Imai/Academy Roman Warship - Completed 26/8/09
    January 2006
Posted by EPinniger on Monday, August 3, 2009 5:40 AM
Here are some work-in-progress photos of my Roman galley warship model. This is built from the current Academy kit which is either a reissue or an exact copy of the 1970s Imai kit, and represents a smallish Roman galley from the late Republican period. The scale on the box is given as "1/250" but the model is actually somewhere between 1/72 and 1/96.
So far I've assembled and painted the basic hull and masts, and painted the oars (not fitted yet). Most of the smaller parts are yet to be added along with the sails, rigging, etc. The display stand is also unpainted currently.
I decided to go for a fairly toned-down and weathered appearance compared to the kit's suggested colour scheme. Most of the ship is painted to represent weathered, unvarnished wood; I used different base colours and highlights to represent different woods, for the hull and deck planks, fittings, spars etc. The decks were also given a somewhat more greyish and weathered appearance compared to the hull. The wales are painted with tar (Revell Tar Black) as is the hull bottom, and the decorated parts of the hull are painted with red ochre; this is a pigment (iron-based, I think) well-known for its use on 18th and 19th century ships, but I strongly suspect it was also known and used in ancient times.
I painted the model using acrylics - the base colours are mostly Revell (with Caldercraft paint for the red ochre); the wood effect is produced by first drybrushing with lighter colours (both Revell and craft acrylic paint) then adding a thin black oil wash to highlight the grain and plank seams. Gilded areas are Vallejo Old Gold over a base coat of tar black, and the bronze ram is two coats of Revell Copper over a matt black base coat, with green, black and grey oil washes to represent "verdigris" corrosion.
I also scratchbuilt a new fighting tower to replace the "stone" tower in the kit. There is evidence for Roman ships carrying towers like that, made of wood painted to resemble stone, but I really didn't like the look of it on the finished model, so I made a new tower, of approximately the same dimensions as the original, of a lighter wood construction (Photo 2 shows the kit tower for comparison).
The tower is made from Evergreen and Slaters styrene - the planked surfaces are Slaters textured styrene sheet - with the ladder from the kit. Not knowing much about the style and construction methods of Roman wooden fortifications, I went for a simple and functional a design as possible, based loosely on the style of the kit's stone tower. They're not visible in these photos, but the vertical pillars have angled supporting struts in the upper corners.
Finally, I'd be interested to hear any thoughts on this possible solution to the oar problem (see my previous Roman warship thread). Here the oars are placed alternately in the upper and lower banks, so the model can be built as a bireme without adding any more oars (note that the oars aren't very even-looking, as they aren't glued in place). The empty holes on the underside of the outrigger (apostis) aren't visible, whilst those on the side don't look conspicuously wrong to my eye.
Anyway - I'll post some more photos when the model has made further progress!
    January 2006
Posted by EPinniger on Wednesday, August 5, 2009 5:22 AM
More parts have been added to the ship including the scratchbuilt fighting tower (now painted), bollards, steering oars and the canopy aft; I painted the ends of this to represent wooden support hoops.
Currently I'm working on painting the 26 shields. These (round, with a large central boss and 4 different patterns) don't look much like any Republican-era infantry shields I've seen (which are oval with a distinct ridge down the centre) but for all I know they may have been permanently fitted to the ship rather than (as with Viking ships) the shields used by the troops on board. Lacking any reference material (other than the kit box art) I decided to paint the 4 different designs red, dark blue, green and greyish-black, with the boss and raised detail bright steel, and an overall black wash to tone down their appearance.
I should add that I would really appreciate any constructive feedback and advice from anyone with any knowledge of ancient ships! I still haven't made a decision about the oars, but I'm inclined to go with the setup shown in my previous post. I'm also thinking of removing the plastic main sail (I've already removed the artimon sail), it just looks a bit too artificial for my liking.
    March 2004
Posted by subfixer on Wednesday, August 5, 2009 5:58 AM
Now that is really nice! I especially like the subdued tone of the paint. The only nitpick that I have is the red and white striped canopy, it just looks a little thick to me. But, overall, it is very well done!
I'm from the government and I'm here to help.
    July 2009
Posted by Ausmosis on Wednesday, August 5, 2009 6:25 AM
I have to agree. This model looks fantastic. You did a fabulous job!!
    February 2007
Posted by vonBerlichingen on Wednesday, August 5, 2009 7:16 AM
That is very nice work so far! The shields were probably not permanently fitted - apparently, the entire crew could have fought when necessary. Oval scuta would have been used by the ship's complement of marines, although the unarmoured rowers may have used the small round parma instead.
