This is Ship related, I promise
Posted by Big Jake on Wednesday, February 25, 2009 8:27 AM
OK, Here goes AND I just know I deserve some ribbing over this.
Over the 4 day weekend (Marti-Gras in New Orleans)  I started 2 large deck projects in my front yard (I have an acre). I'm building the decks around a few old growth oak trees.  In the pictures, you will see the deck layout.
http://home-and-garden.webshots.com/album/570241977kdoDls
I'm also going to build a tree house for the grandkids in the trees and tie that into both decks.  The lower deck will have a slide going to it from the tree house.  The higher deck will have a "rock" climb and ARE YOU READY FOR THE SHIP RELATED ITEM.  I want to make a ratline going up to the tree house deck.  However, I need some help finding how to tie the knots. What is the name of the knot used in tieing the ratlines. I have a source for learning how to tie.
    March 2004
Posted by subfixer on Wednesday, February 25, 2009 10:55 AM
Use a ratline knot.     But really, I have a feeling that it will be a "hitch" and not a "knot". Try using a clove hitch. Make it tight.
I'm from the government and I'm here to help.
    February 2008
Posted by enemeink on Wednesday, February 25, 2009 10:58 AM
it's a clove hitch
"The race for quality has no finish line, so technically it's more like a death march."
    May 2003
Posted by jtilley on Wednesday, February 25, 2009 12:09 PM
The absolutely authentic way to do it (if you're replicating the eighteenth, nineteenth, or twentieth century) is to make an eyesplice in each end of the ratline, seize the eyesplice to the foremost and aftermost shroud, and tie the ratline around each intervening shroud with a clove hitch.  I'm not sure I've ever seen a model with eyesliced ratlines.  (Maybe the 1/2-scale whaler at New Bedford?)  My inclination in this case would be to rig them the way I usually do on small-scale models:  tie the ends of the ratlines to the foremost and aftermost shrouds with a reef knot (aka square knot), and to the intervening ones with clove hitches.  If you use clove hitches for the foremost and aftermost ones, there's a good chance that they'll come loose.
Sounds like a fun project, Jake.  Good luck with it.
Posted by Big Jake on Wednesday, February 25, 2009 1:44 PM
That's the ticket, I could not remember a Clove Hitch knot.  I plan on making at least  4 shrouds about 5 feet in the air. I post some pictures.
Check this out
 http://www.animatedknots.com/cloveboating/index.php?LogoImage=LogoGrog.jpg&Website=www.animatedknots.com
    March 2007
Posted by searat12 on Thursday, February 26, 2009 9:07 AM
You might also try a tautline hitch/prussic knot for the first and last shrouds, with the  loose end seized to the shroud as well, with clove hitches on the inner shrouds......
