How to attach superstructure after painting?
    October 2005
Posted by usmc1371 on Wednesday, April 22, 2009 8:59 AM
Hey guys,
I have a question on how to attach the superstructure of a ship after painting. I usually build armor were almost everything is glued together before painting. I'm currently working on a 1/700 scale ship. I've read about "painting as you go" and attaching superstructure parts after they are painted. How do you actually glue the painted pieces together? For instance, you have a deck that has been painted and you need to attach the superstructure to it, wouldn't the paint interfere with the gluing? Do you scrap the paint away first? Do you mask the area before painting? Do you just hope for the best? Need some simple help here. What's your technique?
-Jesse
    June 2008
Posted by Spotty on Wednesday, April 22, 2009 9:36 AM
I scrape or sand away the paint. But I ain't no expert either. Confused [%-)]
    August 2005
Posted by sumpter250 on Wednesday, April 22, 2009 11:13 AM
I have tried both before and after painting methods. When painting first, paint has to be scraped, or the area masked. When assembling first, masking has to be done for each color......to me that's six of one, half dozen of the other. I complete the build, and mask and paint after assembly, unless there is a requirement for interior painting, that has to be done before assembly, as in the junkbuild I did in the Sci Fi forum. I don't have any problem with masking, and it isn't any more annoying for me than scraping off paint before gluing. I just prefer painting after assembly is done.
Lead me not into temptation ..................I can find it myself
    February 2004
Posted by chris hall on Saturday, April 25, 2009 5:15 AM
 I just cement the superstructure sub-assemnlies together using superglue. Since most model ship superstructures aren't load-bearing assemblies, strength of join isn't really of the essence. I then give the completed model a couple of coats of matt varnish, which disguised any superglue that got where I didn't want it.
Works for me:
Cheers,
Chris.
Cute and cuddly, boys, cute and cuddly!
    September 2005
Posted by warshipguy on Saturday, April 25, 2009 1:37 PM
My masking skills are such that I prefer to build each superstructure subassembly, then paint it before final assembly.  I use ZAP (green bottle) cyanoacrylate glue for the final assembly.  If I get CA where I don't want it, I allow it to dry, gently sand it after drying, provide touch up paint, then overspray with a clear matte coat.  This method is more effective for me than masking after assembly.
Bill Morrison
    August 2008
Posted by tankerbuilder on Tuesday, April 28, 2009 11:15 AM
  Hi! When I build anything I always leave the immediate area near a seam or gluing area unpainted . Then after the glue dries I just touch it up . This has worked for me for over 40 yrs.   tankerbuilder
    February 2006
Posted by Wilbur Wright on Tuesday, April 28, 2009 12:26 PM
Yes the paint would interfere with styrene welder/cement.
I use super glue in any case like this.
Always dryfitting before hand.
    August 2008
Posted by tankerbuilder on Saturday, June 20, 2009 11:00 PM
  SEMPER -FI __ The trick I use is to put the superstructure parts on the deck , and then , scratch a line around the structure with an x-acto blade tip or a scratch awl . then there will be a line up to which you paint .that way you have a nice clean area to apply glue to .. -------TANKERBUILDER
