S-100 Deutsches Schnellboot WIP
    August 2007
Posted by doc-hm3 on Sunday, July 12, 2009 12:54 PM
 I started this build two days ago, and so far so good. Very little putty was used on the keel and driveshaft housing on the port side. The hull halves joined very nicely and were welded together with "Tamiya" liquid cement. The putty is also "Tamiya" (but is getting almost impossible to find)white tube. I bored out the bilge pump holes and the water cooling intakes and the exhaust ports, all done with "Dremels" 3 round burr heads.The torpedo tube doors went on perfectlyThe bridge fit flawlessly to the rear deck, as did all of the detail parts. I have read that there is an issue with the forward 20mm fitting correctly in the gunners amored tub, but I will address that at a later point in the build. There are four smoke cannister can mounting rings molded on to the rear deck and the two center rings have to be removed as per the directions.This as far as I have gotten so far. I just wanted to share my build as it progresses.
                                                Thanks for looking, doc
All gave some and some gave all.
    July 2009
Posted by Austyn95 on Sunday, July 12, 2009 6:56 PM
Very nice. I'd say its beggining to come along.
So your gonna clean that up right? No, i'm just gonna let it sit there. It'll give me something to do when theres nothing else to do.
    August 2007
Posted by doc-hm3 on Sunday, July 12, 2009 9:50 PM
 Austyn, thanks for looking and the encourgement. As you can see sometimes it takes a while to get some lookers and sometimes even longer for some to make comments.
 It was great having you up here and sharing the BB-63 USS Missouri build wiith you.Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]
                                                  Love, uncle charlie (doc)
    June 2006
Posted by Grem56 on Tuesday, July 21, 2009 2:16 AM
Nice start to the build doc, especially the extra work on the exhausts. Are you going to be adding one of the numerous PE sets or are you sticking to Revells offering?
Julian Thumbs Up [tup]
illegal immigrants have always been a problem in the United States. Ask any Indian.....................
Italeri S-100: http://cs.finescale.com/FSMCS/forums/t/112607.aspx?PageIndex=1
Isu-152: http://cs.finescale.com/FSMCS/forums/t/116521.aspx?PageIndex=1
Posted by Model Maniac on Tuesday, July 21, 2009 8:17 AM
Looks so far so good, doc! Is that Revell's 1:144 kit? If so, is it an older version or newer one? (newer one carries Flak38). I have the older version built but the newer version is still in box.
Impressive Songs:
All 10 Playlists that I created on Youtube:
http://www.youtube.com/user/ModelManiacThailand/playlists
Pan Flute Music (300 songs) (Most Popular, over 100K views):
https://www.youtube.com/playlist?list=PLUNb2zPxGTZO7alagEPsEMzgBkWt4-vKV
El Condor Pasa (Top 50) (World's most famous and my most favorite song):
http://www.youtube.com/playlist?list=PLUNb2zPxGTZOLKHbju350mLle4HkMhsb8
    August 2007
Posted by doc-hm3 on Tuesday, July 21, 2009 1:47 PM
 Julian,  thanks for the interest, She's going to be an "OOB".
 Phaisal, this kit is the original release in 1/72nd scale. Thanks for looking.
        doc
    June 2006
Posted by Grem56 on Tuesday, July 21, 2009 2:04 PM
http://modelshipwrights.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=130092&page=25
This is by now a very long but very interesting thread about Italeri's S-boat but you can pick up some nice info if you dig in doc..........................
Julian Smile [:)]
    August 2007
Posted by BGuy on Tuesday, July 21, 2009 5:54 PM
Doc,
Excellent work so far, and very fortunately for me you've decided to share your build just as I'm about to start mine.  Have you seen other published builds of this kit? There's just an incredible one here: http://hsfeatures.com/s100cw_1.htm
Anyway, I see you're doing a "build it first and THEN paint" method, yet as I perused the kit's instructions yesterday I had  rejected this out of hand because there are going to be SOO many itty-bitty bits that would have to be painted in place to accomplish this.  Could you maybe elaborate a bit on your gameplan?  I'd really like to hear whatever you can share about this build.
Posted by Model Maniac on Thursday, July 23, 2009 7:26 AM
        doc
Thanks, doc! My mistake, it was 1:72 scale, not 1:144. I'm going to get PE upgrade set from Eduard for my S-100 Flak 38 for $39.95. S-100 original's also available at the same price.
The new S-100 1:35 from Italeri is also tempting because of its size and details. But at nearly $250 here I think it costs too much. I paid only $85 for 80' Elco 1:35 which is a little shorter than the S-100.
Impressive Songs:
    January 2006
Posted by EPinniger on Thursday, July 23, 2009 12:38 PM
Strange - here in the UK (Great Britain) the Italeri 1/35 Elco costs about £80, and the S-100 about £95.  Maybe the increased cost of shipping the larger S-100 model over from Europe is the reason. There's also a larger price difference in the USA - Squadron.com are asking $135 for the PT and $224 for the S-100.
    August 2007
Posted by doc-hm3 on Friday, July 24, 2009 4:11 PM
Julian, thanks for the link, there's a lot to look at and admire.
BGuy, I just thought that I would build it and then paint it. I guess i will see what degree of difficulty that I have assigned to myself.
        doc
    June 2009
Posted by figure freak on Friday, July 24, 2009 4:27 PM
beautiful, i think i might have to pull this kit out of my stash and DO IT
    August 2007
Posted by BGuy on Friday, July 24, 2009 5:18 PM
Well Doc, good luck with the build.  I think that given all the akward internal areas near the bridge I'll be doing a fair amount of paint/assembly/paint/assembly steps a la an aircraft cockpit installation.  Keep those pics and commentaries coming--I'll be watching closely.
    August 2007
Posted by BGuy on Sunday, July 26, 2009 6:26 PM
Doc, (and anybody else doing this kit), just a warning about the stand.  Don't leave it out in the rain--apparantly plastic rusts:
Tongue [:P]