Besides, permanently fitting shields would have been an expensive way of building a bulwark, given the labour and materials that went into shield construction (plywood-like layers of wood, a felt covering on face and reverse, brass shieldboss, and metal binding).
Posted by Model Maniac on Thursday, August 6, 2009 3:27 AM
Very nice work! I wonder why the ship needs a tower.
Impressive Songs:
All 10 Playlists that I created on Youtube:
http://www.youtube.com/user/ModelManiacThailand/playlists
Pan Flute Music (300 songs) (Most Popular, over 100K views):
https://www.youtube.com/playlist?list=PLUNb2zPxGTZO7alagEPsEMzgBkWt4-vKV
El Condor Pasa (Top 50) (World's most famous and my most favorite song):
http://www.youtube.com/playlist?list=PLUNb2zPxGTZOLKHbju350mLle4HkMhsb8
    February 2007
Posted by vonBerlichingen on Thursday, August 6, 2009 5:50 AM
The tower was probably so that archers and/or javelinmen could shoot over the other crew, while the latter were involved in boarding or repelling boarders.
    July 2009
Posted by Vagabond_Astronomer on Thursday, August 6, 2009 11:58 AM
Nice work!
"I have loved the stars too dearly to be fearful of the night..."
Posted by millard on Thursday, August 6, 2009 2:02 PM
Very nice. I like your fighting tower nice add-on
Rod
    January 2006
Posted by EPinniger on Monday, August 10, 2009 9:30 AM
More progress:
I've now added the oars, yards and shields. The oars are in two banks, using the setup I mentioned previously - this isn't perfect, but IMHO gives the best-looking result without having to buy or scratchbuild more oars. (Putting all the oars on one side of the ship isn't an option, as the model will be displayed on show tables with both sides visible).
I also removed both of the sails from their yards. They aren't bad at all by the standards of injection-moulded sails, but they just looked a bit too stiff and unconvincing to my eye. It took me a while to make the decision all the same - the model looks rather bare in the photos above, but now the rigging is in place it looks much better.
The shields are another compromise. From vonBerlichingen's comments, I suspect they would have been the standard oval "scuta" and the shields supplied in the kit are too ornate as well as being slightly wrong in shape. But I really didn't want to attempt cutting off the shields from soft vinyl plastic wargaming figures and using them on my model, nor the alternative of building 24 from scratch, especially as I was intending this to be a fairly quick and straightforward build! So I went with the kit shields. With an oil wash they don't look too bad (they don't show up well in the photos above; I'll try and get some better photos of the finished model)
As Subfixer mentioned, the canopy is overscale in thickness, I tried to conceal this by painting the ends to resemble wood supporting hoops (which are about the right thickness) so the thickness of the central "cloth" part isn't so noticeable!
I'm now working on the rigging, which is more or less the final stage of the build (the display stand and nameplate also need painting). The rigging plan appears to make sense (though I've no idea if it is accurate for an ancient ship, or even if anything definite is known about the rigging of ancient ships!) so I suspect it was taken from the original Imai instructions. I'll hopefully post some photos of the finished article soon.
    January 2006
Posted by EPinniger on Wednesday, August 26, 2009 6:34 AM
Finally here are the photos of the finished article - sorry for the delay, I finished it nearly two weeks ago!
The finished model has some compromises (such as the oars and shields) and no doubt some inaccuracies, but I'm still pleased with the overall result. I rigged it using thread from my spares box (originally from a wood kit), and the plastic blocks from the kit (painted + drybrushed). I didn't use the deadeyes in the kit - they looked a bit too "modern" to my eye, though I have no knowledge of ancient rigging techniques! So I rigged the shrouds using blocks; their position is deliberately uneven. I also added leather covers to the top oar ports, which are depicted in a number of ancient images of galleys; these are "Kristal Kleer" painted brown and drybrushed.
My model is still lacking figures - I hope to pick up Orion's 1/72 "Roman Sailors" set, and possibly some Republican legionaries, at a local wargaming show next month. If I do I'll post some more photos of the galley with its crew. (Though the Orion oarsmen will have to wait for a future project; the rowing benches on my model are now inaccessible).
    January 2006
Posted by EPinniger on Saturday, August 29, 2009 10:10 AM
Forgot to edit the original thread title to reflect that the model is complete - now fixed.
    July 2009
Posted by Vagabond_Astronomer on Sunday, August 30, 2009 7:34 PM
The finished product looks impressive. Ships of that period fascinate me, though I've never built a model of such. You certainly captured the feel.
