3 sheets of plans from Cutty Sark .org
Posted by wjbwjb29 on Thursday, November 5, 2009 6:34 PM
Hello;
This may be a stupid question but I recieved the set of plans from Cutty Sark.org the oficial site and was wondering if anyone had any tricks on how to get them to lay flat. I would rather not tape them to cardboard if I dont have to because of the tape ruining the paper. Is there any type of drawing holder available. I might check some drafting sites. Any help would be appreaciated.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
Posted by cassibill on Thursday, November 5, 2009 6:42 PM
Weighting the corners with clothespins maybe.  I don't know the size of the things but maybe a cheap poster frame.  They'd be flat and covered but still visible.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by wjbwjb29 on Thursday, November 5, 2009 7:00 PM
Thanks I have a Hobby Lobby by me and will check them out.They must have been rolled up in that tube for quit awhile. Im not complaining, I would rather have rolled plans than folded.
Thanks again
Bill
Posted by cassibill on Thursday, November 5, 2009 8:02 PM
Glad to be a help. I've bought several poster frames.  The cheapest was at Walmart, I think, about $10 for a 24"x36".  Part of my design for my new work area is a poster frame or 2 over the desk for plans, instructions, pics, etc. of what I'm working on at the moment.  For long term storage for over sized references, I'm leaning toward an artist's portfolio. It's basically an accordian file on steroids and it is archive safe!  The librarian and genealogist in me makes storing, organizing. and accessing things a gift.  You should see me pack a freezer or suitcase.
    May 2003
Posted by jtilley on Thursday, November 5, 2009 8:06 PM
The first thing to do is roll them up again, as tightly as you can, in the other direction.  You may find that will take all, or nearly all, of the curl out.
My personal habit is to fasten the plans of the model I'm working on to a sheet of foamcore, using staples.  If you put them in the extreme corners, and take them out carefully when you're finished, the damage to the plans will be almost nil.
fox
    January 2007
Posted by fox on Thursday, November 5, 2009 8:26 PM
    Micro-Mark sells a plan holder that mounts to the edge of your workbench with a cross arm that adjusts for the size of your plans. You clip your plans to the cross arm and they hang down so they are easy to read. Professor Tilleys suggestion should make the plans hang down very nicely. The holder only costs $23. My My 2 cents [2c].
JimCaptain [4:-)]
 Main WIP:
    May 2006
Posted by Shipwreck on Thursday, November 5, 2009 9:06 PM
I like to store my CS plans rolled up in their shipping tube. When I need them I unroll them on a flat serface and weigh the corners down with something. I am not actually building from them; just using them for reference! When I am using them, I am frequently taking measurements off of them which require some bearing down on them. That works better on a flat surface under good light than hanging on a board on some type of easel display.
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    May 2003
Posted by jtilley on Friday, November 6, 2009 12:02 AM
I've got one of those Micromark "plans holders," as a matter of fact.  It's an extremely useful tool; I've got it set up so the plans are normally behind me when I sit at the workbench, so I can swivel around and take measurements from them any time I need to.  I do find that fastening the plans to something flat, rigid, and light (foamcore) makes it a lot easier to take measurements from them.
    January 2005
Posted by steves on Friday, November 6, 2009 11:47 AM
Most people tend to roll plans with the back side showing.  If you roll them with the printed side showing it generally makes tham much easier to handle when unrolled.
Steve Sobieralski, Tampa Bay Ship Model Society
