Batavia
    December 2006
Batavia
Posted by woodburner on Sunday, January 4, 2009 6:39 PM
I've been working on a Revell Batavia over the past few months, and here are some progress shots. Right now the majority of parts are painted, and I'm still working on the detail painting for sculptures and so on.
The paintwork is based on the Texel Diorama models, early 17th century Dutch paintings and first hand evidence from Wasa. There is a lot more work to do, mostly in the side galleries and the sculpted borders of the upper stern.
Sorry for the fuzzy photos.
Jim
    January 2006
Posted by RedCorvette on Sunday, January 4, 2009 6:46 PM
Looks nice.  Good work.  Looking forward to seeing your progress.
Mark
FSM Charter Subscriber
    May 2007
Posted by RTimmer on Sunday, January 4, 2009 6:48 PM
Jim,
Very nice and thanks for sharing.  Did you pick this kit up on e-bay, or was it one you've had in your "stash"?
Lookin' forward to your updates.
Cheers, Rick
    September 2005
Posted by warshipguy on Sunday, January 4, 2009 7:10 PM
You are doing a fantastic job!  I remember picking the Batavia up when it was first released (1990's).  That was the only time the hobby shop carried it.  I have never seen it in hobby shops since, nor have I seen it in Revell catalogs.  Given the expressed interest that many of us have shown in this kit, Revell should consider re-releasing it.  We should all consider writing them to let them know.
Bill Morrison
    June 2006
Posted by Grem56 on Monday, January 5, 2009 10:02 AM
Your woodwork is out of this world. I just love that aged wood effect.
Check out these links for some photos of the real deal:
/forums/771443/ShowPost.aspx
/forums/771440/ShowPost.aspx
cheers,
Julian
illegal immigrants have always been a problem in the United States. Ask any Indian.....................
Italeri S-100: http://cs.finescale.com/FSMCS/forums/t/112607.aspx?PageIndex=1
Isu-152: http://cs.finescale.com/FSMCS/forums/t/116521.aspx?PageIndex=1
    January 2007
Posted by Pavlvs on Monday, January 5, 2009 10:25 AM
Beautiful!! How did you get the wood to look so aged and real? I have a couple of sailing ships in my stash and I would love to replicate your technique.
Deus in minutiae est. Fr. Pavlvs
On the Bench: 1:200 Titanic; 1:16 CSA Parrott rifle and Limber
On Deck: 1/200 Arizona.
Recently Completed: 1/72 Gato (as USS Silversides)
    February 2008
Posted by enemeink on Monday, January 5, 2009 10:26 AM
so beautifully done. can't wait to see more!
"The race for quality has no finish line, so technically it's more like a death march."
    December 2006
Posted by woodburner on Monday, January 5, 2009 1:48 PM
Thanks for the comments.
Batavia is an excellent kit in many respects, well designed and nicely molded. There are some superb details, especially in the sculpture. Its also molded on both sides of the hull, allowing for full interior detail above decks. The hull planking is smooth, so the wood effects require a specific method.
The method is simple, and here it is, using acrylics:
First, paint the hull in a wood color base. I used Testor's "wood."
Then, apply a thin wash of black to darken the color and highlight details such as the wales and so on. The wash will soak into the flat "wood" color and become a fixed aspect of the undercoat (you will see why in step four).
Then, apply a thinned wash of artist's acrylic transparent burnt umber - I think I use Liquitex from the art department of my local hardware store. This will give the "body" of the wood and deepen it for the "tarred wood" look.
Now for the fun part. With a wide brush, give a wash of common household rubbing alcohol and let it sit for a minute or so. Then take a somewhat wide, used, chisel brush, and brush the hull sides in the direction of the planks. This will scoot the transparent burnt umber around on the surface without affecting the "wood" and tinting black coats below. It will also give the effect of planking and grain on a solid, smooth, plastic surface.
Finally, wait till dry and touch up where desired with thinned black or burnt umber, and when dry again, a wash if needed of the alcohol to kill any sheen (dont brush it around, though, just one quick wash on and let it dry).
This method is impressionistic, and as you can see from the photos, looks best when seen from a few feet away, which is, I think, how most of us look at a model. Its a good idea to test this out on a practice model or maybe the ship's barge to see how it works and get the hang of it.
