Honestly, I don't know much about what the model is supposed to represent. The box describes it as an "experimental stealth combat robot". Good guy or bad guy, I got no idea.
My initial idea was to have it in a hanger bay/science lab setting, with a little scale control panel nearby and spotlights inset into the floor shining up at it to give it a sinister aspect. When I was putting all that together however, I realized the base would cost 3 to 5 times as much as the kit itself...so instead I went as cheap as possible, and mounted it on a piece of PVC pipe that cost $3 at Home Depot.
The model cost $8, the base and incidentals were around $5, and the WF '05 contest entry fee was another $5, for a total of around $18 to $20. That's got to be one of the cheapest awards ever.
The figure is exactly 6 inches tall, and the base is 4 inches wide by 3 ½ inches tall, so it's just a bit over 9 1/2 inches (when you figure in the sheet styrene end caps).
The most tedious aspect of the build was all the seam work. All those compound, complex curves had to be perfectly smooth, otherwise they would be plainly obvious. I had to sand off the detail on the sides of the neck, and then replace it w/ cardstock cut to shape and detailed w/ a Waldron punch and die set. You can kinda see it in the second and third pictures.
Masking it was no picnic either.
In the end, I liked the results. I hope you did too.
Thanks for the feedback.
