't quite so prominent, puttied & sanded pinholes, some airbubbles and pour stub marks, then let it sit overnight for the putty to more fully cure. Sanded, primered and then assembled this morning.
Top Middle: Cyclone-class thru-deck cruiser by RogueWolf - eventually to be for sale from Millenia Models Int'l. He designed it to be more of a TNG/DS9 Era ship, but I think it works well as a Movie Era ship, too. I've not decided for sure what to name this, but have been thinking of giving it the name Fujita - the man who developed the "F-Scale", used for identifying the intensity of Tornadoes, Tetsuya "Ted" Fujita of the University of Chicago who developed the scale. No clue I'll give her for a registry, but I was thinking possibly late 2290's/very early 2300's so 1xxxx sounds like a winner to me.
Top Right: Refit Excelsior-class heavy cruiser. This one is actually going to be a Battleship from the Mirror Universe. The weapons pods on top of the saucer are similar to those on the Kumari-class above - capable of firing up to four photorps at one time, as well as has two sets of phaser emitters on it. This ship has been named I.S.S. Kodos, NCC-2244.
Bottom Right: Stingray-class cruiser from VA Miniatures. I'm calling it a Frigate, tho. This one is going to be the U.S.S. Duke, NCC-1999. I opted for the two nacelle, two weapons pod variation and will use that for all of them that I might build of this particular class. I want one or two more of these, too.
 More to come.
The greatest measure of a man is his children and what kind of people they are.
    June 2004
Posted by Griffworks on Thursday, September 7, 2006 8:19 PM
I got one of these most excellent "Multiverse SpaceDocks" (available thru Starship Modeler) while in Chicago a couple of weekends ago for "LesterFest" (10th Anniversary celebration of Starship Modeler) and finally got around to working on it the last two nights. Here's a couple of teaser pics of what I've got done so far...
The white piece in some of the pics is a second from one of the previous years Resin Drop's at WonderFest. It's from the Roger Young kit. It's to be the "Command & Control section" of the drydock, have the offices and living quarters for a lot of the workers, as well as some conference rooms and the like. I plan to make further modifications, as well, such as a possible superstructure on top of the dock and some boarding stations on the inside sort of like what was on the TMP Drydock.
    June 2004
Posted by Griffworks on Thursday, September 7, 2006 8:22 PM
Nearly finished. Well, construction is pretty much finished except for some touch up.
I'm going to call this a part of Griffworks Shipyards for my little cornor of the Trek Multiverse. Well, it's one of the 13 Drydock facilities that are used by the Griffworks Shipyards Corporation in Earth orbit.
The thing on the back of the drydock is two of the pieces from the Large Death Star Tiles that are sold in the SM Store, cut at the halfway point, then glued back-to-back. That is the factory area where the components of the starships being built are fabricated. It saves a great deal of time and money by having the fabrication facilities right there at the drydock where initial construction, refurbishment or major refit takes place.
Anyhow, enjoy....
http://members.aol.com/griffyards/Griffyards03.jpg
http://members.aol.com/griffyards/Griffyards04.jpg
Still needs another coat of primer, then painting. I also need to figure out how I'm going to display this. My initial thinking is to mount it to a plaque of some sort, but I've not yet decided. Need to do that soon, tho....
Anyhow, I've ordered a second of this kit and will make it a mobile drydock along the lines of that seen in the old FASA Star Trek RolePlaying Game and the Jackill's StarFleet Reference Series. Not sure what sort of nacelles to put on there just yet, but was leaning towards a pair from a 1/2500 scale Enterprise-B along w/substational superstructure on top.
Anyone have any thoughts on this? Appreciate any input.
    December 2004
Posted by Hippy-Ed on Thursday, September 7, 2006 8:57 PM
I gotta git me one of those!!!Big Smile [:D]Cool [8D] The spacedock is great! I have the
1/2500 Enterprises (AMT sets) which I'm slwly workin' on. YOu've goven me an ideaBlush [:I]
Looks good & I'll be watchin' this thread!!
If you lose your sense of humor, you've lost everything
    June 2004
Posted by Griffworks on Friday, September 8, 2006 7:28 AM
Thanks!  The kit is $38 from The Starship Modeler Store and I highly recommend it.  Well worth it, IMNSHO.  I purchased a second that should be showing up any day now.
