625 ton Venetian Carrack circa 1450, scratchbuilt, 1/700
    October 2009
Posted by Tom L. on Tuesday, October 20, 2009 8:44 AM
This is my first attempt at scratchbuilding; carracks are a ship type perhaps nearer and dearer to my heart then even my beloved pre-dreadnoughts.
In the Conway's History Of The Ship volume "Cogs, Caravels, and Galleons", length and beam, among other dimensional tidbits, are given for a carrack listed in the Timbotta Manuscript, 140 feet by 38.6 feet.
This gives a length to beam ratio of roughly 3.6:1, a tad on the narrow side from what I've read about carracks, but it's exactly the ratio that Bjorn Landstrom gives in his book "The Ship" for a ship of 125 feet in the same manuscript.
The stempost is mentioned as being 51 feet above the keel, and 12 feet taller then the sternpost...I've been a little dismayed by the appearance of my work so far, the amount of freeboard seems extraordinary, but the height of the stem above the waterline scales out to 34 feet; guesstimation makes me think that 16 feet of draught is in the "acceptable" range...
Here's the Timbotta Manuscript illustration I'm using as my guide:
The amount of curvature in the sheer strake seems excessive to me, too excessive; I'll be playing around with that.
Masting and rigging will be based on WA's "Kraeck" woodcut of circa 1468, with some free interpretation as needed/desired.
I began with seven layers of .020" Evergreen stock laminated together, and roughed some lower hull contours into it forming a raft.
Doubting the dimensions I mentioned above, went with a straightforward 3:1 length to beam ratio.
It didn't look "right", yet I persevered and began adding and shaping by eye some templated onto the raft.
It was looking even less satisfying.
I pared about .080" of beam off of my beginning, creating a very slab sided and awkward looking thing, with ratios more fitting for an 18th century frigate, so I re-introduced some beam in the form of slabs of .020" stock slapped to the sides, remembered that I didn't take into account the amount of overhang the stempost has in the overall length, so I removed the appropriate amount of stern, and went to work with the sandpaper to achieve this hull shape, up to the upper deck:
A little forward motion with the fitting of the of the stern counter piece (correct term?) with the tiller opening:
You can see where I've marked the locations for false ribs that will be visible; I'm only going a semi plank-on-frame route; it uses less plastic, mail order is my only source for Evergreen stock, and I'm impatient!
Please excuse my nasty workbench.Tongue [:P]
    March 2005
Posted by mfsob on Tuesday, October 20, 2009 7:42 PM
Heck, my first attempt at scratchbuilding in 1/700 was a Japanese diahatsu landing barge - you just keep whacking away until it looks right to you. I think you're off to a fine start.
    October 2009
Posted by Tom L. on Friday, October 23, 2009 8:56 AM
Little update:
    August 2008
Posted by tankerbuilder on Tuesday, October 27, 2009 8:33 PM
 Hello,TOM L. And I thought my WW1 KRONPRINZ was a tough scratchbuild in 1/200 scale! I will follow your posts to see how she works out. Did EVERGREEN tell you that they make sheets larger than what you find in hobby shops? I deal direct with them (I also do commissions) so I get the bigger sheets. I can,t wait til you get more done.   tankerbuilder
    October 2009
Posted by Tom L. on Friday, November 20, 2009 9:54 PM
An update:
Planking with .005" sheet strips...not quite the effect I hoped for.
GAPS, GAPS, GAPS!
I'm hoping paint will help conceal some of this sloppiness
Stern:
Coming along, messily...
Slopped a little black paint on it to see if I should try and keep at it:
Mmmmm, tiny.
Basic hull planked:
Some preliminary painting of the main deck.
(For those that may be wondering, the bottle caps are my paint cups, very handy!)
Sub-structure to the "weather covering" between the forecastle and main deck:
Planking the forecastle, starboard:
Port:
Planking the weather covering/deck:
Cleaned planking:
Inboard stringer, detail moldings, and large cross-timber (anchor securing?) added:
Trimming the quarterdeck to size:
looking forward:
Quarter deck with beam-ends faked into it, main deck cargo hatch under construction, and main deck windlass:
Mmmm, tiny...
    January 2006
Posted by RedCorvette on Saturday, November 21, 2009 1:24 AM
Terrific work!  Look forward to seeing more.
Mark
FSM Charter Subscriber
