U.S.N.camo schemes during WWII
    July 2003
Posted by diggeraone on Wednesday, August 6, 2008 3:40 AM
I need your help in camo schemes and any pics or drawings that could be found,thanks Digger.
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
    January 2007
Posted by dahut on Wednesday, August 6, 2008 7:08 AM
EDITED FOR BEING A DUMBA**
See, I was thinking airplanes not ships words. Belay my last...
Cheers, David
    July 2006
Posted by Dick McC2 on Wednesday, August 6, 2008 7:20 AM
Try the below site... I found it to be very helpful....
http://www.shipcamouflage.com/measures.htm
Dick McC
    March 2007
Posted by JMart on Wednesday, August 6, 2008 8:07 AM
Sign - Ditto [#ditto] that one is the best web site for this info by far....
    June 2007
Posted by jazzy_jeff on Wednesday, August 6, 2008 10:47 AM
Dick McC
 +1
 and if you can't find the exact measure you are looking for, try this one:
http://nautilusmodels.com/camouflage.htm
there are a bunch there that are not on shipcamouflage
 Jeff
    March 2005
Posted by mfsob on Wednesday, August 6, 2008 11:17 PM
The answer is - it depends. On what time period you're interested in for the particular ship you're building. And the type if ship. The Measure 32 midwar disruptive scheme, for instance, would look quite different on a light cruiser as compared to an attack transport.
    August 2005
Posted by Surface_Line on Thursday, August 7, 2008 10:26 AM
We're mixing some terminology here - not exactly apples and oranges, but more like apples and apple pies.
 The first site provided, the Ship Camouflage site, provided colors only.  That is referred to as the Measure.  Measure 21, Measure 32, etc.   Some Measures are the same for every ship, and some require speacial Designs (also known as Patterns, and requested in this thread as "drawings"). In all cases, the Measure is the palette of colors to be used, and in some cases, the Measure will prescribe where those colors are to be applied.  And in other cases, that palette is to be applied in particular Designs.
The second site provides some of those specific Designs, which were custom-made for particular ship classes.  So a Design 10A is for an Aircraft Carrier, specifically drawn for an Essex class.  (And just to keep it fun, sometimes a design was used on a different type of a ship, but every rule has exceptions).  The Designs were, however, only meant for a particular measure.  I do believe that you will never (There's a cocky statement to make!!!) find a case of a Design 4A used with any Measure other than 32.  (See the Nautilus site to see what I'm referring to)
I will keep this short, but it could be a very long dissertation.
Rick Heinbaugh
    July 2003
Posted by diggeraone on Thursday, August 7, 2008 7:00 PM
I want to thank ya'll for your help in this.This has help me a lot,Digger.
    March 2005
Posted by mfsob on Friday, August 8, 2008 7:54 AM
We were helpful? Rats ... gotta dial up the "confusion" a bit more the next time I post Big Smile [:D]
    August 2005
Posted by Tracy White on Saturday, August 9, 2008 1:40 AM
 Surface_Line wrote:
The first site provided, the Ship Camouflage site, provided colorsonly.
Uhhh Rick...  when was the last time you went through the camouflage database there? Not only do we list and link to the camouflage measure, in many cases (in some classes, all cases) we also link to the pattern. Check out aircract carriers, heavy cruisers, and Buckley Class DEs for example.
Tracy White Researcher@Large
    August 2005
Posted by Surface_Line on Saturday, August 9, 2008 2:05 AM
I apologize, Tracy.  No slight was intended.
    August 2005
Posted by Tracy White on Saturday, August 9, 2008 8:22 PM
None taken, we just want people to know about the resources available.
For what it's worth, I added two more design sheets this week.
