WIP, Tamiya 350 Enterprise
    July 2007
Posted by Lord-Dogbert on Thursday, May 7, 2009 6:07 PM
Long ago I told my wife I wanted the Tamiya Enterprise. I got it for xmas about 14 years ago and it sat on a shelf. Last year my 7 year old got me back into modeling so I decided to take the box down, open it up and start in on building her up. I'm about 6 months into on/off construction and I attached pics of where i'm at. I wish I thought of taking pics and documenting before now as some cool engineering of the hanger deck support has been since covered.
My ultimate goal is to display the carrier in flight ops, launching the retrieving aircraft, embarking crew and cargo from a C2 and dealing with a collapsed gear of an F14. The island, hanger, flight deck and some aircraft will be lit by LED's and fiber optics. I'm loosely aiming for the late 80's before the 90's rebuild, mostly because I don't want that much extra scratch building, this thing is big enough as it is.
I have employed WEM and GMM PE sets for aircraft and the ship. I'm taking the best parts of both sets for each need. The WEM radar is better than GMM's but I like components of GMM's air wing and hand rails. I also have Tom's flotation canister racks. I am using mostly Tamiya aircraft sets in addition to the included kit aircraft as well as Trumpeter C2, E2 and EA-6B's. I'm going to use GMM's aircraft decals as well as starfighters for squadron insignias.
I promise to take more pics from now on and update as I move along.
1/4 of the airwing" border="0" />
Here's 1/4 of the planned airwing, the rest are still in boxes. Next step is drill out the exhaust and inlets, attach stabilizers, cleanup and paint.[
Hanger deck from the stern" border="0" />
Here's the view of the hanger bay from the aft. I still have stairs, landings, fuel tank holders, observation bays, storage racks, paint and decals. The hanger doors were cut out at slow speed with my dremel and the fine edge was finished with an x-acto blade and sanding sticks. The hanger deck is held in place by sheet styrene blocks that are 4x3 and glued to the underside of the hanger bay door modules. The hanger deck consists of two sheets of thick styrene joined at the mid ships by a 3x4 sheet of styrene. I chose the midships location as the gap would be the track for the fire doors. The fire doors are simply thin styrene stacked together to look like multiple panels. At the fore area of the hanger deck is the gym area. It's going to be a shame to cover all of this with the hanger ceiling and flight deck. At least the pics will show my work.
Starboard forward hanger door" border="0" />
The forward starboard hanger doors. I plan on displaying this as if the door was opening or closing. There will be crew at the door looking out and a tug moving a plane onto the elevator.
Top deck with radars" border="0" />
Here's the top deck of the island with the two main radars sitting in their homes.
Starboard aft hanger door" border="0" />
Here's the aft starboard hanger door. I threw planes in their to see how they would look through the hanger doors.
Hose reel, forklift and cart" border="0" />
The forklift is sooo cool. Also in this pic is a cart and hose reel. These are all from WEM, did I mention that the forklift is cool.
Starboard mid hanger door" border="0" />
Here's the starboard mid hanger door.
Tamita crew" border="0" />
I have the GMM PE crew and just picked up the Tamiya plastic crew. The Tamiya crew front have texture to them, their rears are PE style flat.
Yardarms and radar deck" border="0" />
This is the yardarms, hosereel, cart and Radar top deck. All of these are together for scale.
Next step is to finish sanding and cleaning the hull, paint the under water section and finish the hanger deck. I'm jumping around from hose reels and raft canister construction to the airwing to the hull, this keeps my ADD in check :-)
In case you're wondering that lego sub in the background is a Seawolf class boat. It was a kit I got a few years ago. Once the carrier is done the sub will have to move someplace else since it's about 1/72 or so, can't mix scales.
    April 2009
Posted by Leonidas on Friday, May 8, 2009 7:45 AM
It's an awesome kit, that's for sure. Looking forward for more updates.
    April 2005
  • From: I am at play in the fields of the Lord. (Texas)
Posted by m60a3 on Monday, May 11, 2009 5:01 PM
 Nice looking build so far! Glad you are finally working on the old girl, but it seems to be missing something... I don't know. Maybe..A FORKLIFT!! Yeah, that would be cool! I think that's what it needs Wink [;)].
 Nice work!                                       60
"I lay like a small idea in a vacant mind" - Wm. Least Heat Moon "I am at the center of the earth." - Black Elk My FSM friends are the best.
    July 2007
Posted by Lord-Dogbert on Tuesday, May 12, 2009 11:26 AM
38 hose reels are complete...
