ship building advice?
    October 2006
Posted by skrooby on Wednesday, June 10, 2009 2:32 PM
Hi Everyone,
I'm not sure if this message is more appropriate for the 'Techniques' forum but I figured that this Ship forum is pretty close. I recently acquired a 1/700 Tamiya USS Missouri kit, complete with White Ensign and GMM photoetch. I'm more comfortable building aircraft and so this kit has me stumped, as far as painting goes. What's are some common techniques when it comes to masking and painting the deck and superstructure?
  1. spray grey overall and hand paint the deck, or
  2. spray deck and hand paint the superstructure?
  3. does it vary by kit?
I'm afraid that masking at that scale would be too time consuming and not very pretty.
 Any help would be appreciated,
Jeff
    July 2005
Posted by caramonraistlin on Wednesday, June 10, 2009 5:35 PM
Jeff:
Greetings:
I don't build in 1/700 but 1/350. However, what I do is airbrush the entire hull first. Glue on the deck (s) and then airbrush the entire deck/major super structure what ever color the super structure is. Then I hand paint the deck and any items molded onto it then touch up where  different colors meet. I airbrush the pe items whatever color they should be, superglue them in place and then touch up by hand if needed.  Of course I paint separately any items that get glued in place such as turrets, aa guns, etc. This was the sequence I used when I built a conversion of Tamiya's Missouri into a Montana and I have pretty much followed it on other ships I have built. Some people do mask off the decks but I never have.
Sincerely
Michael Lacey
    March 2007
Posted by JMart on Saturday, June 13, 2009 2:23 PM
Basically it varies from ship to ship.
I construct all the subassemblies and AB deck/horizontal structures, then haze/vertical structures. Put together and touch up. I leave all small parts on the sprue tree, IF the attachment point is the same as the 'glue" point, as I dont want to deal with paint stripping before assembly.
The first pass, I AB at right angles (say, only the horizontal surfaces) without masking the rest (vertical surfaces). Then I mask the painted areas and AB the vertical surfaces. My goal is to get good enough at AB that I can just "point and shoot" and not worry about masking (only right angles). But not yet :)
    August 2008
Posted by tankerbuilder on Saturday, June 13, 2009 5:10 PM
 HEY skrooby --- Glad you,re doing this ship .  I would imagine that doing a/c you have an airbrush . Definitely, spray the larger parts and go from there. If you decide to do any the measures of camo make sure of the time period , and go for it !!!!  tankerbuilder
