Converting a 1:60 Lindberg Shrimp Boat into a European fishing vessel from the late 1930s?
    February 2007
Posted by vonBerlichingen on Sunday, June 14, 2009 5:42 PM
Hi, all. As mentioned here, I would like to waterline and convert a 1:60 Lindberg shrimp boat into a small European fishing vessel from the late 1930s, for use in miniature wargaming:
/forums/1146203/ShowPost.aspx
Supposing that the hull shape is not completely wrong, would a more rectangular deck house be the main required change?
Where might I find some references re. such fishing vessels online? Thus far, most of my searches have tended to find hits about modern European fishing policy ...
Thanks in advance!
    March 2007
Posted by bondoman on Monday, June 15, 2009 1:46 AM
Here's a sample of a Danish vessel probably from about that era. Ignore the liferafts and meteoro sensors.
I don't know the provenance of the shrimp boat model, but I'd say it's American and several decades more recent.
Your vessel would certainly be under sail and be a wooden hull. It would be a nice little scatch project.
    May 2008
Posted by Billyboy on Monday, June 15, 2009 10:28 AM
The Shrimp boat is similar in Hull form to some German fishing vessels. See for example http://www.moduni.de/product_info.php/cPath/30000000_30400000_30406000/products_id/6098585
As the above photo says- a lot of the Scandinavian vessels (and indeed English ones) had rounded sterns.
You may find something like this of some use too
http://www.moduni.de/product_info.php/cPath/30000000_30400000_30406000/products_id/6023017
    August 2008
Posted by tankerbuilder on Monday, June 15, 2009 4:09 PM
  EXCUSE ME , but isn,t 1/60 a little large for war gaming ????? I am just curous , because I thought wargame ships were 1/1200  tankerbuilder
    February 2007
Posted by vonBerlichingen on Monday, June 15, 2009 4:58 PM
1/60 is not too large when you're gaming small amphibious or boarding actions ...
As for purely naval actions, there are other scales, too, such as 1/2400, 1/600 and 1/300 (ancient galleys).
P.S.: Thanks, bondoman and Billyboy!
    August 2005
Posted by EdGrune on Wednesday, June 17, 2009 7:49 AM
Look into some of the paper models of European coastal vessels.   While this is of British design they were similar on the continent.
This is a paper model by the PaperShipwright .   You can scale the parts and use them as a basis for scratchbuilding.
    August 2008
Posted by tankerbuilder on Wednesday, June 24, 2009 9:37 PM
 HI ---- If you want to do the work ,it,s not hard to put a rounded stern on the shrimper . To convert it to a fishing boat you will have to change some of her deck gear . It seems you are up to the task . Send us some pics and let us see your work . Many of the fishing boats in california have small deckhouses and they,re usually aft ! You can keep the ronud front but it would probably look better small and square .  tankerbuilder
