Prop guards on WWII US subs
Posted by Aurora-7 on Friday, June 12, 2009 8:30 AM
While doing some web research on Tambor class submarines, I noticed in some images of WWII subs and from completed kits of Gato's that the propellar gaurds are somtimes missing. I also noticed at White Ensign's website, they set photo-etched 'temporary' propellar gaurds.
I gather that at some point, the propellar gaurds on fleet boats were removed at some point to improve the boat's performance but 'temporary' ones were installed when in habors. Does anyone know if there was a specific time this practice was done? I want to do the Tambor class boat 'Tautog' at both the begining and ending of her wartime service and I'm trying to find out if she had her original prop gaurds at Pearl on Decmber 7th '41 and if they were removed by 1945.
    January 2009
Posted by Division 6 on Friday, June 12, 2009 9:28 AM
It all depends on the boat and refit.
Some of the boat's kept them till they where scrapped of made intio museums while others whe constructed with out them.
Many had them removed at one of their refits
2 reasons for removing them
1. so the enemy couldn't grapple them.
2. cut's down on noise.
Best thing to do is research the boat you are doing to find out it she had any at the time depickted or not.
Information on most boats willl be difficult, I've been looking for info on the Bream for about a year and have only found small blurry images that are mainly post war.
edit...
Looking at Navsource she had the guards in Dec 45.
Looks like she didn't have the marker bouys so you'll have to remove the incorrect ones on the model
Looks like an all wood deck, not sure what's going on in the stern.
She is also flared out in the forward gun position.
Eric...
Posted by Aurora-7 on Friday, June 12, 2009 10:04 AM
Thanks, D6.
Biggest problem with researching the Tautog is that there's little about her appearence at Pearl Harbor durring the time of the attack. There's plenty of her late in the war.
Aside from the hull shortening, the hardest thing to determine is her coloring. There's one image I've found that show's the Nautilus and Tautog at their piers durring the attack. The image is a bit distant and bow on of the Tautog. I'm assuming by late '41 her hull number is painted over and still overall black coloring but significantly showing wear (she is more that a year old and has done several missions by this time).
If I'm right in what I think you are refering to about her stern, I think that plating on the port and staboards sides are from muffler reworking. Tambors had external mufflers attached early in the war and I assume by the time of these shots there was some re-work done that placed them within the outer hull. I assume those are metal coverings.
    January 2009
Posted by Division 6 on Friday, June 12, 2009 11:32 AM
I've seen this boats name come up a number of times so there has to be some information out there.
This site has a pic of the boat with a flange for the gun at the rear but not the front, doesn't say what year.
Listed on the Bowfin site.
USS Tautog (SS-199) - Moored port side to south side of pier No. 2, Submarine Base, Pearl Harbor, T. H.
History.Nav.Mil
USS Tautog (SS-199) at rest, probably off New London, Connecticut, at the time of her completion in 1940. She is painted black, with large numerals ("199") on her conning tower side, and is fitted with a 3"/50 deck gun aft.
Starboard quarter surface view.
Might want to look around SubCommittee if you haven't already.
Floating Drydock may have something of use to you.
Interesting bit of info.
During the second wave of the attack, the USS Tautog is credited with being the first US submarine to single-handedly bring down a Japanese aircraft in WWII.
I believe this actual gun is now aboard the USS Pampanito in San Francisco.
Eric...
    November 2004
Posted by mkeatingss on Saturday, June 13, 2009 9:25 AM
As a side note, Tautog's big sister Thresher (SS-200) was the reason some boats choose to have their screw guards removed.
On 9 July 1942 Japanese Naval Forces attampted to capture Thresher by fishing for it with grappling hooks. They did manage to hook Thresher's screw guards, and was dragged up to less than 200 feet, before LCdr W.J. Millican C.O. finally shook off the hook.
A full, first hand account, of the incident, can be found in the Fall 1988 issue of Naval History, as part of an article by Billie Grieves TM1.
Mike K.
Posted by Aurora-7 on Saturday, June 13, 2009 12:39 PM
Thanks for the reference, Mike.
Yeah I can find lots of text references to the 'Terrible T' but not as much in the way of images from the first few months of the war. I really wanted to get a nice image of her foward deck in late '41 - early '42 but I think I'll end up using images of other boats like the Thresher.
From the images of the late war Tautog (something I should of noticed myself since I already have lots of them) seem to indicate that the Tautog did have her gaurds throughout the war.
    January 2009
Posted by Division 6 on Saturday, June 13, 2009 1:04 PM
I have a couple pix of her in 59 with them still in tact
They are however the flat type with wide spaced spars, different than those that come with the model.
The Tambor had the guards added  Feb 1945
Thrasher, Triton, Trout and Tuna where lunched with them in place.
Eric...
Posted by Aurora-7 on Monday, June 15, 2009 7:46 AM
I have those '59 images of her too, and I see your point about the flat shape of the gaurds.
