rokket, Searat & Bill, You all are correct about her being a type IX, but which one? The scales are all incorrect as are the kit manufacturers. Thanks for looking and the comments. Hint, there was surprisingly enough, no aftermarket PE or resin for these kits. Try again.
Searat, yes the railings are way out of scale, even larger than the "88" on the fordeck. This was a fairly quick build just to see if I could model "Shep Paine's" water.
doc
