1/350 destroyer bootstripe width
Posted by airtrans Crash on Friday, March 6, 2009 7:27 PM
how wide should the boot stripe on the hull of my Buchanan be? I am prepping to cut the tape for the mask but realized this is something I didn't figure out yet.
 A man's country is not a certain area of land, of mountains, rivers, and woods, but it is a principle; and patriotism is loyalty to that principle. ~George William Curtis
    November 2006
Posted by Grandpa1949 on Friday, March 6, 2009 8:54 PM
The "Painting & Markings" page of the instruction sheet is in 1/350 scale. You can get your measurements off of that!
Posted by airtrans Crash on Friday, March 6, 2009 9:04 PM
that's my problem, the painting diagrams are smaller than the actual model and there are no measurements written to give me direction. I could guess but I dont want to screw it up.
    March 2007
Posted by searat12 on Friday, March 6, 2009 9:22 PM
You might try blowing it up on your printer.... fiddle around until it is to scale!
    August 2005
Posted by sumpter250 on Saturday, March 7, 2009 11:07 AM
It's been over 40 years since I had to paint a bootstripe. My memory is that the bootstripe, on a Sumner class DD, was no more that 12", which would be .034" in 1:350 scale. If you went as large as .040" it wouldn't "overdo it".
Lead me not into temptation ..................I can find it myself
    August 2005
Posted by EdGrune on Saturday, March 7, 2009 11:50 AM
On the common instruction sheet which is in both of the 1942 and 1945 versions of the Buchanan there is a full-scale painting diagram.  The '45 version has a smaller supplemental instruction sheet.   I pulled mine out and using the calipers, the boot stripe came out to 0.105 inches (+/-) wide.
That scales to 36.75 inches at 1:350 scale.   Slice your tape to 0.103 for 36 inches or 0.10 for 35 inches.   I'm lazy.  I use 3M vinyl automotive pinstripe masking tape which is 1/8 inch (0.125) wide.  That scales to 43.75 inches -- but its close enough for government work.
Posted by airtrans Crash on Saturday, March 7, 2009 9:20 PM
thanks for the help... I am most definitely ok with "close enough for government work" LMAO
Posted by Anonymous on Monday, March 9, 2009 2:40 PM
...just what was the bootstripe for?...to keep the grey paint from sliding down?
    April 2005
Posted by cruichin on Monday, March 9, 2009 2:44 PM
It was in place to hide the scum that accumulates in harborand adheres to the ship's side.
Steve
    August 2005
Posted by Tracy White on Monday, March 9, 2009 6:25 PM
Scum in this case being things like oil that left unsightly stains and perturbed admirals
Tracy White Researcher@Large
Posted by airtrans Crash on Monday, March 9, 2009 6:31 PM
now you guys are educating this Zoomy on Navy stuff. Thumbs Up [tup]
Posted by CapnMac82 on Tuesday, March 10, 2009 4:52 PM
Preturbing Admirals being bad generally, too. (Worse than swans, really<g>)
But, in wartime, the bootstripe would sometimes be larger than in peacetime, if my memory serves.  Wider stripe means that harbor does not have to be as calm to apply hull paint, especially when using hanging planks.  Slightly more work if using punts/flats along side.
Boot topping (alternate terminology for boot stripe) also sealed the edge between copper-containing bottom paint and the "ordinary" hull paint.
    August 2005
Posted by Tracy White on Wednesday, March 11, 2009 5:13 PM
It can also depend on the class of ship. Some of the Navy ful ships had HUGE boot stripes since they were constantly changing draft in large amounts.
    August 2008
Posted by tankerbuilder on Saturday, March 28, 2009 3:41 PM
MANSTEIN ! I am ashamed of you . Didn,t you know that the bootstripe was there to tell where after a few monthe at sea the rust stopped? Then you paint grey up ....tankerbuilder
