Mounting your ship model?
Posted by lolok on Friday, November 28, 2003 2:55 AM
We are an inventive bunch of modellers here,so I was wondering what different methods you use to mount your models on a wooden base. Flat bottomed battleships are fairly easy to mount but what about the sailing ships and suchlike? What do you use as a mount? Wood,Metal Rod,Acrylic rod or brass fittings. If Brass,what kind?Smile [:)]
Jim Ryan Ex-Pat Limey in warsaw.Poland. " MENE,MENE,TEKEL U PHARSIN"
Posted by Big Jake on Friday, November 28, 2003 4:25 AM
If it has a defined keel, I usually buy a set of brass pedistels (sp) and mount them from the insde with screws.
Jake
    January 2003
Posted by therriman on Friday, November 28, 2003 11:47 AM
I've got a lamp supply store nearby I buy brass pedistals from. Drill holes in the bottom of hull and in board and mount with nuts inside of model, and bolts in board.
Tim H. "If your alone and you meet a Zero, run like hell. Your outnumbered" Capt Joe Foss, Guadalcanal 1942 Real Trucks have 18 wheels. Anything less is just a Toy! I am in shape. Hey, Round is a shape! Reality is a concept not yet proven.
Posted by Anonymous on Friday, November 28, 2003 4:06 PM
The brass lamp parts do indeed make good pedestals. For keel ships you can use four rather than two. You can bevel one end with a file to angle them as well.
For my corvette I am planning to put her on blocks like in a drydock, at least initially. This method is popular with small large scale ships.
You can also make wood or metal cradles. Use a piece of card stock to make a template of the hull shape so you don't mar your finish. You can also line the edge of the cradle with felt for the same reason. This works well for operating models that are taken off the base to sail.
For my models I always finish the display base with a glass or plexi enclosure to keep dust off.
Enjoy!
Bruce
