B-Wing 1/72 WIP finished
Posted by ssgkopp on Saturday, January 19, 2008 3:36 PM
 So far i have replaced the barrels for all the blasters, i have added the open panel on the back edge of the main wing and i have also drill into the wing from the top close to the outer edge. Once I burned through just a little i pulled the drill out and placed a small piece of brass rod in. So once painted it will have the blast damage and show a little metal through it.
I will be replacing the chin guns also and doing some things with the cockpit.
Well here are the pics
    January 2006
Posted by PatlaborUnit1 on Sunday, January 20, 2008 6:10 PM
Your mods look good here, pics are a bit fuzzy. Would love to see more especially of how you work with the cockpit. Are you planning any lighting  mods? also what color scheme you going with?
thanks for posting
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
    January 2006
Posted by KirkTrekModeler on Monday, January 21, 2008 11:21 AM
Great work. This is another one of the kits that I've always wanted but could never find. Looking forward to updates on this.
Posted by ssgkopp on Tuesday, January 22, 2008 3:31 PM
Better Pics
Not all the guns are glued together so that is why a couple look crooked. Also i love Wave black CA and Mr. Surfacer 500. Im going to prime the canopy later today and see what it needs. I got about another 20 min worth of sanding to do on it and a little work still on the cutout windows.
Posted by ssgkopp on Tuesday, January 22, 2008 4:00 PM
Also working on my two pilot idea for this build. I have seen one side veiw of a fan made two pilot B-wing so im going to try that.
Looking for a cylinder shape around the house and my daughter yells to me hey will this work? She hands me her stick glue tube thingy and there you have a perfect fit for both pilots and a small magnet.
so here is the in prog pic of that.
any comments would be great.
    January 2006
Posted by KirkTrekModeler on Tuesday, January 22, 2008 5:27 PM
That's really looking good. Great work, can't wait to see more.
Posted by ssgkopp on Tuesday, January 22, 2008 6:03 PM
Hit the canopy with some primer to show where the bad spots are.  Going good so far.
    February 2007
Posted by PetarB on Tuesday, January 22, 2008 10:35 PM
Lighting this kit would be quite difficult, but the thought crossed my mind when I got hold of mine. I'm sure ssgkopp is probably sick of removing resin by now!
www.studiostarforge.com
    December 2007
Posted by Cosmic J on Tuesday, January 22, 2008 11:37 PM
Is this a resin kit, or one of the plastic ones? The surface detail looks pretty good.
    January 2006
Posted by PatlaborUnit1 on Wednesday, January 23, 2008 12:20 PM
the new pics look good and re giving us a much better appreciation of the work you are putting in.
I lit m Tyderium shuttle.......freakin nightmare.....went about it using Minimag bulbs and a flashlight bulb / reflector setup in the cockpit and engine nacelle.  Won't do that again!
 I like the twinned cockpit. Thinking of adding a defensive turret like on the Y wing?
David
Posted by ssgkopp on Wednesday, January 23, 2008 3:10 PM
Its a resin kit put out by fantastic plastic
thx for the comments
Posted by ssgkopp on Thursday, January 24, 2008 8:52 PM
Well i got a little done today.  Should be able to finish most of the build this weekend as i have a 4day pass.
Started to open out the vents on the front of the wing using a pin vise and different files. You can see a slight bow in the wing, Ill fix that when i wet sand everything and wash it for painting.
Here is just a shot of the wing.
This is the seam between the engine housing and the engine vents. I smoothed out MR. S 500 and then started to clean it up a little.  Some small detail will be replaced with some styrene later on. Also got the holes drilled and some pins for support measured and cut.  Even the little one that is in it now makes the fit better.
And here it is all pinned together
Still working the Cockpit but i have hit a mind block.
    January 2006
Posted by KirkTrekModeler on Thursday, January 24, 2008 10:36 PM
Very nice. Who is the producer of this kit, is this an AMT / MPC kit????
Posted by ssgkopp on Saturday, January 26, 2008 3:39 PM
This kit is avalible from FAntastic Plastic
Alright here is my cockpit concept work so far. Now understand this is my first time ever doing a major conversion/scratch built parts. Well ihave hte main look down and have started to cut some armor panels to go on the new section.
Also working the insides with the second pilot facing the rear to a back of ECM/Gun equipment back there. Also he has a good field of view to help the pilot identified incoming bodies from different angles.
Constructive criticism is more then welcome as i want this two seater version to work and look good. I think im onto a good start but may need some pointers from so of you experts out there.
    January 2006
Posted by KirkTrekModeler on Saturday, January 26, 2008 5:38 PM
I think you're doing a great job. I'm not familiar with the kit and am not an expert by far.
Posted by ssgkopp on Sunday, January 27, 2008 6:37 PM
painted cockpit
    January 2006
Posted by KirkTrekModeler on Sunday, January 27, 2008 9:59 PM
Very good, fantastic..... Er....uh....BTW is Fantastic Plastic a garage kit? I thought that kind of thing was not allowed.... Advertising garage kits, kind if thing...??? Sorry, just curious.