Posted by cassibill on Friday, September 8, 2006 10:25 AM
I'm trying to keep myself away from the 1/2500 Trek stuff cause once I start...  Let's put it this way, Mom may regret finishing the upstairs ceilings in something that lends itself to hanging models.  I had to use space models up there since I painted the night sky in glow in the dark paint on it.  As a scratchbuilder and a Trekkie Geek,  I do love your work.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by Woody on Friday, September 8, 2006 12:38 PM
Nice collection Griffman! I'm partial to the neat-o thru-deck carrier. I wonder how one in the scale of the gods would look(1/1000)? Wink [;)]
Oh and it's good to see you back Cassibill! Big Smile [:D]
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by cassibill on Friday, September 8, 2006 1:23 PM
Hi, Woody. School is back in session.  Star Trek is 40 today.
Here's a neat scratchbuilding idea:  in one of the Corps of Engineers novels, one of the guys was designing a specialized ship for the Corps.  The forward part of the saucer would open to space (like pincers kinda) and another ship could be pulled partly (or completly if it was a smaller class) inside for repairs.  A module (like the Nebula Class) would function as a materials storage.  Depending on the job, the modules changed. Like in Nemesis when the Enterprise's forward section was smashed up, this ship would had picked up a module of ship materials and rendezvoued with the E.  It would have simply opened the forward saucer, towed the E in, locked on and went to work.  As the saucer was restored the tractors were to switch to repulsers and the E would have moved back to make room for more of the saucer to be rebuilt.  The E never would have had to return to spacedock, it would have come to them.  Think of the difference that would have made during the Dominion War.
    August 2005
Posted by highlanderburial on Monday, September 18, 2006 8:46 PM
Are most of those futura (japanese company?) ships from the movies and tos in 1/2500? I just got a little USS Grissom for less than 10$ and repainted it. It looks about right to me. Any comments welcome.
Todd
Imagine a witty signature right .....here....
    October 2004
Posted by ikar01 on Monday, September 18, 2006 9:18 PM
Just how big are those?
    August 2005
Posted by highlanderburial on Tuesday, September 19, 2006 7:46 AM
Futara box sets.They are mostly the same scale as the Polar Lights "matchbox" sized ships. They come in random box sets so you can't tell which ones you are getting. Ebay has em all the time and they are generally for sale in Comic stores and game stores etc. They are well detailed and painted though.
-TW
    June 2004
Posted by Griffworks on Tuesday, September 19, 2006 9:58 AM
Oh, no.  Hardly any of them are Furuta Mini's.  Those have scales all over the place and none are 100% 1/2500 scale.
That particular Furuta Mini is about three times too large.  For a good idea on what scale those are, go check out the Star Trek Kit List By Scale for the complete list and scales.
Posted by SNOOPY on Wednesday, September 20, 2006 11:46 AM
Griffworks,  very nice job.  Did you scratchbuild any of those?  Very nice looking fleet. I wouldn't mind seeing some of the Klingon fleet you mentioned.
    March 2004
Posted by BlackOps on Wednesday, September 20, 2006 1:48 PM
Hey JG, as usual most impressive work, I like the space dock too...Just won't work with my 1/350 Enterprise ;)
Good to see you in production mode!
Jeff G.
    June 2004
Posted by Griffworks on Wednesday, September 20, 2006 6:46 PM
Thanks.  None are completely scratchbuilt, no. A few have major sections that are scratchbuilt, but most are either straight kit builds or kitbashes.
  I'll take some up-to-date pics and post them to my site sometime this weekend.
Thanks JG!  I appreciate it.
There are two other space docks available thru SM, dude.  Neither are close to what you want/need for the 1/350 scale Refit, but I'll bet you could work something up based on their pieces/parts.
    June 2004
Posted by Griffworks on Friday, September 22, 2006 9:09 PM
I recently purchased a 1/2500 scale Constellation-class model from one of my fellow 1/2500 Fanatics.  It's the first release of the Starcast Models/TM Lindsey Models Constellation and it's not too bad, really. MUCH better than the craptacular Furuta Stargazer mini I've been using as a sort of place holder, which is all I've been able to get my grubby meat hooks on!
Anyhow, I really modified this kit. I took the pylon assemblies from one of my Furuta Stargazers and modified the main hull to accept them. I then cut off the "pods" that hang down from the bottom aft section of both kits, putting the Furuta pods on the TM Lindsey hull, making for much more accurately sized and detailed pieces.
A pic:
Furuta Stargazer and Starcast Models Constellation-class.  The well-butchered Furuta mini is on the left, Starcast parts I lopped off in the middle and then the underside of the Starcast hull showing the mod's.
More to come, eventually.  That'll include those Klingon Fleet pics I promised earlier.
    June 2004
Posted by Griffworks on Sunday, September 24, 2006 9:30 PM
September update for my website!   It's a WIP, tho.  I need to write the HTML for Page 4, which will have pics of my various Fleet Shelves as they currently stand.
