ban dai gundam
    November 2003
ban dai gundam
Posted by wildcard2 on Saturday, February 17, 2007 9:52 PM
 I recently started a project build for a friend, its a 1/144 scale ban dai model ...aisle strike gundam... so I open the box this kit looks excellent but the instructions show some strange building icons/symbols there descriptions are in Japanese and i cant read it. just want to make sure I understand before i start.... is there a translation version somewhere, any advice would be appreciated
    November 2004
Posted by Chris_in_Japan on Sunday, February 18, 2007 2:40 AM
If you want to take a picture of the instructions, post them in this thread, and then I will explain it all to you..
Cheers, Chris
On the bench:
                          1/48 RAAF 3 Sqn F/A-18B
                          1/150 /1/160 N Scale Japanese Rail diorama.
    November 2003
Posted by wildcard2 on Sunday, February 18, 2007 11:21 AM
thank you! Ill do what i can from here
    December 2005
Posted by dj898 on Sunday, February 18, 2007 7:27 PM
you can go to www.dalong.net and let us know which page of instruction you have problem as Dalong has put the big scan of every construction manuals for the kits he's built OOB.
people living in glass colonies shouldn't throw nuclear stones.
    January 2006
Posted by PatlaborUnit1 on Monday, February 19, 2007 11:43 AM
the symbols (depending on which sets of instructions you have, what year, etc) should have an English equivelant called out on the face page. I know thier symbols are unusual, they caught me off guard at first, too.
Usually it will boil down to "Do this step first, then install assembly", or "do this and put inside this" which will look like a larger and smaller circle, one black one white.   Follow the flow arrrows, they lead you directly from step to step. Bandai usually starts at one side of the body, rolls around to the other side to finish up, so studying HOW these things go together reallyhelps.
Also if you plan to use the head sensors, put the decal/sticker in place on the "eyes" first before you stuff it all inside the head armor, otherwise it will be hard to get in there.
I much prefer 1/100 scale, bigger parts, oftentimes more detail, but not as "poseable".
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
    December 2005
Posted by dj898 on Monday, February 19, 2007 4:36 PM
and when you have built enough kits you can try the intermediate level skill called "C-Joint mod".
This is basically discard the construction manual and built the kit in such a way that each section can be detached even after the seam line is fixed and sanded.
It was originally came about to fix the seam line issue with the old kits where once you glued you could not easily fix the seam line and etc. By making the female part of pin hole to "C" shape thus allowing the male part slid in after the section was built.
Have a look at my blog for some of sample if you like.
Though they are in Korean - that's why you see a lot of garbage characters on screen - you can still see the pictures. ^__^
http://blog.dreamwiz.com/dj898/5589426
http://blog.dreamwiz.com/dj898/5581480
http://blog.dreamwiz.com/dj898/5589684
    January 2006
Posted by PatlaborUnit1 on Tuesday, February 20, 2007 5:23 PM
dj
The girls are pretty cute too!!!!!
David
    December 2005
Posted by dj898 on Tuesday, February 20, 2007 8:20 PM
and in case you are wondering(?) I don't go around dressed like that...  ^__^
    November 2004
Posted by Chris_in_Japan on Wednesday, February 21, 2007 12:24 AM
I am interest in knowing if what you are refering to are actually symbols. Or are they Hirigana characters?
Hard to know what you are talking about without seeing it..
Chris
On the bench:
