Converting the uss Arizona revell kit into the uss Pennslyvainia?
    January 2009
Posted by afsf on Monday, June 29, 2009 4:26 PM
Has anyone done this? If so What all had to be changed?
Thanks!
    March 2007
Posted by searat12 on Monday, June 29, 2009 6:21 PM
Correct me if I am wrong, but I believe Revell already MAKES (or made!) a USS Pennsyvania kit in the same scale as the Arizona, so why go through the trouble of a conversion?
    August 2005
Posted by EdGrune on Monday, June 29, 2009 7:03 PM
You may be thinking of Lindberg (ex Pyro).    They made a small-scale which proported to be a Pennsylvania.     It is probably the second worst ship model kit I ever made, the worst being the 1:720 Revell Arizona.
Dragon makes a 1:700 scale late-war Pennsylvania which while not one of their better kits is far from the worst.
I think Mike Ashey did a conversion of the 1:426 Revell Arizona to the Pennsylvania in an article in FSM
    March 2007
Posted by bondoman on Monday, June 29, 2009 7:17 PM
Be aware that Revell sold kits of the Pennsylvania in both 1/426 and 1/720. Obviously they were a reboxing of the Arizona. I've seen conversions, and heard the differences described as "subtle". If it were me, I'd concentrate on getting the colors accurate. That's always a fun subject to explore.
Both are currently on eBay. The 1/720 is listed at $ 5, and the open box photo shows the main gun barrels flashed together like a bad resin kit. Probably worth the price.
The 1/426 is listed for $ 129 or so. Go figure. For that kind of money I'd go find the most accurate resin kit of BB-38 that you can.
    June 2006
Posted by Carmike on Monday, June 29, 2009 7:24 PM
Revell has issued a kit of the Pennsylvania which, typical of the time, is just the Arizona kit in a different box.  The Arizona and the Pennsylvania started out as sister ships but were refitted differently in the 1920's with the Pennsylvania being fitted with an extended flag deck and a extra level in the conning tower to enable her to serve as a fleet flagship.
The photo above, from the US Navy History Site, shows the Pennsylvania in 1934 and you can see the added level in the conning tower, the different shape of the flag bridge, and the different shape of the navigation bridge (which may also have been a level higher than in the Arizona to see over the conning tower).
After the Pearl Harbor attack the Pennsylvania was refitted several times including a large refit in which her single 5"/25's and 5"/51's were replaced by 5"/38's in twin turrets and a lot of the superstructure removed to save weight.
Depending on how much scratch building you are willing to do the Revell Arizona kit could be modified into the Pennsylvania.
Good luck!
    January 2009
Posted by afsf on Monday, June 29, 2009 7:36 PM
Yeah i have the 1:426 scale kit. I'm still doing research to see what all will have to be done. I'm thinking ill probably convert it to the pennslyvania during or right after pearl harbor. I think it would be a mess to try and rework the super structure and then to find twin 5 inch gun mounts.
    September 2005
Posted by warshipguy on Monday, June 29, 2009 8:03 PM
Bondoman is correct; the two Revell models of Pennsylvania were simply reboxed Arizona's.  Gold Medal Models includes the parts necessary to model Pennsy in their 1/426 Arizona set, but I have not heard whether they do so in their 1/350 set.  They include the parts necessary to convert the superstructure.  Good luch with your conversion!
Bill Morrison
    April 2005
Posted by ddp59 on Monday, June 29, 2009 9:43 PM
afsf, i'm redoing a 1/426 arizona to represent the pennsylvania of 1945. scratch built the twin 5" turrets & replaced everything from main deck & up except fot 14" turrets & stack. i fixed the stern around the prop areas to get rid of that concave look & added the anti-torpedo bulges.
    January 2009
Posted by afsf on Monday, June 29, 2009 10:20 PM
Awesome! What did you scratch build the 5" turrets with? Also how much re working of the superstructure was there? If you have pics I would love to see them?
    August 2005
Posted by Tracy White on Monday, June 29, 2009 10:51 PM
There's quite a bit of difference in the superstructure by 1945; you'd essentially have to redo everything from the main deck up.
As far as 1941 goes, you will need to decide how much you care. The shape of the superstructure platforms is essentially the same, but the verticals (armored conning tower, splinter shields, etc) are different. The platforms on the stack were different, and the ventilators on the #2 & 4 barbetters were a different shape as well.
Resources are weak, the best I've found that was affordable is "Keystone Battlewagon" by Myron Smith, which has overhead and side view drawings circa 1935 in 1/500th scale. Using those and the few 1941 and 1942 photos that are available online you should be able to infer how things looked at the attack on Pearl Harbor. Don't forget the turret top colors!
Tracy White Researcher@Large
    March 2007
Posted by bondoman on Tuesday, June 30, 2009 12:16 AM
asfs here's the image that you might start with. Battleship colors at 12/7/41 are a Master's Degree so ask early and ask often. Not me, but the white hats all have opinions.
You've either been astute enough, or stumbled upon, a top ten ship modeling subject from WW2 in the Pacific.IMHO.
    September 2005
Posted by warshipguy on Tuesday, June 30, 2009 11:13 AM
Another source is Siegfried Breyer's Battleships and Battlecruisers, 1905-1970. It has excellent drawings showing differences between sisterships, although in 1/1200 scale.
Bill Morrison
    August 2004
Posted by a6m5zerosen on Tuesday, June 30, 2009 12:44 PM
The best reference by far for this conversion is the new Dragon kit in 1/700 scale of the USS Pennsylvania in 1944 after her final refit.  It is kit # 7041 and includes photoetched parts, and is beautifully molded & detailed. If you are converting the Revell 1/426 Arizona, the easiest thing to do would be to simply lay out the parts from both kits and convert the Revell parts to match the Dragon parts.  I'm not saying the Dragon kit is perfect, but it would be a great place to start.