September Workbench Update
Enjoy.
    June 2004
Posted by Griffworks on Sunday, October 1, 2006 1:41 PM
OK, I finally finished the update for September late last night.  Page Four contains pics of all my shelves w/the bulk of my models - those that I wasn't immediately working on at my workbench.  This is likely my last update 'til sometime after mid-February.
Posted by Woody on Sunday, October 1, 2006 4:31 PM
Wow that is a lot of starships! Nice collection.
    June 2004
Posted by Griffworks on Sunday, October 1, 2006 6:55 PM
Thanks, Chris!  I was just going thru my unbuilt stuff, reorganizing it so that it's easier to get to by Era and "government" and realized that I've got almost half again as many unbuilt!  Shock [:O]
I'm gonna need some more shelf space, methinks....
    November 2004
Posted by Chris_in_Japan on Monday, October 2, 2006 6:42 AM
Geez Griff.. I must really be playing on your mind.. I havn't even posted on this thread, and you are thanking me!!..
I guess, all I can say is.......
"Your Welcome!"  Big Smile [:D]
On the bench:
                          1/48 RAAF 3 Sqn F/A-18B
                          1/150 /1/160 N Scale Japanese Rail diorama.
    June 2004
Posted by Griffworks on Monday, October 2, 2006 12:05 PM
No more so than a cockroach.
Oh, and it's "you're" as in "you are", not "your". Wink [;)]
In this particular instance, Chris = Woody.  Somebody who's quite the Kewel Kat and a real hoot to hang out with.
You shall ever be Mr. P to me. Thumbs Up [tup]
    November 2004
Posted by Chris_in_Japan on Monday, October 2, 2006 5:29 PM
OMG. Did you just correct my spelling?
Well, all I can say is, that if you look around your house, you will see all these square and rectangle shaped things.. Those things are called windows!.. I suggest you stick your head out of one, and get some fresh air!..
Have a great day Mr G
On the bench:
    June 2004
Posted by Griffworks on Monday, October 2, 2006 5:33 PM
Right back at ya on that fresh air thing.  Smile [:)]
    November 2004
Posted by Chris_in_Japan on Monday, October 2, 2006 5:36 PM
Zzz [zzz]
Ok.. you win!
On the bench:
Posted by Woody on Monday, October 2, 2006 6:59 PM
And I sometimes wonder why I don't come to FSM as often as I once did but them it comes back to me. Griff, I'm sorry my name started this thing in your thread. Sad [:(]
    June 2004
Posted by Griffworks on Monday, October 2, 2006 7:31 PM
Yeah, it's kinda sad.  That's the second time he's come at me on this forums w/o provocation.
However, there are still a LOT of other interesting folks who post here, so I'm not going to let the one person drive me off when there are lots more who have excellent advice and sometimes funny commentaries to pass on. That and I like to see what other folks are doing with their models.
    March 2004
Posted by BlackOps on Monday, October 2, 2006 9:00 PM
Hey JG, that is quite a collection, I sure hope that room is shielded against all the plasma emissions that are bound to occur from a fleet that size. ;)
Jeff G.
    November 2004
Posted by Chris_in_Japan on Monday, October 2, 2006 9:53 PM
Griff.. In all honesty.. With the crap you and I have said to each other lately. My comment was a tongue in cheek comment, made in gest...  Do you honestly think for one minute that I really thought that you were refering to me when you said Chris?....
As for being sad. Its the fact that I was trying to break the ice and be funny ha ha. But I guess it must have gone strait over your head?... To make matters worse. You correct my spelling, when your post isnt exactly Shakespear either..  Seriously man......
As for your comment about "other folks here".. I have 1300 or so posts to your 160.. I simply dont post in just the sci-fi boards, and infact talk with people in every section from time to time.. Feel free to go through my posts, and find one instance where I have been rude, or abusive to any member, other than your good self, and then get back to me regarding my behavior on these boards.. Woody. Dont see you on much here, cant say I have spoken with you many times, or at all?.. If you dont come to FSM, then thats a decision you have made on your own mate...
Chris
On the bench:
    June 2004
Posted by Griffworks on Saturday, December 9, 2006 8:30 PM
Hey, JG!  Sorry I didn't respond to this sooner.  I sort of got lost in getting ready to leave home and come Over Here.   Mea culpa. Whistling [:-^]
 Yes, the room is well shielded against plasma emissions.  It's just not so well shielded from my children, as my oldest son (Daniel, 7) has had a bad habit of deciding to play w/my starships while I'm gone.  Nothing a little glue and putty can't fix.  Plus, it's not like they're anything more than RedNeck Primered.  Wink [;)]