Phew, wasn't looking forward to building all of them but I finally just bellied up, got into a groove and got them out of the way.
IMG_8845/" border="0" />
My approach after the prototype was complete was to measure the distance between the inside of the reels, add the width of the x-acto #11 blade. I then attached round sprue to a piece of blue tape and cut the center sections to length; the gap is 2.05mm. I then attached the reel sides to the base with CA. After the reels sides dried I then spread to the sides to allow the center piece to be inserted. I dipped one side of the center piece in CA and slid it into place. After one side dried I used a toothpick to apply CA to the side and used my self closing tweezers to close things up for the final fit.
IMG_8848" border="0" />
It's inevitable that the carpet monster will strike when working on these things so I bring in the air cav. I empty the vacuum bag and make a few strafing flights over the last location of the monster. When faced with overwhelming air superiority the monster gives up my parts. Even parts this delicate survive the trip into the bag which really surprises me.
IMG_8857" border="0" />
All done. All 38 reels, 152 parts made it to the end. There are spares in the WEM set so those are going into the PE spares box. With some mods they can be used for ship's wheels, capstans and other things. Next step is to prime and paint these and then attach monofilament for the appearance of hoses. I'm still trying to figure out how to make nozzles for the ends. One or two of the hoses will be pulled out for filling a couple of planes on the stern.
    April 2005
Posted by m60a3 on Monday, May 18, 2009 4:21 AM
 Show the carpet monster who is KING, Dogbert!! Way to go. We await this beauty. Keep sharing, please!
                                             60
    July 2007
Posted by Lord-Dogbert on Wednesday, May 27, 2009 12:22 PM
Memorial weekend saw some progress, not as much as I wanted because I was concentrating on finishing my 350 scale Ohio class boomer and King Tiger diorama for a local IPMS show.
Started drilling out some of the intake and exhaust on the planes. Some are coming out awesome and others not so much. The odd ones will probably go into the hanger. Most of the problem is I just start the hole at the wrong angle and the hole doesn't look to be at the right angle. More on this and pics to come. Anyways...
I finished all 104 raft flotation racks from Tom's and cut out and trimmed the raft canisters. I've seen lots of people ask about using PE and I found that it's not very difficult at all, with some right tools. I use pliers that are not grooved, meaning that there are no grooves on the inside surface. Problem with grooves is that if you hold the part tightly you'll get grooves imprinted in the brass, nuff said about that. These parts are so small that pliers are necessary as you ca't use a PE fold table.
IMG_9198" border="0" />
This is the flotation rack fret. The quality is very nice and the brass is thin. I use a piece of 6x6 kitchen tile and a #11 x-acto blade to cut the pieces out. I try to be exact as sanding  these peices afterwords pretty much destroys them, at least my findings so far. I fully appreciate Tom's family continuing the business after his passing.
IMG_9201" border="0" />
I then line up the part where the first fold is to occur with the end of my blunt nose pliers and bend the part with either the side of my knife or my finger nail.
IMG_9209" border="0" />
After the first fold I rotate the piece and repeat. There is a tab at the top of the piece, after the second bend I fold the tab down into place.
IMG_9210" border="0" />
IMG_9214" border="0" />
I then place the piece into the jaws and light hold it. This sets the side walls perpinducular and closes them in on the tab that is at the top. It doesn't require much pressure to squeeze in the walls and make everything line up. The piece is now ready for the last bend, I push up the bottom tab agaist the wall of the pliers and voila, one down, 103 more to go.
IMG_9217" border="0" />
Ahh, the finished product. Now to finish cleaning up the canisters, paint the racks and start attaching them. All in all this part of the construction is 318 parts and about 6 hours just cutting and folding. I never imagined how many parts (and $) this carrier would consume.
    July 2007
Posted by Lord-Dogbert on Wednesday, May 27, 2009 1:17 PM
Wife's cousin Eddie made a surprise drop in on Saturday while I was folding the canister racks, he was wondering what I was working on so I showed him. He perked up and said, " I was on the Prize for 3 years in the early 80's"Tongue [:P] woohoo, he was already my friend but now he's now my most favorite friend in the world. He was a white shirt on deck and the hanger deck. He told me all about flex deck plane arrangements including the Alert Five, locked deck, launch only and recovery only modes. He gave me some advise on the hanger deck, I had made some of the watch overhangs that are high up and the bulkheads of the hanger deck, he advised what they were used for, how the worked and the arrangement of equipment on the hanger deck. I had enough planes ready that we went through a ouija board exercise on both the hanger and flight decks :-).
