Jeff Herne had stated in 2003 that he printed his sheets on Plastic, so we were wondering what printer he might be using if that was actually how he was doing it. Since he is, apparently, no longer associated with FSM or this forum, it is an academic question. I had hoped to find out if there is a printer out there that had a straight enough path to be able to use plastic or metal sheets. I think a laser printer could work since it works by fusing the toner to the page with heat. I don't know if that heat would be too hot for a plastic sheet however. A sheet of .010 might just get a bit wrinkly! Or worse, get stuck in the printer! That probably would not be a problem with a metal sheet though. Now whether the fused toner would actually stick to brass or not, that's another question. Has anyone out there ever tried anything like this?
I had thought of using carbon paper, but I hadn't thought far enough to think of the clear flat. Thanks! I had also thought of gluing the paper to the plastic, but then you have to get it back off eventually. If you glue it firm enough to keep it from moving while you are cutting the plastic, then the paper will be harder to remove later. So overall, if I can't use a printer, then my best bet is probably the carbon paper. What do you use to scribe with? Just a fine point pen?