"no, honey, of course that's not another new model. I've had that one for a long time..."
    April 2005
Posted by ddp59 on Tuesday, June 30, 2009 1:42 PM
afsf, i used .080" sheet plastic in the bread & butter fashion then cut to shape. still have to cut the notches for the gun barrels as tho they can travel up & down. except for the stock piece of the top of the forward superstructure, it is all scratch built.
a6m5zerosen, that was not her last refit as that happened between march & june 45.
    August 2008
Posted by tankerbuilder on Tuesday, June 30, 2009 3:45 PM
 AFSF -- Funny you should ask this question ,as it is in with something I,ve thought about before . I would like to do the two sisters before they got rid of the cage masts and other stuff . I have an old picture in a sdb at the bank and it,s another I,d like to build to that . Do you remember the GREAT WHITE FLEET ????? I have the fleet steaming in line aquarter off the california coast . Whatta sight they made !!!!!Even pictures of either ships with the cage masts is hard to find . Good luck on the build and lets see some project pics ---- TANKERBUILDER
    January 2009
Posted by afsf on Wednesday, July 1, 2009 5:55 PM
All right guys:
Sorry for the delay in responding. I went and toured the USS. North Carolina so i didnt have my computer with me. It was a pretty awesome trip. I Took close to 700 pictures of her. So if anyone is doing a model of her let me know and i might be able to help.
But back to the pennslyvania. I've decide to model her after she looked at the end of world war 2. I found some 5" inch guns off of another kit that I had but never finished since half the parts were lost. And as far as the super structure goes im still trying to figure out. Also thanks guys for all the input and pictures.
    September 2005
Posted by warshipguy on Wednesday, July 1, 2009 6:55 PM
Back in 1995 and 1996, FSM published two periodicals titled "Modeling the Second World War".  One of the articles in the second year was "Pearl Harbor Survivor - USS Pennsylvania," converting Revell's 1/720 Arizona to a late-war Pennsylvania. It includes templates for the bridge modifications necessary for the conversion in 1/720 scale that can be scaled up for 1/426.  I recommend this article highly!
The author's name is Jim Kloek.
Bill Morrison
    January 2009
Posted by afsf on Wednesday, July 1, 2009 7:12 PM
deffinently a big help on the super strucure and where the twin 5" mounts went
    April 2005
Posted by ddp59 on Wednesday, July 1, 2009 9:43 PM
afsf, go to that same page, 7th from the bottom as it shows what she looked like after june 45 refit.
A line drawing by A.L. Raven of the Pennsylvania (BB-38) as rebuilt with twin 5in/38 guns, July 1945
that is the one i'm doing
    January 2009
Posted by afsf on Wednesday, July 1, 2009 10:03 PM
SAME SITE CORRECT?
 Battleship Photo Index BB-38 USS PENNSYLVANIA
    April 2005
Posted by ddp59 on Wednesday, July 1, 2009 10:47 PM
yes.
    January 2009
Posted by afsf on Wednesday, July 1, 2009 10:57 PM
oki googled imaged searched the original pics i wasnt sure.
How far along are you on yours?
    April 2005
Posted by ddp59 on Thursday, July 2, 2009 2:22 PM
maindeck & 2nd deck level built & glued to hull. forward & aft superstructures built, aft structure glued to deck whereas forward superstructure is currently removeable. 40mm aa guntubs made & glued to decks. torpedo blisters & fixing stern design problem almost finished except for final sanding. 14" turrets needs a bit more work done to them & 20mm aa gun tubs made & glued to those turrets. 5" gun directors made but still need to make their radars. the 2 horizontal triangular antennas on the forward superstructure still have to be made. 5" gun turrets made but slots for gun barrels still have to be done. all previous portholes, cables & paravane on hull have been removed. the fix i did to the stern & torpedo blisters has also been done to 2 other arizona hulls after being shortened as they will be nevada of 45 & oklahoma of 41.
    January 2009
Posted by afsf on Thursday, July 2, 2009 2:38 PM
Good deal. I've started cutting gun tubs off the deck but thats about it.
    April 2005
Posted by ddp59 on Thursday, July 2, 2009 3:01 PM
i made new main decks from .o40" sheet styrene. all the gun tubs are from .010" sheet styrene not from the kit.
    January 2009
Posted by afsf on Thursday, July 2, 2009 3:06 PM
gotcha. How hard was it to shape the new gun tubs?
    April 2005
Posted by ddp59 on Friday, July 3, 2009 12:08 AM
depends on where they are located. on the decks, i marked out the location & shape then cut, bent & glued the .010" plastic to those locations. on the main turrets, i made disks out of .020" plastic then cut to length .010" plastic, bent it & glued it to the disks. after glue had set then i removed any extra glue that was showing.
    September 2005
Posted by warshipguy on Friday, July 3, 2009 9:19 AM
Again, check out the very fine article about this conversion written in FSM's 1996 Modeling the Second World War; it gives terrific templates, very clear photos, and diagrams. It will be a big help to you.  I can send you a copy if you like.
Bill Morrison
    April 2005
Posted by ddp59 on Friday, July 3, 2009 11:36 AM
warshipguy, possible to get a copy? also fsm did a 2 part article i think oct/nov 2005 on converting i think 1/350 scale arizona to late war pennsylvania. i have the 2nd part & it started me on this model.
    January 2009
Posted by afsf on Friday, July 3, 2009 1:36 PM
Bill Morrison
I would very much appriciate it if you could!