Posted by ssgkopp on Monday, January 28, 2008 9:04 AM
Don't start this stuff with me! You asked a question and I gave you the answer. Do not try to turn this into something its not.  Do I go into your threads and say stupid remarks.  Comment on my work on the kit not your own personnel motives whatever they may be.
    January 2006
Posted by KirkTrekModeler on Monday, January 28, 2008 9:52 PM
I'm not, not at all, just curious. i think the work you're doing is fantastic and seriously considering tracking one of these kits down. I've never had a B-Wing of any kind and have always wanted one.
    January 2003
Posted by cthulhu77 on Tuesday, January 29, 2008 12:18 PM
 Yeah, helping out the little companies would be terrible!  After all, they are just trying to make an even break on the immense amount of work that they do...
  They are a real threat to Tamiya and the other advertisers who pay fsm. Yipes.
   Not trying to be an ***, but this sort of thing is usually better sent in a p.m., isn't it?
http://www.ewaldbros.com
    January 2006
Posted by KirkTrekModeler on Tuesday, January 29, 2008 1:54 PM
I totally agree with you, that's why I still find it amazing that so many made such an effort to shut down my lil business. I think one of the big issues here is that it's against the rules to post advertisements of garage kits. I only know that because when I was still attempting to give the community a decent 1/350th Enterprise, at a decent price and made the attempt to show my craft here I was immediately shut down while others persisted. I just want to make sure that no one gets in trouble for the same thing I did. Now that I no longer have a kit coming out and no longer have a business thanks to the efforts of people I don't even know, I can see where it might not be appropo. I was really blind to the whole ting until I had several "copyright" discussions on several different boards. I then realized that no matter how you dress it up, if you don't own the copyright and don't have permission to copy the product then you are essentially stealing. Look what Lucas did to SM, look what happened to some of the other GKers that crossed the line. I really don't want to highjack this thread any further. I sincerely appreciate the authors work and would like to see it continue without further ado, sorry to have brought the subject up. Just want to make sure the playing field is level and no one else gets into trouble. If you wish to discuss it further, please drop me a PM, or e-mail. Thank you.
Posted by ssgkopp on Tuesday, January 29, 2008 10:24 PM
 KirkTrekModeler please take your rants somewhere else. Commenting on the work is fine but stop this stupid agrument here.  If you need to get it out then PM someone and tell them.
well I opened up the canopy housing piece and placed a small washer in side. With a small magnet attached to the back of the cockpit it worls out really good. All the major pieces have been painted the base colors for the most part.. I have to mask up a scheme and hit it with some Dark sea blue or azure blue for the look i want. The canopy itself is a continuing work in progress. Sanding, priming, filling sanding etc.
Looking at the figs that PeterB is making I will not completely glue up th ecockpit pieces as i would like to get a couple of those nice pilots in this baby.
    December 2006
Posted by Lord Darth Beavis on Wednesday, January 30, 2008 5:10 AM
That's looking mighty nice.  Keep up the great work!
LDB
Aficianado of great garage kits
I lied to get the job. They lied about the job. I'd say we're even. I hear...stupid people! Member of the Global Conspiracy since 2007
    January 2006
Posted by KirkTrekModeler on Wednesday, January 30, 2008 9:33 AM
I wasn't ranting, just addressing a post and I think if you reread the post you will see that it was I who asked the other member to contact me via PM, so that this thread would remain on track. Also, please note that I have been interested in and supportive of this thread from the beginning and very interested in your work.
BOT Great work, enjoying the updates.
    February 2007
Posted by PetarB on Thursday, January 31, 2008 7:13 PM
Looking good!
    January 2008
Posted by ModelX on Thursday, January 31, 2008 9:01 PM
awsome work
Model eXcellence
Posted by ssgkopp on Friday, February 1, 2008 4:20 PM
thx guys
Got some masking and painting done this afternoon thanks to a snow store and my otherwise bored self. I masked with both tamiya tape and some self adhesive friskit film that came with my Iwata HP-C plus kit. THe stuff works great. I used Navy Blue Grey for the color and im really happy as it goes well with the other greys i already used.
Ill let the paint cure for a day or two they hit it with some gloss clear and start the decals and wash the close it all up with a dull coat and do some weathering.. I can see the home stretch now.
Posted by ssgkopp on Saturday, February 2, 2008 2:27 PM
here it is assembled.  Need to Dull Coat it now.  and then figure out the base thingy.
    December 2007
Posted by Cosmic J on Saturday, February 2, 2008 4:26 PM
Big Smile [:D] What's wrong w/ the flesh colored base its on now?
Posted by ssgkopp on Saturday, February 2, 2008 4:29 PM
that base will wither up and die before the modle turns to dust!!!
