Painting the Fletcher
    July 2006
Posted by constructor on Monday, January 26, 2009 4:41 PM
I'm building the Tamiya 1/350 USS Fletcher and I'm mixing the paints needed. I was just wondering if the deck blue specified (hull red + field blue, that's in tamiya enamels) will be the same color for all the WW2 US Navy ships? I find it a little too dark though.
    August 2005
Posted by EdGrune on Tuesday, January 27, 2009 8:09 AM
If you are choosing to go with Tamiya's color mixes only, then yes their mix for 20B Deck Blue would be correct for all WWII USN deck blue applications.
However, and it is a big however,  Tamiya's color mixes are intended to sell Tamiya paint.  Their color selection is not the most accurate.   The most accurate source of USN WWII colors is in the White Ensign Models Colourcoat line of enamels.   Testor's used to make a line of acrylic naval colors which were based on these paints but they are now out of production.  Some may still be available direct from Testors or in some online sources.
If you still intend to mix your colors, then perhaps you should invest in a set of Snyder & Short paint color chips as a standard reference.  These are available from White Ensign Models or from shipcamouflage.com.   They are paint (not ink) which has been correctly matched to the 1929 Munsell color reference used by the US Navy as the period standard.
    August 2005
Posted by Tracy White on Tuesday, January 27, 2009 3:24 PM
As a minor point of correction, the Testors/ Model Masters paints that Ed mentioned were matched to the Snyder & Short color chips and not the WEM paints. Snyder & Short is at http://www.shipcamouflage.com/ and more information on the color chips can be viewed here.
Also available there is the Ship Camouflage Database.
Tracy White Researcher@Large
    July 2006
Posted by constructor on Tuesday, January 27, 2009 4:42 PM
Thanks guys, your'e a big help
    May 2003
Posted by jtilley on Thursday, January 29, 2009 12:37 AM
I don't have any information to add to the knowledgable posts above.  I would, however, strongly urge anybody with a tendency toward obsession with "accurate" warship colors to take a look at this Forum thread:  /forums/1/987616/ShowPost.aspx#987616 .
    March 2007
Posted by searat12 on Thursday, January 29, 2009 1:35 PM
A good thread Professor!  In my 'good old days' the place to get models was Woolworths 5 & 10 cent store... They always had a supply of the small Pyro kits that could be had for cheap, and the Testors paint too, and if you didn't like the selection at one, there was always another Woolworths that you could peddle to in the next village square....
    August 2005
Posted by Tracy White on Friday, January 30, 2009 2:00 AM
Good points, but I find it easier to START with accurate paints before adding weathering and scale light.
Your four-piper experience is what I liketo call "Adventures in Metamerism!"
