Bandai 1/144 Zugock-E
Posted by Anonymous on Monday, September 18, 2006 3:35 PM
Here are some in progress shots of my Zugock.  So far I done a good bit of work on the right arm along with a bunch of sanding.  I still have to add some custom parts and maybe improve on the shoulder socket/arm joint.  Sorry if some of the pics are a little blurry.  It's my wife's new camera and I forgot to set it to the right setting.
Here I removed the back pin on one of the claw arms so that it isn't visible once completed.
I still have to remove it on the left claw and do a little bit of putty work.
Claw Before
Claw After
Here are a couple of pics of the shoulder armor.  I wasn't sure if I should remove the plastic pin at the top of the arm inside the shoulder and then lay a strip of styrene in place or putty up the area and then add a bit of detail.  Because the kit is an older 1/144 the detail was the greatest and some of the areas are hard to get into.
Shoulder One
Shoulder Two
Shoulder Three
Since taking these pictures I cut out the vision slits and I still have to construct a new mounting point in order to mount the monoeye properly.  I am also thinking of drilling out the torpedo holes in the top of the head and then recreate the torpedo heads with some small rods or leftover sprues.
Zugock 01
Zugock 02
Zugock 03
Zugock 04
Posted by Chatterer on Monday, September 18, 2006 4:03 PM
Looking good Malich. I am working on the same kit also at the painting stage right now. Keep up the good work.
David
    July 2004
Posted by matthew9 on Monday, September 18, 2006 6:42 PM
Nice progress. I look foward to see how it turns out.
Matt
Posted by Anonymous on Tuesday, September 19, 2006 7:20 AM
Thanks for the comments!
Last night I finished drilling out all of the eye slots and did a bit more sanding on some parts.  Tonight I will drill out the torpedo ports in the head and lay down a piece of styrene inside the head to start building up the base for the mono-eye.
Update: Well I couldn't wait until tonight to continue working so today at lunch I started drilling the torpedo heads out.  I took a nice straight piece off of the sprue and started sanding down the rod to make the torpedo heads.  The fit is nice so hopefully tonight I will be able to cut out the rest of the heads and get them mounted.  Once that is done I will go ahead with the base for the mono-eye.
Posted by Anonymous on Sunday, September 24, 2006 5:28 PM
Here are some updated photos.  The Head torpedoes are in place, the vision slits are cut out, and the shoulders have had styrene added with a bit of detail.  The upper body is almost done.  I still need to finish the work up on the mono-eye and get a few other parts done.  I still have to go back and do some putty work along with re-positioning the arms where they attach to the claws.  After that I can start modding the lower torso and legs.  Hopefully I will have this done in time for a model contest on Oct 28.
Shoulder Armor
Head Pic #1
Head Pic #2
Posted by Chatterer on Sunday, September 24, 2006 5:47 PM
Looking good Malich, those torpedoes look really good. Cant wait to see it done.
David
    January 2006
Posted by PatlaborUnit1 on Thursday, September 28, 2006 1:18 PM
Mailch
all looks good, mine is OOB and Im happy with it, but someday I will update it much like you have yours here. I really wish that the luanch tubes in the head were hollow so we could avoid the drill/sand/prep stage for adding new ammo....
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
Posted by Anonymous on Thursday, July 26, 2007 7:05 PM
Well it's been a long time since I updated this thread but I am back on it so here is an update.
I cut the top of the Zugock's head off and built an internal box to support the Mono-eye.  Next thing I need to do is putty up the base and then add the detail to it.  Not so sure what putty to use though to build up the base.  I have Tamiya grey putty but I was thinking of getting some epoxy putty and covering it with that.  Once that is done and shaped I can start adding the pla plate to mimic the track detail that goes around the head unit that the Mono-eye runs around on.  I really hit a wall with the whole eye thing.  At one point I just wanted to throw the whole thing in the trash!  So we will see how it goes.  Here are two pics of the latest work.  The additional pla plates in the background still need to be sanded around the edges and added to the top for some more height.
I just ordered some parts from Hobby Japan so I am waiting on those to come in.  If anyone knows where I can find Kotobukiya Modeling Support Goods, (MSGs), besides Hobby Japan please let me know.
    January 2006
Posted by PatlaborUnit1 on Sunday, July 29, 2007 8:55 AM
Malich
You can use what the Japanese use, Mori Mori from Hobby Link Japan or any 2 part polyestr putty such as Tamiya 2 part or Bondo 2 part putty for general shaping.  I am using a lot of Magic-sculpt from TAP plastics online and love the stuff. Even regular old 2 part plumbers putty would work for general shaping, but getting the sanding marks out can be tedious.
Looks good so far, better definition for the mono sensor.  I have seen those made up from WAVE and Kotubukaiya (SP?) option parts vernie thrusters and Klenses.
David
Posted by Anonymous on Sunday, July 29, 2007 3:23 PM
Quick Update.
I ended up using Magic-Sculpt for the Mono-eye base.  It went on pretty quickly and without much fuss so no problems there.  I did a bit of sanding and clean up this morning and I am happy with the way it turned out.  Now I am moving on to cutting the styrene strips for the upper and lower parts of the track.  I was thinking of sculpting the eye out of Magic-Sculpt but I think I will try and get the wave parts to make the eye.  If there is one thing I wish I would have done differently it would have been to make the Mono-eye base a bit smaller.  There is always next time though! Smile [:)]
David, you don't happen to know of any other place that sells the Kotobukiya or Wave parts do you?  Hobby Japan is still awaiting a july restock.  It sure would be nice to get parts soon so I can move on to other things! Big Smile [:D]
Rich
    January 2006
Posted by PatlaborUnit1 on Thursday, August 9, 2007 11:50 AM
Rich
 Get ahold of Bobe's Hobby House in Pensacola, they have a LOT of Asian stock and usually stock some option parts.
www.bobeshobbyhouse.com
Give them a call in the morning and see if they can ship you something. I have NEVER been unhappy with them. I try to stock up on those things when I can every now and then, just to have the extra stock.
Posted by Anonymous on Friday, August 10, 2007 7:47 AM
I will definitely check them out and thanks for the info!  I did however end up buying some option parts off evilbay.  Hopefully I will see them sometime next week.
I laid the tracks in place for the mono-eye so now I need to construct the eye and line it up where I want it.  I made the bottom strip of styrene a little too wide.  So I will probably have the eye overlap it.  Next time I will try and get it smaller.  I don't want to sand the edge of the styrene down too much because that will eat into the magic sculpt and create a groove.  I am going to have to replace the struts that hold the crown of the head.  I was thinking of cutting two strips of styrene.  Make one strip the height I want the inside view port to be and the other strip to ride along top of the first strip with a little overlap on the crown connection and body connection.  I plan on leaving the crown detachable.  There is a pin in place which connects the crown to the base unit.  I noticed that you can see from one side to the other where the crown meets the base unit.  So I will have to add some detail to the inside to cover up any holes.  Once that is done I need to glue the substructure to the inside of one half the body and start filling in gaps, etc...  I have also been kicking the idea around of cutting out the existing pegs for the arms and constructing a better shoulder joint.  Not sure if I want to tackle that in this kit since I am already way behind.
While waiting on parts to dry and what not I started working on a 1/144 GM Command.  I will probably keep this one pretty simple though every time I start fiddling with it I think about what I can change on it.  Once I make a bit more progress I will start another thread for it.  For now here are some pics of the latest work.
