Looking for the correct colors for a mid '60s Fletcher Tincan.Need both the horz and vert surface colors. Does anyone have the right numbers ??
See post below re: Modern USN hull & deck colors. Unless you suffer from AMS, then you must go to White Ensign Models' Colourcoats paints
What scale on the decals?
EDIT -- see my response to your mis-placed post in Math Conversion
bump
doing a 1/350 square bridge Fletcher. I did get the after market large numbers for the hull.Looking for the FS # for the paints.(which haze gray,etc?)
radartec doing a 1/350 square bridge Fletcher. I did get the after market large numbers for the hull.Looking for the FS # for the paints.(which haze gray,etc?)
Unless I'm wrong Ed was suggesting looking here: /forums/t/125141.aspx
Where MM Neutral grey for verticals; Gunship Gry for decks and Engine grey for non-skid was the recommendation. Which sounds right to me.
Thanks for the help