IMG_9222" border="0" />
Here's the general arrangement from the bow, looking aft. Some aircraft were moved a bit whilewe populated the flight deck but this is how they were stacked in. He had some cool stories about mishaps by the aircraft handlers both in bumping things and testing. One time an A6 caught fire because the avionics system was fired up for testing and they forgot to remove a cover from the pitot tube and a cooling vent. The equipment overheated and started a fire in the avionics bay. The guys in the watch booths spotted it, closed the fire tight doors and started the sprinklers. The sprinklers are contolled in zones so you can either spot treat the deck or flood it depending on the situation. All along the bulkheads are fire, eye wash, electrical and other necessary items with marking high on the bulkheads. I found a guy who has these markings at http://www.shipmodels.info/mws_forum/viewtopic.php?f=12&t=34259. I have some decal paper and plan on printing these soon. In this pic you can see one of my scratch lookout booths laying on the deck, we were using this one for placement of the lookouts. This one is the biggest and sits forward of the fire doors. The two clear odd looking planes are EA-6B's from Trumpeter, they still have lots of work to go.  The E2 in the aft starboard corner is in storage and generally had lots of stuff stored around it. The aft port area where the choppers are is generally where the admirals yacht was kept. My rear bulkhead doesn't go back far enough but that's fine for me. Will have to find a nice 350 scale yacht to sit in there, gotta keep the admiral happy. The little box area on the forward port bulkhead is the gym, I didn't go into much detail here since it really won't be seen once the flight deck goes on.
IMG_9220" border="0" />
Here's the flight deck, we didn't do alot here since I showed him all of the pics I have but he did change some of my ideas a tad. I had planned on having the C2 seen aft of the island here more forward with the crew unloading cargo and passengers disembarking to the island. He advised that generally during landing ops the C2 would land and taxi to the position where it is on the deck. There were many reasons but the aft cargo door brought in lots of cool air to help keep the temp down inside the aircraft while the crew worked. This position also helps protect the passengers and work crew from the landing area and a potential cable break. My favorite little forklift is at the cargo door and will be fitted with a pallet for the cargo to be placed on.
After 1 hour of this play and talk the wives finally asked if we were going to stop playing with the toys, why I asked, so we can watch TV!
I wanted to have a crew member painting an area on the island, cousin Eddie did this many times. I was going to build a scissor or man lift for this, he said nope. They just put a man box on a forklift and rasied you into position to paint, scary stuff as the ship rolls.
Aside from filling and sanding construction seams I haven't done much with the island or hull. Have to get working on the R2 (CIWS) deck modifications on the stern and some other hull mods. I already sanded the ladders and hatches off, to be replaced with PE. Perhaps this weekend will see the hanger along further and tape and prep for painting the lower section of the hull. I expect that once I get some traction this thing will move along quick towards the end since the small stuff will be done and ready to attach.
    September 2006
Posted by raider-hall on Thursday, May 28, 2009 8:39 AM
this going to be a nice build.
    July 2007
Posted by Lord-Dogbert on Thursday, May 28, 2009 12:15 PM
Thanks everyone for comments so far.
I talked to a photographer friend and showed him my pics, he was horrified that I would show anyone those, I knew they weren't magazine quality. He says I need another 600 bucks in a macro lens and some real lights. I wonder then why my cell phone phone camera takes better pics in some cases than my D-SLR, hmmm. He did admit that shooting metal objects is difficult because of the reflection.
    July 2007
Posted by scorpr2 on Thursday, May 28, 2009 10:13 PM
WOW!!!!  How big is that thing?!  I think you're doing a wonderful job!!!
    July 2007
Posted by Lord-Dogbert on Friday, May 29, 2009 9:59 AM
She's 43" stem to stern when complete. I'll be adding about 8~12 inches for water effect around the ship and to protect all of the parts that hang off here and there.
    April 2005
Posted by m60a3 on Sunday, June 14, 2009 12:25 AM
 Wow, your wifes cousin? Who'd a thunk it? Keep posting, friend!
                                        60
    July 2007
Posted by Lord-Dogbert on Wednesday, June 17, 2009 12:59 AM
Hello,
Not really any new updates on the project, spent two weeks in Chicago on business and concentrating on completing a 1/350 Ohio class boomer and 1/35 King Tiger diorama for the local IPMS show this Saturday.
I brought the life raft canisters with me on the trip and was prepared to explain to the TSA what they were but didn't have any issues there and didn't even have time to work on them.
After this Saturday i'll get some progress made :-)
