Gun Mount Numbers
    June 2005
Gun Mount Numbers
Posted by 1st_combat_comm on Tuesday, May 26, 2009 5:08 PM
I'm looking to build a diorama of the USS Ropers confrontation with U-85. I was able to get the Ropers after action report. It comments that mount 1 and 3 were the only ones unmasked to the target.
My question is how were the mounts numbered? Is there a standard?
Rich
Rich 1st Combat Communications Squadron Alummi Air Traffic Control And Landing Shop
    July 2007
Posted by Lord-Dogbert on Tuesday, May 26, 2009 6:15 PM
A friend told me in regards to battleships looking towards the bow from the stern that odds are port and evens are starboard. Not sure if that helps and applies to destroyers or not.
    August 2005
Posted by Tracy White on Tuesday, May 26, 2009 9:07 PM
For that class it would be:
1: Bow
2: Port Midships
3: Starboard amidships
4: stern
So essentially the u-boat was on the starboard side of the ship and the suprstructure and stacks prevented the port midships gun from being able to train on the target.
Tracy White Researcher@Large
    April 2005
Posted by ddp59 on Tuesday, May 26, 2009 10:19 PM
tracy, wouldn't it be starboard midships instead of starboard amidships as both guns are on the same deckhouse?
    March 2007
Posted by bondoman on Tuesday, May 26, 2009 11:40 PM
Tracy good info. As for the dio, like all battle dios, it's got a scale issue. The nearest distance between combatants I can find for the engagement, except for the later depth charging, was 300 yards. At 1/700 scale where the Roper would be about 4" long, the distance between units would be a little over a foot. Manageable, but the U-85 is going to be tiny. At 1/350 , 2 1/2 feet. At 1/240 assuming you use the Revell model as a starting point and scratch the U-85, which in all scenarios is the case anyways, a big piece of sea.
    June 2005
Posted by 1st_combat_comm on Wednesday, May 27, 2009 5:02 AM
Tracy that helps a lot but do you mind if I ask you where/how you found that? Believe me, I'm not trying to offend but would like to know so I can figure this out in the future.
I hadn't given a thought to that distance at all, thanks for bringing that up!! I was thinking 1/700 but one drawback is that I never worked on that scale before and I'm afraid that I'm going to lose a lot a detail. However, to be correct on the distance at 1/350 sounds like it would be a 3' by 3' base and thats a little too big for me. Thoughts? My 2 cents [2c]
Rich
    January 2008
Posted by DerOberst on Wednesday, May 27, 2009 6:49 AM
I would suggest cheating.
The point of a model/dio is to represent the subject and aid in understanding.  If you try to model the solar system to scale, you end up with a basket ball sized sun in Chicago and a marble sized earth in Sheboygan.  Interesting, but not terribly useful or practical.
So what do we do?  We cheat a bit on the distance scale.
Make them in the larger scale and place them at a closer distance.  That way you can see the subject and model in a scale that has some detail.
Otherwise you have two specks and a vast ocean.  Accurate, but not very fun!
    April 2005
Posted by Rick Martin on Wednesday, May 27, 2009 12:30 PM
Starting at the bow and working aft the gun mounts are numbered on destroyers as follows:
mount 51 (first gun mount)
mount 52 (second gun mount)
the first digit is the gun size i.e. 5 inch etc. the second digit is the gun mount number. Since you're doing a destroyer thats the numbering scheme. Not sure about big boys like cruisers/battleships etc.
"Whoever said the pen is mightier than the sword obviously never encountered automatic weapons" General Douglas Macarthur
    August 2005
Posted by EdGrune on Wednesday, May 27, 2009 1:49 PM
That may be correct for Benson/Livermores, Fletchers, Sumners, and Gearings but it is not correct for the 4-pipe destroyers like the Roper which are the subject of the discussion.
Ohh, and the Roper was equipped with 4-inch guns
    August 2005
Posted by Tracy White on Wednesday, May 27, 2009 8:44 PM
I've  "just known" it for some time; I can't tell you how I found out exactly. I've done this site for a number of years and it was her #3 gun, on the starboard side that sank the midget, so I learned the convention early.
DDP59: amidships and midships are the same thing; both guns were on the same deck house but one was on the port side and one was on the starboard.. I probably should have kept the same wording to make it less confusing.
Ed: When Roper was converted to an APD she traded her 4" guns for 3" mounts. Not really relevant to the discussion other than the fact that they retained the same numbering system.
