Alterntive color to "Magnesium Metalizer"
Posted by Anonymous on Monday, March 19, 2007 12:07 PM
I'm in the middle of the 1/2500 Enterprise-B and one of the colors it calls for is Magnesium Metalizer for the "neck" of the ship (not sure if that is the proper name) between the primary and secondary hulls.  My local hobby shop carries this color, but it is an airbrush-only paint.  I asked the owner if it was still possible to brush-paint it, but was told that it wouldn't really work.
Does anyone have any alternative color suggestions that is the same as Magnesium?  I looked at Steel and Aluminum, but neither really looks right.
 Thanks.
    January 2006
Posted by PatlaborUnit1 on Tuesday, March 20, 2007 1:29 PM
airbrushing is the way to go with this and you can get testors Metallizer magnesium in spray cans.  Magnesium is a light colored metal, you can go the Alclad route but I take it your staying away from airbrushing.  Metallics must be put on in THIN layers to look right.  Another choice for you could be RubNBuff wax based metallic pigmentfrom Hobby Lobby.
HTH
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
    December 2005
Posted by dj898 on Tuesday, March 20, 2007 6:33 PM
I can tell from the experience that you cannot paint brush these Testors metalizers to achieve the look. It simply doesn't work.
people living in glass colonies shouldn't throw nuclear stones.
    June 2003
Posted by Silverback on Thursday, March 29, 2007 2:03 PM
While you can brush paint MM Metalizers, they are only effective on large areas if airbrushed.  A better alternative, if you are not into the airbrush thing, is to apply one of the art wax treatments such as Rub 'n Buff.  Depending on how carefully you are with the application and buffing procedure, you can achieve some amazingly realistic metallic finishes.
Just be sure to mask surrounding areas, because these wax treatments can get really messy before they set.
Phil