There are a few other things: paint the underwater hull and mask off first, and I made "rivits" and "treenails" from a permanent ink marker onto the hull at step two. I also marked off the gunport hinges but the ink wiped away during the process, so I have to re-mark them. Batavia has three open gunports on each side: I closed some off for a different look, with two open on one side, one on the other. The gunport lids are painted the same way, and I used natural "wood" for the interiors, as contemporary paintings show both red and unpainted lids at this time.
The interior of the hull is done the same way.
The upper works are painted light blue and will get a wash of thinned black to highlight the clinker construction, and perhaps a wash of burnt umber to tone down the blue color. The rails are based on a Texel diorama model, with the lower moldings in ochre yellow, the upper in dark blue-grey. I wanted to "lower" the height of the stern castle and this is a visual trick that works well.
The carved work is polychromed based on evidence from Wasa, and I chose less elaborate colors that would be more suitable for a merchant ship. There is more to do - beards for the men on the gallery sides, and so on. The mermen on the ship have blue-green bodies with red tails, based on a Dutch painting. The sides of the taffrail are carved but the model's detail is kind of spotty here, so its going to be giving the illusion of carved work using different colors. I'm dreading this.
Rick, this was in the stash, next to a Wasa. Its sort of practice for Wasa because Wasa is all tarred wood, including the underwater hull (no evidence from the actual ship survives for whiting, and operating in Baltic waters perhaps not thought necessary). The upperworks, with rich red clinker work and tons of carvings in different colors, are going to be a real task.
The real treat here was to try out the Artitec method used in painting the Texel Diorama models, modified for acrylics. I have one comment here that could be helpful, since Batavia is a smaller scale than the Artitec models - Artitec has the entire hull, sculptures and all, done up in the wood color, which tones down all the painted work applied over it beautifully. But in smaller scales, it's better to confine the wood base to those parts of the ship that will be seen as wood, and avoid any extra layers of paint on the tiny sculptures. Learned this from experience. Yup.
Julian, those photos of the replica have been invaluable. Just to see the actual ship has allowed me to undersrand what's being represented on the model, and how the effects of weather and wear tone the ship over time. There are have been many times I looked at a specific sculpture detail to understand what the model's tiny blob of plastic was representing. This was especially valuable for the figures which flank the stern windows, and along the gallery sides. Thank you very much for posting them.
Cheers,
Jim
    January 2007
Posted by Pavlvs on Tuesday, January 6, 2009 8:59 AM
Jim,
Thanks so much for your tutorial. I am eager to try it. I can't wait to see how you do that mural on the transom just above the rudder in the photos of the "real" ship. You could print yourself a decal for it perhaps.
Please keep showing pics.
    December 2006
Posted by woodburner on Tuesday, January 6, 2009 3:54 PM
Thanks for the good words, I hope the method works out for you!
I thought about a mural, but decided not to use one, for two reasons:
First, it seems that paintings of this type were actually used between the 1640s and 1670s, slightly later than Batavia's time. The 1620s ship Wasa, which had a much finer program of decoration, and would likely have used one if it was the style, did not have them. On Wasa, the lower section was divided into panels with sculptures instead.
(There is evidence of a murals before this, in the Armada painting of ca. 1596-1600. It's shown on an English ship below the windows, and not on the lower sections. Its the oldest example of a mural I've found, too, and surprised me very much. But it seems a different location and tradition than the Dutch style of the 1640s-70s).
I think that the original design for the replica Batavia was to follow Wasa, but at some point a decision was made to use the mural instead. Revell's model seems to have been made from initial reconstruction plans, while the ship's construction was just beginning, so this area has brackets where sculptures would go, similar to Wasa.
So that leads to the second reason. To use a mural, you would want to add a styrene curve to this area to create a smooth planked surface for the painting to go on. The "paneled" beams on the model would not make an easy surface for a landscape painting! I thought about adding a curved surface, but the weight of evidence from Wasa suggested I wanted to go the more old fashioned route.
If you did want to use a mural, the decal is the way to go, and home printers make this easy. First, make the styrene insert for the curved surface. Trace it out on some paper so you have the shape before installing it on the model. Second, find a 17th century Dutch landscape painting, resize it to fit the template, and print it onto white or clear decal paper. If you use clear, paint the styrene white. White decal paper might work better, since the whole area is painted. If you do this I would like to see how it comes out.
Cheers, Jim
